Kubota Ride-On Mower GZD21-2HD Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Ride-On Mower
Model: Kubota GZD21-2HD Ride-On Mower
Number of Pages: 267 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Aceite Bomba / Oil Pump
Volante / Flywheel
Regulador [Antiguo] / Governor [Old]
Regulador [Nuevo] / Governor [New]
Speed Control Plate
Cubierta / Cover
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo / Inlet Pipe
Silenciador / Muffler
Combustible Bomba / Fuel Pump
Ventilador / Fan
Agua Tubo (Motor) / Water Pipe (Engine)
Agua Tubo (Radiador) / Water Pipe (Radiator)
A Prueba De Polvo Placa / Dustproof Plate
Dinamo / Dynamo
Dinamo [Componente Piezas] / Dynamo [Component Parts]
Motor De Arranque / Starter
Conmutador / Switch
Interruptor Arranque/Metro / Starter Switch/Meter
Interruptor/Controlador / Switch/Controller
Claxon/Rele / Horn/Relay
Embrague / Clutch
Respiradero De La Transmisión / Transmission Breather
Trasero Eje Caja (Derecho) / Rear Axle Case (Right)
Trasero Eje Caja (Izquierdo) / Rear Axle Case (Left)
Soporte De La Caja Del Eje Trasero / Rear Axle Case Support
Hst
Hst Derecho (Cilindro Bloque) [Componente Piezas] / Hst Rh (Cylinder Block) [Component Parts]
Hst Derecho (Cubierta) [Componente Piezas] / Hst Rh (Housing) [Component Parts]
Hst Izquierdo (Cilindro Bloque) [Componente Piezas] / Hst Lh (Cylinder Block) [Component Parts]
Hst Izquierdo (Cubierta) [Componente Piezas] / Hst Lh (Housing) [Component Parts]
Embrague Eje / Clutch Shaft
Eje De Entrada / Input Shaft
Universal Junta (Entrada) / Universal Joint (Input)
Eje De Junta / Joint Shaft
Pto Arbol Contrarrotante / Pto Countershaft
Pto Eje / Pto Shaft
Trasero Eje (Derecho) / Rear Axle (Right)
Trasero Eje (Izquierdo) / Rear Axle (Left)
Eje De La Tracción Trasera (Derecho) / Rear Wheel Drive Shaft (Right)
Eje De La Tracción Trasera (Izquierdo) / Rear Wheel Drive Shaft (Left)
Freno / Brake
Brazo Del Freno / Brake Arm
Estcnmnt Frn Pedal / Parking Brake Pedal
Palanca De Control (Derecho) / Motion Control Lever (Right)
Palanca De Control (Izquierdo) / Motion Control Lever (Left)
Velocidad Control Varilla / Speed Control Rod
Adelante Eje / Front Axle
Linea De Aceite Hidraulico(Impulsion) / Hydraulic Oil Line (Delivery)
Hidraulico Aceite Linea (Respiradero) / Hydraulic Oil Line (Breather)
Hidraulico Aceite Linea (Radiador De Aceite) / Hydraulic Oil Line (Oil Cooler)
Ascenso Brazo / Lift Arm
Ascenso Cilindro [Componente Piezas] / Lift Cylinder [Component Parts]
Cortacespedes Ascenso Brazo / Mower Lift Arm
Articulacion De Segadora (Centro) / Mower Link (Center)
Articulacion De Segadora (Derecho) / Mower Link (Right)
Articulacion De Segadora (Izquierdo) / Mower Link (Left)
Cortacespedes Salto Palanca / Mower Jump Lever
Conducto / Duct
Peso / Weight
Eje Cubierta / Shaft Cover
Adelante Protector / Front Guard
Capo Superior / Hood (Bonnet) Upper
Lado Cubierta Bajar / Side Cover Lower
Guardabarros / Fender
Cinturón Del Asiento / Seat Belt
Hoja / Seat
Peldano / Step
Arco De Seguridad / Rops
Rueda Delantera (15*6,00-6) / Front Wheel (15*6.00-6)
Rueda Trasera (23*10,5-12) / Rear Wheel (23*10.5-12)
Accesorios / Accessories
Peso Kit [Opcion] / Weight Kit [Option]
