Kubota Mower G2160 G2160-DS G2160AU Australia Parts Catalog
Type of Machine: Mower
Model: Kubota G2160 G2160-DS G2160AU Mower
Region: Australia
Number of Pages: 297 Pages
Frequently Used Items _ Frequently Used Items
Frequently Used Items _ Frequently Used Items [Sta]
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover ## S.No.;_=4z9999
Engine _ Head Cover ## S.No.;_=5a0001
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Oil Pump
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft ## S.No._=Bbz999 Note_Order By New Part And Fig.No
Engine _ Piston And Crankshaft ## S.No._=Bc0001 S.No.;_=Bc0001
Engine _ Flywheel
Engine _ Fuel Camshaft
Engine _ Idle Apparatus
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate ## S.No.;_=1e8947
Engine _ Speed Control Plate ## S.No.;_=1g0001
Engine _ Nozzle Holder [Component Parts]
Engine _ Fuel Pump Cover
Engine _ Oil Switch_Thermometer
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Valve And Rocker Arm ## S.No.;_=4z9999
Engine _ Valve And Rocker Arm ## S.No.;_=5a0001
Engine _ Inlet Manifold ## S.No.;_=4z9999
Engine _ Inlet Manifold ## S.No.;_=5a0001
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Upper Gasket Kit [Option] ## S.No.;_=4z9999
Engine _ Upper Gasket Kit [Option] ## S.No.;_=5a0001
Engine _ Lower Gasket Kit [Option]
Fuel System _ Accelerator Lever
Fuel System _ Fuel Tank
Fuel System _ Fuel Pipe_Fuel Filter
Cooling Water System _ Fan
Cooling Water System _ Water Pipe
Cooling Water System _ Radiator
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Battery
Electrical System _ Electrical Parts [G2160_G2160-DS]
Electrical System _ Electrical Parts [G2160AU_G2160EC_G2160UK]
Electrical System _ Head Light
Electrical System _ Electrical Wiring [G2160]
Electrical System _ Electrical Wiring [G2160-DS]
Electrical System _ Electrical Wiring [G2160AU_G2160EC_G2160UK]
Transmission _ Transmission Case
Transmission _ Brake Gear-Shaft_Idler Shaft
Transmission _ HST
Transmission _ HST 1 [Component Parts]
Transmission _ HST 2 [Component Parts]
Transmission _ HST 3 [Component Parts]
Transmission _ HST 4 [Component Parts]
Transmission _ Universal Joint_HST Fan
Transmission _ PTO Shaft
Transmission _ PTO Tension Pulley
Rear Axle _ Rear Differential
Rear Axle _ Rear Differential Shaft
Rear Axle _ Rear Axle Case
Rear Wheel _ Rear Wheel (230.50-12)
Brake _ PTO Brake
Brake _ Brake
Brake _ Brake Pedal
Brake _ Parking Brake Lever [G2160_G2160-DS]
Brake _ Brake Rod
Speed Change _ Speed Change Pedal [G2160_G2160-DS]
Speed Change _ Speed Change Pedal [G2160AU_G2160EC_G2160UK]
Speed Change _ Speed Control Arm
Speed Change _ Hydraulic Control Lever [G2160_G2160AU_G2160EC_G2160UK]
Speed Change _ Hydraulic Control Lever [G2160-DS]
Speed Change _ PTO Clutch Control Lever_Wire
Speed Change _ PTO Wire Bracket
Front Axle _ Front Axle
Front Axle _ Main Frame_Steering Support
Front Axle _ Engine Support
Front Wheel _ Front Wheel (16_6.5-8)
Steering _ Power Steering_Steering Handle
Hydraulic System _ Control Valve [G2160_G2160AU_G2160EC_G2160UK] ## Note_Order By Ref.No
Hydraulic System _ Control Valve [G2160-DS] ## Note_Order By Ref.No.010 (K1310-3631-3), Ref
Hydraulic System _ Control Valve [Component Parts] ## S.No._=10781 S.No
Hydraulic System _ Control Valve [Component Parts] ## S.No.10782 To 15959 S
Hydraulic System _ Control Valve [Component Parts] ## S.No._=15960 S.No
Hydraulic System _ Hydraulic Oil Line (Suction)
Hydraulic System _ Hydraulic Oil Line(Breather) [G2160_G2160AU_G2160EC_G2160
Hydraulic System _ Hydraulic Oil Line (Breather) [G2160-DS]
Hydraulic System _ Hydraulic Oil Line (Drain)
Hydraulic System _ Hydraulic Lift Cylinder
Hydraulic System _ Lift Link
Top Link_Lower Link_Hitch _ Hitch [G2160_G2160AU_G2160EC_G2160UK]
Hood_Bonnet _ Hood (Bonnet)
Hood_Bonnet _ Panel [G2160_G2160AU]
Hood_Bonnet _ Panel [G2160-DS_G2160EC_G2160UK]
Hood_Bonnet _ Fender
Hood_Bonnet _ Seat ## S.No._=15637 S.No.;_=15637
Hood_Bonnet _ Seat ## S.No._=15638 S.No.;_=15638
Hood_Bonnet _ Seat Suspension
Labels _ Label [G2160] [English]
Labels _ Label [G2160] [French]
Labels _ Label [G2160-DS]
Labels _ Label [G2160AU]
Accessories Parts _ Accessories And Service Parts
Option _ Cruise Control Kit [G2160_G2160-DS] [Option]
Region: Australia
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Oil Filter
Engine _ Oil Pump
Engine _ Flywheel
Engine _ Governor
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Muffler
Transmission _ HST
Brake _ PTO Brake
Brake _ Brake
Brake _ Brake Pedal
Brake _ Brake Rod
