Kubota Mower G2460G Australia Parts Catalog
Type of Machine: Mower
Model: Kubota G2460G Mower
Region: Australia
Number of Pages: 228 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Oil Pump
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft
Engine _ Governor
Engine _ Caburettor
Engine _ Fork Lever
Engine _ Speed Control Lever
Engine _ Spark Plug And Distributor
Engine _ Distributor (Component Parts)
Engine _ Alternator And Pulley
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Oil Switch_Thermometer And Plug
Engine _ Water Pump ## S.No._=Yy8644
Engine _ Water Pump ## S.No._=1a0001
Engine _ Water Pump ## S.No._=6c0001
Engine _ Water Pipe
Engine _ Fan
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Gasket Kit
Fuel System _ Accelerator Lever
Fuel System _ Choke Wire
Fuel System _ Fuel Tank
Fuel System _ Fuel Pipe_Fuel Filter
Cooling Water System _ Water Pipe
Cooling Water System _ Radiator
Electrical System _ Battery ## Note_Order By Fig.No.G10002 Ref.No.470.
Electrical System _ Electrical Parts
Electrical System _ Head Light
Transmission _ Transmission Case
Transmission _ Brake Gear-Shaft_Idler Shaft
Transmission _ HST
Transmission _ HST [Component Parts]
Transmission _ Universal Joint_HST Fan
Transmission _ PTO Shaft
Transmission _ PTO Tension Pulley
Rear Axle _ Rear Differential
Rear Axle _ Rear Differential Shaft
Rear Axle _ Rear Axle Case
Rear Wheel _ Rear Wheel
Brake _ PTO Brake
Brake _ Brake
Brake _ Brake Pedal
Brake _ Parking Brake Lever
Brake _ Brake Rod
Speed Change _ Speed Change Pedal
Speed Change _ Speed Control Arm
Speed Change _ Hydraulic Control Lever
Speed Change _ PTO Clutch Control Lever_Wire
Speed Change _ PTO Wire Bracket
Front Axle _ Front Axle
Front Axle _ Main Frame_Steering Support
Front Axle _ Engine Support
Front Wheel _ Front Wheel
Steering _ Power Steering_Steering Handle
Hydraulic System _ Control Valve ## Note_Order By Ref.No
Hydraulic System _ Control Valve [Component Parts] ## S.No._=10061
Hydraulic System _ Control Valve [Component Parts] ## S.No._=10062
Hydraulic System _ Control Valve [Component Parts] ## S.No._=10835
Hydraulic System _ Hydraulic Oil Line (Suction)
Hydraulic System _ Hydraulic Oil Line(Breather)
Hydraulic System _ Hydraulic Oil Line(Drain)
Hydraulic System _ Hydraulic Lift Cylinder
Hydraulic System _ Lift Link
Top Link_Lower Link_Hitch _ Hitch
Hood_Bonnet _ Hood(Bonnet)
Hood_Bonnet _ Panel
Hood_Bonnet _ Fender
Hood_Bonnet _ Seat
Hood_Bonnet _ Seat Suspension
Labels _ Label [English]
Labels _ Label [French]
Accessories And Service Parts _ Accessories And Service Parts
Option _ Cruise Control Kit [Option]
Region: Australia
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Oil Pump
Engine _ Flywheel
Engine _ Governor
Engine _ Caburettor
Engine _ Fork Lever
Engine _ Starter
Engine _ Water Pipe
Engine _ Fan
Engine _ Muffler
Engine _ Gasket Kit
Transmission _ HST
Brake _ PTO Brake
Brake _ Brake
Brake _ Brake Pedal
Brake _ Brake Rod
Hood_Bonnet _ Panel
Hood_Bonnet _ Seat
