702,019
Kubota Mower G21LD Australia Parts Catalog
Type of Machine: Mower
Model: Kubota G21LD Mower
Region: Australia
Number of Pages: 242 Pages
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover ## S.No.;_=4x4026
Engine _ Head Cover ## S.No.;_=5a0001
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Oil Pump
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft ## Note_Order By Ref.No.010 New Part And Fig.No.060002 Ref.No
Engine _ Flywheel
Engine _ Fuel Camshaft
Engine _ Idle Apparatus
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Nozzle Holder [Component Parts]
Engine _ Fuel Pump Cover
Engine _ Oil Switch_Thermometer
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Valve And Rocker Arm ## S.No.;_=4x4026
Engine _ Valve And Rocker Arm ## S.No.;_=5a0001
Engine _ Inlet Manifold ## S.No.;_=4x4026
Engine _ Inlet Manifold ## S.No.;_=5a0001
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Muffler [FR]
Engine _ Upper Gasket Kit [Option] ## S.No.;_=4x4026
Engine _ Upper Gasket Kit [Option] ## S.No.;_=5a0001
Engine _ Lower Gasket Kit [Option]
Fuel System _ Accelerator Lever
Fuel System _ Fuel Tank
Fuel System _ Fuel Pipe_Fuel Filter
Cooling Water System _ Fan
Cooling Water System _ Water Pipe
Cooling Water System _ Radiator
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Battery
Electrical System _ Electrical Parts
Electrical System _ Head Light
Transmission _ Transmission Case
Transmission _ Brake Gear-Shaft_Idler Shaft
Transmission _ HST
Transmission _ HST 1 (Housing)
Transmission _ HST 2 (Plug)
Transmission _ HST 3 (Cylinder Block,Motor)
Transmission _ HST 4 (Cylinder Block,Pump)
Transmission _ Universal Joint_HST Fan
Transmission _ PTO Shaft
Transmission _ PTO Tension Pulley
Rear Axle _ Rear Differential
Rear Axle _ Rear Differential Shaft
Rear Axle _ Rear Axle Case
Rear Tire _ Rear Wheel (230.50-12)
Brake _ PTO Brake
Brake _ Brake
Brake _ Brake Pedal
Brake _ Brake Rod
Speed Change _ Speed Change Pedal
Speed Change _ Speed Control Arm
Speed Change _ Hydraulic Control Lever
Speed Change _ PTO Clutch Control Lever_Wire
Speed Change _ PTO Wire Bracket
FRont Axle _ FRont Axle
FRont Axle _ Main FRame_Steering Support
FRont Axle _ Main FRame_Steering Support [FR]
FRont Axle _ Engine Support
FRont Axle _ Engine Support [FR]
FRont Tire _ FRont Wheel (16_6.5-8)
Steering _ Power Steering_Steering Handle
Hydraulic System _ Control Valve
Hydraulic System _ Control Valve [Component Parts] ## S.No.;_=14771
Hydraulic System _ Control Valve [Component Parts] ## S.No.;_=14772
Hydraulic System _ Hydraulic Oil Line (Suction)
Hydraulic System _ Hydraulic Oil Line (Breather)
Hydraulic System _ Hydraulic Oil Line (Drain)
Hydraulic System _ Hydraulic Lift Cylinder
Hydraulic System _ Lift Link
Hood_Bonnet _ Hood (Bonnet)
Hood_Bonnet _ Hood(Bonnet) [FR]
Hood_Bonnet _ Panel
Hood_Bonnet _ Fender
Hood_Bonnet _ Seat ## S.No.;_=11130
Hood_Bonnet _ Seat ## S.No.;_=11131
Hood_Bonnet _ Seat Suspension
Labels _ Label
Labels _ Label [FR]
Accessories _ Accessories And Service Parts
Option _ Safety Cover Kit (Body FRont) [FR] [Option] ## S.No.;_=17538
Option _ Safety Cover Kit (Body FRont) [FR] [Option] ## S.No.;_=17539
Option _ Safety Cover Kit (Body Rear) [FR] [Option]
