Kubota Tractor B1181DT-F2-EC-S5 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B1181DT-F2-EC-S5 Tractor
Number of Pages: 315 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Dipstick And Guide
Aceite Bomba / Oil Pump
Piston Y Cigueenal / Piston/Crankshaft
Volante / Flywheel
Combustible Bomba (Mecanico) / Fuel Pump (Mechanical)
Alternador Y Polea / Fan Drive Pulley
Agua Bomba / Water Pump
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Palanca Acelerador / Hand Accelerator Lever
Ventilador / Fan
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Cab Inner Switch
Conmutador/Rele / Switch/Relay
Tablero De Instrumentos Y Interruptor / Panel Board And Switch
Tablero De Instrumentos [Componente Piezas] / Panel [Component Parts]
Faro Delantero / Head Light
Cola Luz / Rear Lamp
Intermitente Lampara / Winker Lamp
Luz Matricula / License Lamp
Instalacion Electrica (Cuerpo) / Electrical Wiring (Body)
Embrague / Clutch
Embrague Varilla / Clutch Rod
Adelante Bastidor / Front Frame
Rueda Delantera (4.50-10) / Front Wheel (4.50-10)
Rueda Delantera (5-12) / Front Wheel (5-12)
Rueda Delantera (20*8.00-10) / Front Wheel (20*8.00-10)
Rueda Delantera (20.5*8.00-10) / Front Wheel (20.5*8.00-10)
Rueda Delantera (6-12) / Front Wheel (6-12)
Adelante Eje Caja / Front Axle Case
Eje Impulsor De La Rueda Delantera / Front Wheel Drive Shaft
Embrague Eje / Clutch Shaft
Pto Eje / Pto Shaft
Tdf Intermedia / Mid Pto
Gama Engranaje / Range Gear
Adelante Rueda Helice Eje / Front Propeller Shaft
Primero Eje / 1st Shaft
Segundo Eje / 2nd Shaft
Tercero Eje / 3rd Shaft
Tdf Engranaje Cambio Bifurcacion / Pto Gear Shift Fork
Horquilla Diferencial / Rear Differential Lock Shift Fork
Rueda Trasera (7-16) / Rear Wheel (7-16)
Rueda Trasera (8-16) / Rear Wheel (8-16)
Rueda Trasera (215/80d-15) / Rear Wheel (215/80d-15)
Rueda Trasera (29*12.00-15) / Rear Wheel (29*12.00-15)
Rueda Trasera (9.5-18) / Rear Wheel (9.5-18)
Freno / Brake
Freno Varilla / Brake Rod
Control Palanca / Hydraulic Control Lever
Mangueta Brazo / Knuckle Arm
Vinculo,Arrastre / Link,Drag
Atar Varilla / Tie Rod
Direccion / Steering
Hidraulico Bomba (Potencia Direccion) / Hydraulic Pump (Ps)
Hidraulico Bomba (Potencia Direccion) [Componente Piezas] / Hydraulic Pump (Ps) [Component Parts]
Hidraulico Aceite Linea (Aspiracion) / Hydraulic Pipe (Suction)
Hidraulico Cilindro (Ascensor) / Hydraulic Cylinder
Cambio Valvula [Componente Piezas] [Opcion] / Change Valve [Component Parts]
Hidraulico Piston/Ascenzo Brazo / Hydraulic Lift Arm
Distribuidor / Control Valve
3-Punto Varillaje (Ascenso Varilla) / Lift Rod
Bajar Vinculo / Lower Link
Trasero Enganche / Rear Hitch
Tdf Protector / Pto Protector
Capo / Hood (Bonnet)
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Guardabarros / Fender
Peldano / Step
Cola Cubierta / Tail Cover
Trasero Cubierta / Rear Cover
Arco De Seguridad / Rops
Etiquetas / Labels
Hoja [Opcion] / Seat [Option]
Kit De Faro De Labor [Opcion] / Working Light Kit [Option]
Adelante Enganche Kit[Opcion] / Front Hitch Kit [Option]
Trasero Enganche Kit [Opcion] / Rear Hitch Kit [Option]
Barra De Remolque Kit Adelante [Opcion] / Drawbar Kit [Option]
Rueda Peso [Opcion] / Front Weight Kit [Option]
