Kubota Ride-On Mower T1400H-UK Europe Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Ride-On Mower
Model: Kubota T1400H-UK Europe Ride-On Mower
Number of Pages: 151 Pages
Bloque Motor / Crankcase
Piston/Crankshaft / Piston/Crankshaft
Camshaft
Rocker Arm
Breather
Silenciador / Muffler
Carburettor
Carburettor [Component Parts]
Magneto
Balancer Shaft
Oil Filter
Ventilador Cubierta / Fan Cover
Placa De Control De Velocidad / Speed Control Plate
Motor De Arranque [Componentes] / Starter [Component Parts]
Aire Limpiador / Air Cleaner
Light
Dashboard
Wire Harness
Hst/Bevel Gear Shaft / Hst/Bevel Gear Shaft
Hst
Hst [Component Parts]
Differential Case
Tension Pulley
Speed Change Pedal
Speed Change Arm
Speed Change Arm
Eje Trasero / Rear Axle
Rear Axle Flange
Adelante Eje / Front Axle
Rear Wheel(18x8.50-8)/Front Wheel(14x5.00-6) / Rear Wheel(18x8.50-8)/Front Wheel(14x5.00-6)
Freno Pedal / Brake Pedal
Brake Rod
Brake Rod
Brake Rod
Blake
Steering
Lift Lever
Lift Link
Mower Link
Hood
Light
Panel
Fender
Frame
Step Seat
Hoja / Seat
Label
Camshaft
Rocker Arm
Breather
Carburettor
Magneto
Balancer Shaft
Oil Filter
Light
Dashboard
Wire Harness
Hst
Differential Case
Tension Pulley
Speed Change Pedal
Speed Change Arm
Speed Change Arm
Rear Axle Flange
Brake Rod
Brake Rod
Brake Rod
Blake
Steering
Lift Lever
Lift Link
Mower Link
Hood
Light
Panel
Fender
Frame
Step Seat
Hoja / Seat
Label
