Kubota Mower ZD21F Australia Parts Catalog
Type of Machine: Mower
Model: Kubota ZD21F Mower
Region: Australia
Number of Pages: 305 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover ## S.No._=4z9999
Engine _ Head Cover ## S.No.;_=5a0001
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Oil Pump
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft ## Note_Order By Ref.No.010 New Part And Fig.No.060002 Ref.No
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Idle Apparatus
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate ## S.No.;_=1e8947
Engine _ Speed Control Plate ## S.No.;_=1g0001
Engine _ Nozzle Holder [Component Parts]
Engine _ Cover
Engine _ Oil Switch_Thermometer And Plug
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Valve And Rocker Arm ## S.No.;_=4z9999
Engine _ Valve And Rocker Arm ## S.No.;_=5a0001
Engine _ Inlet Manifold ## S.No.;_=4z9999
Engine _ Inlet Manifold ## S.No.;_=5a0001
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Upper Gasket Kit [Option] ## S.No.;_=4z9999
Engine _ Upper Gasket Kit [Option] ## S.No.;_=5a0001
Engine _ Lower Gasket Kit [Option]
Engine _ Accelerator Lever
Fuel System _ Fuel Tank
Fuel System _ Fuel Pipe
Cooling Water System _ Fan
Cooling Water System _ Water Pipe
Cooling Water System _ Radiator
Cooling Water System _ Dust Proof Plate
Cooling Water System _ Reserve Tank
Electrical System _ Dynamo
Electrical System _ Dynamo [Component Parts]
Electrical System _ Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Battery ## Note_Order By Fig.No.P10302 Ref.No.115
Electrical System _ Switch_Sensor
Electrical System _ Switch_Controller
Clutch _ Clutch ## S.No._=59253
Clutch _ Clutch ## S.No._=59254
Transmission _ Transmission Case
Transmission _ Charge Pump Case ## S.No._=59253
Transmission _ Charge Pump Case [Option] ## S.No._=59253
Transmission _ Charge Pump Case ## S.No._=59254
Transmission _ Rear Axle Case Rh
Transmission _ Rear Axle Case Lh
Transmission _ HST
Transmission _ HST Rh 1 [Component Parts]
Transmission _ HST Rh 2 [Component Parts]
Transmission _ HST Lh 1 [Component Parts]
Transmission _ HST Lh 2 [Component Parts]
Transmission _ Clutch Shaft ## S.No._=59253
Transmission _ Clutch Shaft ## S.No._=59254
Transmission _ Input Shaft ## S.No._=59253
Transmission _ Input Shaft ## S.No._=59254
Transmission _ Universal Joint_Fan
Transmission _ Joint Shaft
Rear Axle _ Rear Axle
Brake _ Brake Shaft
Brake _ Brake Rh
Brake _ Brake Lh
Brake _ Brake Rod
Brake _ Hand Brake
Brake _ Parking Brake Pedal
Speed Change _ PTO Gear Shift Lever
Speed Change _ Speed Control Lever Rh
Speed Change _ Speed Control Lever Lh
Speed Change _ Speed Control Rod 1
Speed Change _ Speed Control Rod 2
Front Axle _ Front Axle
Pump_Motor System _ Hydraulic Oil Line (Suction)
Pump_Motor System _ Hydraulic Oil Line (Delivery)
Pump_Motor System _ PTO Hydraulic Oil Line
Pump_Motor System _ Hydraulic Pipe (HST)
Pump_Motor System _ Lift Lever
Pump_Motor System _ Control Valve
Pump_Motor System _ Control Valve [Component Parts] ## S.No._=63839
Pump_Motor System _ Control Valve [Component Parts] ## S.No._=63840
Pump_Motor System _ Lift Cylinder
Pump_Motor System _ Mower Lift Arm
Chassis _ Main Frame
Chassis _ Upper Frame ## S.No._=48263
Chassis _ Upper Frame ## S.No._=48264
Chassis _ Engine Support
Chassis _ Adjuster Handle
Chassis _ Lift Up Adjuster
Hood_Bonnet _ Front Mask
Hood_Bonnet _ Hood (Bonnet) ## Note_Order By Fig.No.P10302 Ref.No.030
Hood_Bonnet _ Fender ## Note1_Order By Fig.No.P10202 Ref.No.135, Note2_Order By Fig.No
Hood_Bonnet _ Seat
Hood_Bonnet _ Seat Suspension 1 [Component Parts]
Hood_Bonnet _ Seat Suspension 2 [Component Parts]
Hood_Bonnet _ Step
Rops _ Rops
Front Tire _ Front Wheel (15_6.00-6)
Rear Tire _ Rear Wheel (242.00-12)
Labels _ Label (Front) [English]
Labels _ Label (Front) [French] ## Note_Order By Fig.No.P10201 Ref.No.080
Labels _ Label (Rear) [English] ## Note_Order By Fig.No.P10303 Ref.No.030
Labels _ Label (Rear) [French] ## Note_Order By Fig.No.P10301 Ref.No.030
Accessories And Service Parts _ Accessories
Option _ Horn Kit [Option]
Option _ Axle Kit [Option] ## S.No._=56677
Option _ Oil Reserve Tank [Option]
Region: Australia
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Oil Filter
Engine _ Oil Pump
Engine _ Flywheel
Engine _ Governor
Engine _ Cover
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Muffler
Transmission _ HST
Brake _ Brake Shaft
Brake _ Brake Rh
Brake _ Brake Lh
Brake _ Brake Rod
Brake _ Hand Brake
Hood_Bonnet _ Seat
Hood_Bonnet _ Step
Rops _ Rops
