702,019
Kubota Mower G1800-S Australia Parts Catalog
Type of Machine: Mower
Model: Kubota G1800-S Mower
Region: Australia
Number of Pages: 214 Pages
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Piston_Crankshaft
Engine _ Main Bearing Case
Engine _ Flywheel
Engine _ Cylinder Head
Engine _ Valve_Rocker Arm
Engine _ Nozzle Holder_Glow Plug
Engine _ Nozzle Holder [Component Parts]
Engine _ Head Cover
Engine _ Inlet Manifold
Engine _ Air Cleaner
Engine _ Exhaust Manifold
Engine _ Muffler
Engine _ Camshaft
Engine _ Gear Case
Engine _ Water Pump
Engine _ Water Flange_Thermostat
Engine _ Injection Pump
Engine _ Speed Control Plate
Engine _ Governor
Engine _ Stop Solenoid
Engine _ Upper Gasket Kit
Engine _ Lower Gasket Kit
Engine _ Accelerator Lever
Fuel System _ Fuel Tank
Fuel System _ Fuel Pipe
Cooling Water System _ Radiator
Cooling Water System _ Fan
Electrical System _ Dynamo
Electrical System _ Dynamo [Component Parts]
Electrical System _ Starter [Component Parts] ## S.No
Electrical System _ Battery
Electrical System _ Light
Electrical System _ Dashboard
Electrical System _ Wire Harness
Transmission _ Transmission Case
Transmission _ HST
Transmission _ HST [Component Parts]
Transmission _ Universal Joint_HST Fan ## S.No.;_=13397
Transmission _ Universal Joint_HST Fan ## S.No.;_=13398
Transmission _ PTO Shaft
Transmission _ Tension Pulley
Transmission _ Belt Retainer
Transmission _ Rear PTO
Transmission _ Rear PTO [Component Parts]
Speed Change _ Cruise Control Plate
Speed Change _ Cruise Control Lever
Speed Change _ Speed Control Pedal
Rear Axle _ Rear Differential
Rear Axle _ Rear Axle Case
Rear Axle _ Rear Axle [4ws]
Rear Axle _ Rear Axle Joint [4ws]
Rear Axle _ Knuckle Arm [4ws]
Rear Axle _ Tie Rod [4ws]
Rear Axle _ Drag Link [4ws]
Rear Axle _ Rear Wheel (23 X 8.50-12) [4ws]
Brake _ PTO Brake
Brake _ Brake Shaft
Brake _ Brake
Brake _ Brake Rod
Brake _ Brake Pedal
Front Axle _ Front Axle_Knuckle Arm
Front Axle _ Tie Rod_Drag Link
Front Axle _ Front Wheel (16 X 6.50-8)
Front Axle _ Frame
Steering _ Steering Gear Case
Steering _ Steering Wheel
Hydraulic System _ Control Valve
Hydraulic System _ Control Valve [Component Parts]
Hydraulic System _ Hydraulic Pipe 1
Hydraulic System _ Hydraulic Pipe 2
Hydraulic System _ Lift Cylinder
Hydraulic System _ Hydraulic Outlet [Old Type] [Option] ## S.No
Hydraulic System _ Hydraulic Outlet [New Type] [Option] ## S.No
Hydraulic System _ 3-Point Linkage [Option]
Hydraulic System _ Mower Assist Spring [Option]
Hydraulic System _ Mower Swing Stopper [Option]
Bonnet_Hood_Chassis _ Hood (Bonnet)
Bonnet_Hood_Chassis _ Panel
Bonnet_Hood_Chassis _ Fender
Bonnet_Hood_Chassis _ Seat [A] [Ca]
Bonnet_Hood_Chassis _ Seat [Au] [Nz]
Labels _ Label
Accessories _ Accessories And Service Parts
