Kubota Mower GZD15-IILD Australia Parts Catalog
Type of Machine: Mower
Model: Kubota GZD15-IILD Mower
Region: Australia
Number of Pages: 257 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crank Case ## Note_Order By Ref.No.010 New Part And Ref.No.140 New Part.
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case ## Note_Order By Ref.No.010,100 New Parts And Fig.No.050100 Ref.No
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Oil Pump
Engine _ Main Bearing Case
10201 Piston And Crankshaft ## S.No._=Bbz999 [Note_Order By Ref.No.010 New Part And Fig.No
Engine _ Piston And Crankshaft ## S.No._=Bc0001 S.No.;_=Bc0001
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Idle Apparatus
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Nozzle Holder [Component Parts] ## S.No._=9hz999 S.No.;_=9hz999
Engine _ Nozzle Holder [Component Parts] ## S.No._=9j0001 S.No.;_=9j0001
Engine _ Cover
Engine _ Oil Switch_Thermometer
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Inlet Pipe (Air Cleaner)
Engine _ Muffler
Engine _ Upper Gasket Kit
Engine _ Lower Gasket Kit ## S.No._=7t5453 S.No.;_=7t5453
Engine _ Lower Gasket Kit ## S.No._=7u0001 S.No.;_=7u0001
Fuel System _ Accelerator Lever
Fuel System _ Fuel Tank
Fuel System _ Fuel Pipe
Cooling Water System _ Fan
Cooling Water System _ Water Pipe
Cooling Water System _ Radiator
Cooling Water System _ Dustproof Plate
Cooling Water System _ Reserve Tank
Electrical System _ Stop Solenoid
Electrical System _ Dynamo
Electrical System _ Dynamo [Component Parts]
Electrical System _ Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Battery
Electrical System _ Switch
Electrical System _ Switch_Controller
Electrical System _ Horn_Relay ## S.No._=60373 S.No.;_=60373
Electrical System _ Electrical Wiring (Body) ## S.No._=60372 S.No.;_=60372
Electrical System _ Electrical Wiring (Body) ## S.No._=60373 S.No.;_=60373
Clutch_Transmission _ Clutch
Clutch_Transmission _ Transmission Case
Clutch_Transmission _ Rear Axle Case Rh
Clutch_Transmission _ Rear Axle Case Lh
Clutch_Transmission _ HST
Clutch_Transmission _ HST Rh(Cylinder Block) [Component Parts]
Clutch_Transmission _ HST Rh(Housing) [Component Parts]
Clutch_Transmission _ HST Lh(Cylinder Block) [Component Parts]
Clutch_Transmission _ HST Lh(Housing) [Component Parts]
Clutch_Transmission _ Clutch Shaft
Clutch_Transmission _ Input Shaft
Clutch_Transmission _ Universal Joint(Input)
Clutch_Transmission _ Joint Shaft
Clutch_Transmission _ PTO Counter Shaft
Clutch_Transmission _ PTO Shaft
Clutch_Transmission _ Universal Joint(PTO)
Rear Axle _ Rear Axle
Brake _ Brake
Brake _ Parking Brake Pedal
Speed Change _ PTO Gear Shift Lever
Speed Change _ Speed Control Lever Rh
Speed Change _ Speed Control Lever Lh
Speed Change _ Speed Control Rod
Front Axle _ Front Axle
Hydraulic System _ Hydraulic Pump
Hydraulic System _ Hydraulic Pump [Component Parts]
Hydraulic System _ Hydraulic Oil Line(Suction)
Hydraulic System _ Hydraulic Oil Line(Delivery)
Hydraulic System _ Hydraulic Oil Line(Breather)
Hydraulic System _ Hydraulic Oil Line(Oil Cooler)
Hydraulic System _ Lift Arm
Hydraulic System _ Control Valve
Hydraulic System _ Lift Cylinder
Hydraulic System _ Lift Cylinder [Component Parts]
Hydraulic System _ Mower Lift Arm
Hydraulic System _ Mower Link(Center)
Hydraulic System _ Mower Link(Right)
Hydraulic System _ Mower Link(Left)
Hydraulic System _ Mower Jump Lever
Hydraulic System _ Duct
Chassis _ Weight
Chassis _ Main Frame ## Note_Order By Ref.No.010(K2011-2101-7)New Part
Chassis _ Engine Support ## S.No._=60372 S.No.;_=60372
Chassis _ Engine Support ## S.No._=60373 S.No.;_=60373
Bonnet _ Hood(Bonnet)
Bonnet _ Side Cover Lower
Bonnet _ Fender
Bonnet _ Seat Support
Bonnet _ Seat
Bonnet _ Step
Front Wheel_Rear Wheel _ Front Wheel(15_6.00-6)
Front Wheel_Rear Wheel _ Rear Wheel(200-8)
Labels _ Label(Front)
Labels _ Label(Rear)
Accessories _ Accessories
Option _ Weight Kit [Option]
