Kubota Tractor B1121D Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota B1121D Tractor
Number of Pages: 253 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Dipstick And Guide
Aceite Bomba / Oil Pump
Piston Y Cigueenal / Piston/Crankshaft
Volante / Flywheel
Combustible Bomba (Mecanico) / Fuel Pump (Mechanical)
Agua Bomba / Water Pump
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Palanca Acelerador / Hand Accelerator Lever
Ventilador / Fan
Agua Tubo / Water Pipe
Dinamo / Dynamo
Dinamo [Componente Piezas] / Dynamo [Component Parts]
Motor De Arranque / Starter
Conmutador / Cab Inner Switch
Conmutador/Rele / Relay
Tablero De Instrumentos Y Interruptor / Panel Board/Switch
Tablero De Instrumentos [Componente Piezas] / Panel [Component Parts]
Faro Delantero / Head Light
Instalacion Electrica (Cuerpo) / Electrical Wiring (Body)
Embrague / Clutch
Embrague Varilla / Clutch Rod
Adelante Bastidor / Front Frame
Embrague Eje / Clutch Shaft
Pto Eje / Pto Shaft
Gama Engranaje / Range Gear
Adelante Rueda Helice Eje / Front Propeller Shaft
Primero Eje / 1st Shaft
Segundo Eje / 2nd Shaft
Tercero Eje / 3rd Shaft
Tdf Engranaje Cambio Bifurcacion / Pto Gear Shift Fork
Horquilla Diferencial / Rear Differential Lock Shift Fork
Control Palanca / Hydraulic Control Lever
Freno Pedal / Brake Pedal
Trasero Eje / Rear Axle
Rueda Trasera (7-16) / Rear Wheel (7-16)
Rueda Trasera (8-16) / Rear Wheel (8-16)
Freno / Brake
Freno Varilla / Brake Rod
Rueda Delantera (4,50-10) / Front Wheel (4.50-10)
Rueda Delantera (5-12) / Front Wheel (5-12)
Adelante Eje Caja / Front Axle Case
Eje Impulsor De La Rueda Delantera / Front Wheel Drive Shaft
Mangueta Brazo / Knuckle Arm
Vinculo,Arrastre / Link,Drag
Atar Varilla / Tie Rod
Direccion / Steering
Hidraulico Aceite Linea (Aspiracion) / Hydraulic Pipe (Suction)
Hidraulico Cilindro (Ascensor) / Hydraulic Cylinder
Cambio Valvula [Componente Piezas] [Opcion] / Hydraulic Valve [Component Parts]
Hidraulico Piston/Ascenzo Brazo / Hydraulic Lift Arm
Distribuidor / Control Valve
3-Punto Varillaje (Ascenso Varilla) / Lift Rod
Bajar Vinculo / Lower Link
Trasero Enganche / Rear Hitch
Capo / Hood (Bonnet)
Panel Cubierta / Panel Cover
Lado Cubierta / Side Cover
Guardabarros / Fender
Peldano / Step
Cola Cubierta / Tail Cover
Etiquetas / Labels
Kit De Faro De Labor [Opcion] / Working Light Kit [Option]
Adelante Enganche Kit[Opcion] / Front Hitch Kit [Option]
