Kubota Ride-On Mower T1880EU Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Ride-On Mower
Model: Kubota T1880EU Ride-On Mower
Number of Pages: 115 Pages
Bloque Motor Y Piston (T1880 No.S.<=11018) / Crankcase And Piston (T1880 S.No.<=11018)
Bloque Motor Y Piston (T1880 No.S.>=11019) / Crankcase And Piston (T1880 S.No.>=11019)
Carter (T1880 No.S.<=11018) / Oil Pan (T1880 S.No.<=11018)
Carter (T1880 No.S.>=11019) / Oil Pan (T1880 S.No.>=11019)
Cilindro Ppal (T1880 No.S.<=11018) / Cylinder Head (T1880 S.No.<=11018)
Cilindro Ppal (T1880 No.S.>=11019) / Cylinder Head (T1880 S.No.>=11019)
Ciguenal (T1880 No.S.<=11018) / Crankshaft (T1880 S.No.<=11018)
Ciguenal (T1880 No.S.>=11019) / Crankshaft (T1880 S.No.>=11019)
Volante (T1880 No.S.<=11018) / Flywheel (T1880 S.No.<=11018)
Volante (T1880 No.S.>=11019) / Flywheel (T1880 S.No.>=11019)
Carburador (T1880 No.S.<=11018) / Carburetor (T1880 S.No.<=11018)
Carburador (T1880 No.S.>=11019) / Carburetor (T1880 S.No.>=11019)
Placa Control De Velocidad (T1880 No.S.<=11018) / Speed Control Plate (T1880 S.No.<=11018)
Placa Control De Velocidad (T1880 No.S.>=11019) / Speed Control Plate (T1880 S.No.>=11019)
Motor De Arranque (T1880 No.S.<=11018) / Starter (T1880 S.No.<=11018)
Motor De Arranque (T1880 No.S.>=11019) / Starter (T1880 S.No.>=11019)
Ventilador Cubierta (T1880 No.S.<=11018) / Fan Cover (T1880 S.No.<=11018)
Ventilador Cubierta (T1880 No.S.>=11019) / Fan Cover (T1880 S.No.>=11019)
Filtro De Aire (T1880 No.S.<=11018) / Air Cleaner (T1880 S.No.<=11018)
Filtro De Aire (T1880 No.S.>=11019) / Air Cleaner (T1880 S.No.>=11019)
Escape Piezas (T1880 No.S.<=11018) / Exhaust Parts (T1880 S.No.<=11018)
Escape Piezas (T1880 No.S.>=11019) / Exhaust Parts (T1880 S.No.>=11019)
Etiqueta,Motor (T1880 No.S.<=11018) / Label (Engine) (T1880 S.No.<=11018)
Etiqueta,Motor (T1880 No.S.>=11019) / Label (Engine) (T1880 S.No.>=11019)
Junta Kit [Opcion] (T1880 No.S.<=11018) / Gasket Kit [Option] (T1880 S.No.<=11018)
Junta Kit [Opcion] (T1880 No.S.>=11019) / Gasket Kit [Option] (T1880 S.No.>=11019)
Silenciador / Muffler
Instrumento Electrico / Electrical Parts
Cableado Eléctrico / Electrical Wiring
Hst
Hst [Componente Piezas 1] / Hst [Component Parts 1]
Hst [Componente Piezas 2] / Hst [Component Parts 2]
Hst [Componente Piezas 3] / Hst [Component Parts 3]
Hst [Componente Piezas 4] / Hst [Component Parts 4]
Hst [Componente Piezas 5] / Hst [Component Parts 5]
Rueda Posterior / Rear Wheel
Freno Varilla / Brake Rod
Pto Embrague Control Palanca/Cable / Pto Clutch Control Lever/Wire
Rueda Delantera / Front Wheel
Direccion Asistida 1 / Steering
Ascenso Vinculo / Lift Link
Capo(Capo) / Hood (Bonnet)
Tablero Panel / Panel Board
Guardabarros / Fender
Hoja / Seat
Etiquetas / Label
Accesorios / Accessories
Hst
Hoja / Seat
Etiquetas / Label
