Kubota Mower F3060 Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Mower
Model: Kubota F3060 Mower
Number of Pages: 328 Pages
F3060
F3060 Haeufig Verwendete Teile Frequently Used Items Haeufig Verwendete Teile Frequently
F3060 Motor Engine Kurbelgehaeuse Crank Case
F3060 Motor Engine Ol-Fanger Oil Pan
F3060 Motor Engine Zylinderkopf Cylinder Head
F3060 Motor Engine Getriebe Gehaeuse Gear Case
F3060 Motor Engine Ventildeckel Head Cover
F3060 Motor Engine Oelfilter Oil Filter
F3060 Motor Engine Hauptlagergehäuse Main Bearing Case
F3060 Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And Idle Gear
F3060 Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
F3060 Motor Engine Schwungrad Flywheel
F3060 Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And Governor
F3060 Motor Engine Freilaufapparat Idle Apparatus
F3060 Motor Engine Einspritzpumpe Injection Pump
F3060 Motor Engine Zylinderkopf Governor ## S.Nr. =Xz0500 S.No.; =Xz0500 S.No. =Xz0500 S.
F3060 Motor Engine Zylinderkopf Governor ## S.Nr. =Ya0001 S.No.; =Ya0001 S.No. =Ya0001 S.
F3060 Motor Engine Geschwindigkeitskontrolle Nockenhohn Speed Control Plate
F3060 Motor Engine Duesenhalter Und Gluehkerze Nozzle Holder And Glow Plug
F3060 Motor Engine Duesenhalter [Einzel-Teil] Nozzle Holder [Component Parts]
F3060 Motor Engine Kuehlwasserflansch Water Flange And Thermostat
F3060 Motor Engine Loffel(Ohne Schnellkupplung) [Option] Water Pump
F3060 Motor Engine Loffel(Ohne Schnellkupplung) [Option] Valve And Rocker Arm
F3060 Motor Engine Ansaugrohr Inlet Manifold
F3060 Motor Engine Auslasskruemmer Exhaust Manifold
F3060 Motor Engine Luftfilter Air Cleaner ## S.Nr. =50456 S.No.; =50456 S.No. =50456 S.No.; =
Motor Engine Luftfilter Air Cleaner ## S.Nr.50457 To 50535 S.No.;50457 To 50535 S.No.50457 To 50535
F3060 Motor Engine Luftfilter Air Cleaner ## S.Nr. =50536 S.No.; =50536 S.No. =50536 S.No.; =
F3060 Motor Engine Auspufftopf Muffler
F3060 Motor Engine Hydraulikpumpe Hydraulic Pump
F3060 Motor Engine Hydraulikpumpe [Einzel-Teil] Hydraulic Pump [Component Parts]
F3060 Motor Engine Beschleunigerhebel Accelerator Lever
F3060 Kraftstoff System Fuel System Karroceair Fuel Tank
F3060 Kraftstoff System Fuel System Kraftstoffsieb Fuel Filter
F3060 Kuehlungs System Cooling Water System Ventilator Fan
F3060 Kuehlungs System Cooling Water System Kuehler Radiator
F3060 Kuehlungs System Cooling Water System Staubschutzplatte Dustproof
F3060 Elektrisches System Electrical System Oelschalter Und Thermometer Oil Switch And
F3060 Elektrisches System Electrical System Abstellhubmagnet Stop Solenoid
F3060 Elektrisches System Electrical System Lichtmaschine Alternator
F3060 Elektrisches System Electrical System Lichtmaschine [Einzel-Teil] Alternator [
F3060 Elektrisches System Electrical System Anlasser Starter
F3060 Elektrisches System Electrical System Anlasser [Einzel-Teil] Starter [Component
F3060 Elektrisches System Electrical System Batterie Battery
F3060 Elektrisches System Electrical System Schalter Switch
F3060 Elektrisches System Electrical System Elektrische Ausrustung (Kabine) Electrical
F3060 Elektrisches System Electrical System Tachometer [Option] Tachometer Kit [
F3060 Elektrisches System Electrical System Leuchte [Uk] Light Kit [Uk]
F3060 Kupplung Clutch Kupplung Clutch
F3060 Transmission Transmission Carcasa Caja Transferencia Transmission Case
F3060 Transmission Transmission Differentialgetriebegehaeuse Differental Gear
Transmission Transmission Hst [Einzel-Teil] Hst [Component Parts] ## S.Nr. =59999 S.No.; =59999
Transmission Transmission Hst [Einzel-Teil] Hst [Component Parts] ## S.Nr. =60001 S.No.; =60001
F3060 Transmission Transmission Kardangelenk Ventilator Universal Joint Fan
F3060 Transmission Transmission Zapfwelle Pto Shaft
F3060 Transmission Transmission Vorderachsen-Differential Front Differential
F3060 Transmission Transmission Antriebswelle, Hinterrad Rear Wheel Propeller
Vorerachse Vorderrad Front Axle Front Wheel Kupplung [Einzel-Teil] One-Way Clutch [
F3060 Vorerachse Vorderrad Front Axle Front Wheel Vorderachse Gehaueuse Front
F3060 Vorerachse Vorderrad Front Axle Front Wheel Loffel(Ohne Schnellkupplung) [Option]
F3060 Vorerachse Vorderrad Front Axle Front Wheel Differentialsperrepedal Differential
Vorerachse Vorderrad Front Axle Front Wheel Hilfsbremspedale [Option] Turn Assist
F3060 Vorerachse Vorderrad Front Axle Front Wheel Vorderrad (24 8,5-12) Front Wheel
Vorerachse Vorderrad Front Axle Front Wheel Vorderrad (230,5-12) [Option] Front Wheel
F3060 Bremse Brake Brems Brake
F3060 Bremse Brake Bremspedal Brake Pedal
System Speed Change Tempomat-Schalthebel Cruise Control Lever ## S.Nr. =59999 S.No.; =
System Speed Change Tempomat-Schalthebel Cruise Control Lever ## S.Nr. =60001 S.No.; =
F3060 Getriebe System Speed Change Tempomat-Schalthebel [Option] Cruise Control Lever
F3060 Getriebe System Speed Change Drehzahlbereichshebel Range Gear Shift
F3060 Getriebe System Speed Change Zapfwellenschalthebel Pto Gear Shift Lever
F3060 Getriebe System Speed Change Hydraulik Auftriebhebel Hydraulic Lift Lever
F3060 Getriebe System Speed Change Fahrpedal Speed Control Pedal
F3060 Getriebe System Speed Change Tempomat Hebel Cruise Control [Option]
F3060 Getriebe System Speed Change Hebel Clutch Lock Lever
F3060 Hinterradachse Hinterrad Rear Axle Rear Wheel Hinterachsen-Diff.Gehaeuse Rear
F3060 Hinterradachse Hinterrad Rear Axle Rear Wheel Hinterdifferential Rear
F3060 Hinterradachse Hinterrad Rear Axle Rear Wheel Winkelzahnradwelle Bevel Gear
F3060 Hinterradachse Hinterrad Rear Axle Rear Wheel Winkelzahnradgehaeuse Bevel
F3060 Hinterradachse Hinterrad Rear Axle Rear Wheel Hinterachse Gehaeuse Rear
F3060 Hinterradachse Hinterrad Rear Axle Rear Wheel Hinterantriebswelle Rear Drive
F3060 Hinterradachse Hinterrad Rear Axle Rear Wheel Hinterrad (18 7,0-8) Rear Wheel
Hinterradachse Hinterrad Rear Axle Rear Wheel Hinterrad (18 7,0-8) [Option] Rear Wheel
F3060 Lenkgestaenge Steering Spurstange Tie Rod
F3060 Lenkgestaenge Steering Lenkrad Steering Wheel
F3060 Lenkgestaenge Steering Hydraulikpumpe (Hilfskraftlenkung) Hydraulic Pump
Lenkgestaenge Steering Hydraulikpumpe (Hilfskraftlenkung) [Einzel-Teil] Hydraulic Pump (
F3060 Lenkgestaenge Steering Lenkungszylinder [Einzel-Teil] Steering Cylinder [Component
F3060 Hydraulik System Hydraulic System Hydraulik-Kreislauf (Meeresarm) Hydraulic Oil
F3060 Hydraulik System Hydraulic System Hydraulik-Kreislauf (Oelkuehler) Hydraulic Oil
F3060 Hydraulik System Hydraulic System Hydraulikzylinder Hydraulic Cylinder
F3060 Hydraulik System Hydraulic System Kontrollventil Control Valve
F3060 Hydraulik System Hydraulic System Regelungsventil [Einzel-Teil] Control Valve [
Hydraulik System Hydraulic System Grp.Kontrollventil (1ventil) [Option] Control Valve
Hydraulik System Hydraulic System Grp.Kontrollventil (2ventil) [Option] Control Valve
F3060 Hubstange Unterlenker Lift Rod Lower Link Rasenmaeherschubstange Mower
Unterlenker Lift Rod Lower Link Kardangelenkgehaeuse Joint Cover ## S.Nr. =50536 S.No.; =
F3060 Hubstange Unterlenker Lift Rod Lower Link Gewicht Weight
F3060 Motorhaube Hood Bonnet Hauptrahmen Main Frame
F3060 Motorhaube Hood Bonnet Motorhaube H00d (Bonnet)
F3060 Motorhaube Hood Bonnet Lenkungpfosten Steering Post
F3060 Motorhaube Hood Bonnet Kotfluegel Fender
F3060 Motorhaube Hood Bonnet Sitz Ausgenommen [G] Seat Except [G]
F3060 Motorhaube Hood Bonnet Ueberrollbuegel (Option) Rops [Option]
F3060 Aufkleber Labels Aufkleber Label
F3060 Zubehoer Accessories And Service Parts Sonstiges Zubehoer Accessories
F3060
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
