Kubota Ride-On Mower T1870 10001- Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Ride-On Mower
Model: Kubota T1870 Ride-On Mower
Serial Number: 10001-
Number of Pages: 112 Pages
Girar Caja Y Cilindro Culata / Crank Case And Cylinder Head
Aceite Filtro / Oil Filter
Volante / Flywheel
Carburador(Componente Piezas) / Caburettor(Component Parts)
Velocidad Control Palanca / Speed Control Lever
Combustible Bomba(Electrico) / Fuel Pump (Electrical)
Motor De Arranque(Componente Piezas) / Starter (Component Parts)
Ventilador Cubierta / Fan Cover
Aire Limpiador / Air Cleaner
Etiqueta Y Operadores Manual / Label
Silenciador / Muffler
Electrico Piezas / Electrical Parts
Hst
Hst
Hst(Componente Piezas) / Hst (Component Parts)
Trasero Rueda / Rear Wheel
Freno Varilla / Brake Rod
Pto Embrague Control Palanca/Cable / Pto Clutch Control Lever/Wire
Adelante Rueda / Front Wheel
Principal Bastidor/Direccion Soporte / Main Frame/Steering Support
Hst Ventilador Cubierta / Hst Fan Cover
Potencia Direccion/Direccion Maneta / Power Steering/Steering Handle
Ascenso Vinculo / Lift Link
Capo(Capo) / Hood (Bonnet)
Panel Cubierta / Panel Cover
Guardabarros / Fender
Hoja / Seat
Hoja / Seat
Etiqueta / Label
Etiqueta / Label
