Kubota Mower GR1600EC2 Australia Parts Catalog
Type of Machine: Mower
Model: Kubota GR1600EC2 Mower
Region: Australia
Number of Pages: 201 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Cylinder Head ## [Z482-E2-GX]
Engine _ Cylinder Head ## [Z482-E3-GX]
Engine _ Gear Case ## Note_Order By Ref.No.010,050 And Fig.No.050102 Ref No
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Oil Pump
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Idle Apparatus
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Nozzle Holder [Component Parts] ## S.No._=9hz999 S.No.;_=9hz999
Engine _ Nozzle Holder [Component Parts] ## S.No._=9j0001 S.No.;_=9j0001
Engine _ Fuel Pump Cover
Engine _ Dynamo And Pulley
Engine _ Dynamo [Component Parts]
Engine _ Starter
Engine _ Starter [Component Parts]
Engine _ Oil Switch
Engine _ Water Pump ## S.No._=6b9999 S.No.;_=6b9999
Engine _ Water Pump ## S.No._=6c0001 S.No.;_=6c0001
Engine _ Water Pipe
Engine _ Fan
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Upper Gasket Kit [Option]
Engine _ Lower Gasket Kit [Option]
Fuel System _ Accelerator Lever
Fuel System _ Fuel Tank
Cooling Water System _ Water Pipe ## S.No._=49999 S.No.;_=49999
Cooling Water System _ Water Pipe ## S.No._=50001 S.No.;_=50001
Cooling Water System _ Radiator ## S.No._=49999 S.No.;_=49999
Cooling Water System _ Radiator ## S.No._=50001 S.No.;_=50001
Electrical System _ Battery
Electrical System _ Electrical Parts
Transmission _ Transmission Pipe
Transmission _ Clutch Shaft(Transmission) ## S.No._=33118 S.No.;_=33118
Transmission _ Clutch Shaft(Transmission) ## S.No._=33119 S.No.;_=33119
Transmission _ Input Shaft(Transmission)
Transmission _ HST
Transmission _ HST [Component Parts]
Transmission _ Universal Joint_HST Fan
Rear Axle _ Rear Differential(Transmission)
Rear Axle _ Rear Axle
Rear Wheel _ Rear Wheel (200.0-8)
Brake _ Brake
Brake _ Parking Brake Lever
Brake _ Brake Rod
Speed Change _ Cruise Control [Option]
Speed Change _ Speed Change Pedal
Speed Change _ PTO Clutch Control Lever
Front Axle _ Front Axle
Front Wheel _ Front Wheel (15_6.00-6)
Chassis _ Main Frame_Steering Support ## S.No._=34229 S.No.;_=34229
Chassis _ Main Frame_Steering Support ## S.No._=34230 S.No.;_=34230
Chassis _ Main Frame_Cover [Fr]
Chassis _ Engine Support
Chassis _ Engine Support 1 [Fr]
Chassis _ Engine Support 2 [Fr]
Steering _ Steering Handle
Hydraulic System _ Control Valve
Hydraulic System _ Lift Link
Hood_Bonnet _ Hood(Bonnet)
Hood_Bonnet _ Panel
Hood_Bonnet _ Fender
Hood_Bonnet _ Seat
Labels _ Label
Option _ Safety Cover Kit 1 [Option]
Option _ Safety Cover Kit 2 [Option]
Accessories _ Accessories
Region: Australia
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Oil Pump
Engine _ Flywheel
Engine _ Governor
Engine _ Starter
Engine _ Oil Switch
Engine _ Water Pipe
Engine _ Fan
Engine _ Muffler
Transmission _ HST
Brake _ Brake
Brake _ Brake Rod
Hood_Bonnet _ Panel
Hood_Bonnet _ Seat
Labels _ Label
