Martin Welker
104
230,792
Kubota Mowers Z232KW-AU Workshop Manual 9Y111-27600
Type of Machine: Mowers
Type Of Manual: Workshop Manual
Model: Kubota Z232KW-AU Mowers
Parts Number: 9Y111-27600
Publication Date: 2023
Number Of Page: 203 Pages
1 Safety
Safety First
1 Preparing For Emergencies
2 Working Cautions
3 Starting Machine Safely
4 Preventing Fires
5 Preventing Acid Burns
6 Avoiding High Pressure Fluid
7 Avoiding Hot Exhaust
8 Cleaning Exhaust Filter
Safe Operation
1 Before Operating The Machine
2 Operating The Machine
3 Transporting The Machine
4 Servicing And Storage
Safety Labels
1 Care Of Danger, Warning And Caution Labels
2 General
General Working Instructions
1 General Working Precautions
2 Tightening Bolts And Nuts
3 Applying Thread-Locking Fluid
4 Installing Circlips
5 Installing Spring Pins
6 Handling Split Pin
7 Handling Chain Joint And Split Pin
8 Handling Liquid Gasket
9 Replacing O-Rings
10 Replacing Oil Seals
11 Replacing Floating Seals
12 Connecting Hydraulic Hoses
13 Wrapping Thread Seal Tape
14 Installing Elbows With Male Seat
15 Connecting And Disconnecting Quick Hose Couplings
16 Handling The Battery
17 Handling Wire Harness
18 Handling Fuses
19 Handling Connectors
20 Wirina Color
21 Washing The Machine With A High Pressure Washer
22 Dispose Fluids Correctly
23 Checking Hoses
Tightening Torques
1 General Use Screws, Bolts And Nuts
2 Stud Bolts
3 Hydraulic Fitting
4 Metric Screws, Bolts And Nuts
5 American Standard Screws, Bolts And Nuts With Unc Or Unf Threads
6 Plugs
General Machine Information
I Machine Identification
2 Specifications
3 Dimensions
4 Tires And Wheels
5 Implement Limitations
Special Tools
1 Special Tools For Machine
3 Maintenance
Service Intervals
Lubricants And Fuel
Check And Maintenance
I Daily Check
2 Every 50 Hours
3 Every 100 Hours
4 Every 200 Hours
5 Every 300 Hours
6 Eve
1 Ear
7 Every 4 Years
8 Service As Required
4 Engine
Mechanism
1 Structure Of Engine
2 Fuel System
3 Lubrication System
4 Cooling System
Servicing
I Troubleshooting For Engine
2 Service Specifications For Engine
3 Tightening Torques For Engine
4 Checking And Adjusting
5 Disassembling And Assembling
5 Transaxle
Mechanism
1 Function Of Transaxle
2 Hydraulic Circuit Of Transaxle
3 Structure Of Transaxle
4 Transaxle External Components
5 Transaxle Specification
6 Parking Brake
Servicing
1 Troubleshooting For Transaxle
2 Service Specifications For Transaxle
3 Tightening Torques For Transaxle
6 Front Axle
Mechanism
1 Structure Of Front Axle
Servicing
7 Lift System
Mechanism
1 Structure Of Lift System
Servicing
I Troubleshooting For Lift System
2 Tightening Torques For Lift System
3 Disassembling And Assembling
8 Electrical System
Mechanism
I Starting System
2 Gauge
3 Hour Meter
4 Pto Clutch
5 Pto Switch
Servicing
1 Troubleshooting For Electrical System
2 Service Specifications For Electrical System
3 Checking And Adjusting
9 Mower
Mechanism
1 Structure Of Mower
2 Power Transmission Flow For Mower
Servicing
1 Troubleshooting For Mower
2 Service Specifications For Mower
3 Tightening Torques For Mower
