702,019
Kubota Mower G5200H Australia Parts Catalog
Type of Machine: Mower
Model: Kubota G5200H Mower
Region: Australia
Number of Pages: 153 Pages
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Main Bearing Case
Engine _ Cylinder Head Cover
Engine _ Manifold
Engine _ Valve_Rocker Arm
Engine _ Camshaft
Engine _ Piston_Crankshaft
Engine _ Flywheel
Engine _ Nozzle Holder
Engine _ Injection Pump
Engine _ Idling Apparatus
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Dynamo
Engine _ Water Flange
Engine _ Water Pump
Engine _ Nozzle Holder (Section Parts)
Engine _ Injection Pump (Section Parts)
Engine _ Dynamo (Section Parts)
Engine _ Muffler
Engine _ Air Cleaner
Engine _ Exhaust Pipe Kit (Option)
Hydraulic System _ Hydraulic Outlet (Option)
Hydraulic System _ Aux Control Valve (Option)
Hydraulic System _ 3-Point Linkage (Option)
Hydraulic System _ Hydraulic Lift (Option)
Hydraulic System _ Hydraulic Pipe
Mower Link_Drive Belt _ Rear PTO (Option)
Mower Link_Drive Belt _ Lift Lever
Mower Link_Drive Belt _ Lift Link
Transmission _ Transmission Case
Transmission _ Propeller Shaft
Transmission _ 4th Shaft
Transmission _ 5th Shaft
Transmission _ Differential
Transmission _ PTO Shaft
Transmission _ Tension Pulley
Transmission _ PTO Lever
Transmission _ H.S.T.
Rear Axle_Rear Wheel _ Rear Axle
Rear Axle_Rear Wheel _ Rear Wheel
Rear Axle_Rear Wheel _ Rear Wheel (23x10.50-12) Except U.S.A.
Brake _ Brake ## S.No.;_=32924
Brake _ Brake ## S.No.;_=32925
Brake _ Brake Pedal
Steering _ Steering
Speed Change _ Accel.Lever
Speed Change _ Speed Change Lever
Speed Change _ Engine Stop Wire
Bonnet_Hood_Chassis _ Seat ## S.No.;_=30000
Bonnet_Hood_Chassis _ Seat ## S.No.;_=30001
Bonnet_Hood_Chassis _ Frame
Bonnet_Hood_Chassis _ Fender
Bonnet_Hood_Chassis _ Panel Cover
Bonnet_Hood_Chassis _ Radiator Net
Bonnet_Hood_Chassis _ Hood
Bonnet_Hood_Chassis _ Seat Suspention Kit (Option) ## S.No.;_=30000
Labels _ Label
Cooling Water System _ Radiator
Fuel System _ Fuel Tank
Fuel System _ Fuel Pump
Fuel System _ Fuel Filter
Fuel System _ Fuel Pipe
Fuel System _ Fuel Filter (Section Parts)
Electrical System _ Electrical System
Electrical System _ Battery
Electrical System _ Starter
Electrical System _ Starter (Section Parts)
Electrical System _ COMBI.METER Kit (Option) ## S.No.;_=12548
Front Axle_Front Wheel _ Front Axle
Front Axle_Front Wheel _ Front Wheel
Front Axle_Front Wheel _ Front Wheel (16x6.50-8) Except U.S.A.
Accessories _ Accessories And Service Parts
