702,019
Kubota Mower G18 Australia Parts Catalog
Type of Machine: Mower
Model: Kubota G18 Mower
Region: Australia
Number of Pages: 194 Pages
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Dipstick And Guide
Engine _ Oil Pump
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Idle Apparatus
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate ## S.No._=1e8947
Engine _ Speed Control Plate ## S.No._=1g0001
Engine _ Fuel Pump Cover
Engine _ Oil Switch And Plug
Engine _ Water Pump
Engine _ Water Pipe
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Upper Gasket Kit [Option]
Engine _ Lower Gasket Kit [Option]
Fuel System _ Accelerator Lever
Fuel System _ Fuel Tank
Fuel System _ Fuel Pipe_Fuel Filter
Cooling Water System _ Fan
Cooling Water System _ Radiator
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Battery
Electrical System _ Electrical Parts
Electrical System _ Head Light
Transmission _ Transmission Case
Transmission _ Brake Gear-Shaft_Idler Shaft
Transmission _ HST
Transmission _ HST [Component Parts]
Transmission _ Universal Joint_HST Fan
Transmission _ PTO Shaft
Transmission _ PTO Tension Pulley
Rear Axle _ Rear Differential
Rear Axle _ Rear Differential Shaft
Rear Axle _ Rear Axle Case
Rear Wheel _ Rear Wheel(230.50-12)
Brake _ PTO Brake [Old Type] ## S.No._=12871
Brake _ PTO Brake [New Type] ## S.No._=12872
Brake _ Brake
Brake _ Brake Pedal
Brake _ Brake Rod
Speed Change _ Speed Change Pedal
Speed Change _ Speed Control Arm
Speed Change _ Hydraulic Control Lever
Speed Change _ PTO Clutch Control Lever_Wire
Speed Change _ PTO Wire Bracket [New Type] ## S.No._=12872
Front Axle _ Front Axle
Front Axle _ Main Frame_Steering Support
Front Axle _ Engine Support
Front Wheel _ Front Wheel(16_6.5-8)
Steering _ Power Steering_Steering Handle
Hydraulic System _ Control Valve ## Note_Order By Ref.No.010,060,120,And 180 New Parts.
Hydraulic System _ Control Valve [Component Parts] [Old Type] ## S.No._=13391
Hydraulic System _ Control Valve [Component Parts] [New Type] ## S.No._=13392
Hydraulic System _ Hydraulic Oil Line(Suction)
Hydraulic System _ Hydraulic Oil Line(Breather)
Hydraulic System _ Hydraulic Oil Line(Drain)
Hydraulic System _ Hydraulic Lift Cylinder
Hydraulic System _ Lift Link
Hood_Bonnet _ Hood(Bonnet)
Hood_Bonnet _ Panel
Hood_Bonnet _ Fender
Hood_Bonnet _ Seat
Labels _ Label
Accessories _ Accessories And Service Parts
