Kubota Mower ZD28F Australia Parts Catalog
Type of Machine: Mower
Model: Kubota ZD28F Mower
Region: Australia
Number of Pages: 312 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crank Case ## Note_Order By Ref.No.010(16613-0101-8),230 & 240 [Set]
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover ## S.No._=3z9999 [D1105-E-ZD]
Engine _ Head Cover ## S.No._=4a0001 [D1105-E2-ZD]
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft ## S.No._=2x9999 S.No.;_=2x9999
Engine _ Piston And Crankshaft ## S.No.2y0001 To 7t9999 S.No.;2y0001 To 7t9999
Engine _ Piston And Crankshaft ## S.No._=7u0001 S.No.;_=7u0001
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Idle Apparatus
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Platec
Engine _ Nozzle Holder [Component Parts]
Engine _ Cover
Engine _ Dynamo And Pulley
Engine _ Dynamo [Component Parts]
Engine _ Starter
Engine _ Starter [Component Parts]
Engine _ Oil Switch And Thermometer
Engine _ Water Pump
Engine _ Fan
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold ## S.No._=3z9999 [D1105-E-ZD]
Engine _ Inlet Manifold ## S.No._=4a0001 [D1105-E2-ZD]
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Upper Gasket Kit [Option]
Engine _ Lower Gasket Kit [Option]
Engine _ Accelerator Lever
Fuel System _ Fuel Tank
Fuel System _ Fuel Pipe
Cooling Water System _ Water Pipe
Cooling Water System _ Radiator
Cooling Water System _ Dust Proof Plate
Cooling Water System _ Reserve Tank
Electrical System _ Battery
Electrical System _ Switch_Sensor
Electrical System _ Switch_Controller
Clutch_Transmission_Rear Axle _ Clutch ## S.No._=59999 S.No.;_=59999
Clutch_Transmission_Rear Axle _ Clutch ## S.No._=60001 S.No.;_=60001
Clutch_Transmission_Rear Axle _ Transmission Case
Clutch_Transmission_Rear Axle _ Charge Pump Case ## S.No._=59999 S.No.;_=59999
Clutch_Transmission_Rear Axle _ Charge Pump Case [Option] ## S.No._=59999 S.No.;_=59999
Clutch_Transmission_Rear Axle _ Charge Pump Case ## S.No._=60001 S.No.;_=60001
Clutch_Transmission_Rear Axle _ Rear Axle Case Rh
Clutch_Transmission_Rear Axle _ Rear Axle Case Lh
Clutch_Transmission_Rear Axle _ HST
Clutch_Transmission_Rear Axle _ HST Rh 1 [Component Parts]
Clutch_Transmission_Rear Axle _ HST Rh 2 [Component Parts]
Clutch_Transmission_Rear Axle _ HST Lh 1 [Component Parts]
Clutch_Transmission_Rear Axle _ HST Lh 2 [Component Parts]
Clutch_Transmission_Rear Axle _ Clutch Shaft
Clutch_Transmission_Rear Axle _ Input Shaft
Clutch_Transmission_Rear Axle _ Universal Joint_Fan
Clutch_Transmission_Rear Axle _ Joint Shaft
Brake_Speed Change Lever _ Brake Shaft
Brake_Speed Change Lever _ Brake Rh
Brake_Speed Change Lever _ Brake Lh
Brake_Speed Change Lever _ Brake Rod
Brake_Speed Change Lever _ Hand Brake
Brake_Speed Change Lever _ PTO Gear Shift Lever
Brake_Speed Change Lever _ Speed Control Lever Rh
Brake_Speed Change Lever _ Speed Control Lever Lh
Brake_Speed Change Lever _ Speed Control Rod 1
Brake_Speed Change Lever _ Speed Control Rod 2
Brake_Speed Change Lever _ Parking Brake Pedal
Front Axle _ Front Axle
Hydraulic System _ Hydraulic Oil Line (Suction)
Hydraulic System _ Hydraulic Oil Line (Delivery)
Hydraulic System _ Hydraulic Oil Line (PTO)
Hydraulic System _ Hydraulic Pipe (HST)
Hydraulic System _ Hydraulic Oil Line (Oil Cooler)
Hydraulic System _ Lift Lever
Hydraulic System _ Control Valve
Hydraulic System _ Control Valve [Component Parts] ## S.No._=63126 S.No.;_=63126
Hydraulic System _ Control Valve [Component Parts] ## S.No._=63127 S.No.;_=63127
Hydraulic System _ Lift Cylinder
Hydraulic System _ Mower Lift Arm
Main Frame _ Main Frame ## Note_Order By Ref.No.010(K3151-2101-9) & Fig.No.M225 Ref.No
Main Frame _ Upper Frame
Main Frame _ Engine Support
Main Frame _ Adjuster Handle
Main Frame _ Lift Up Adjuster
Hood_Bonnet _ Front Mask
Hood_Bonnet _ Hood (Bonnet)
Hood_Bonnet _ Fender
Hood_Bonnet _ Seat
Hood_Bonnet _ Seat Suspension 1 [Component Parts] ## S.No._=25049 S.No.;_=25049
Hood_Bonnet _ Seat Suspension 1 [Component Parts] ## S.No._=25050 S.No.;_=25050
Hood_Bonnet _ Seat Suspension 2 [Component Parts]
Hood_Bonnet _ Step
Hood_Bonnet _ Rops
Front & Rear Gauge Wheel _ Front Wheel (15_6.00-6)
Front & Rear Gauge Wheel _ Rear Wheel (242.00-12)
Labels _ Label(Front)
Labels _ Label(Rear)
Accessories And Service Parts _ Accessories
Option _ Weight Kit [Option]
Option _ Horn Kit [Option]
Option _ Axle Kit [Option]
Option _ Oil Reserve Tank [Option]
Option _ Rops Kit 1 [Option]
Option _ Rops Kit 2 [Option]
