702,019
Kubota Mower F3060 Australia Parts Catalog
Type of Machine: Mower
Model: Kubota F3060 Mower
Region: Australia
Number of Pages: 278 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Oil Filter
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft And Governor Shaft
Engine _ Idle Apparatus
Engine _ Injection Pump
Engine _ Governor ## S.No._=Xz0500 S.No.;A_=Xz0500
Engine _ Governor ## S.No._=Ya0001
Engine _ Speed Control Plate
Engine _ Nozzle Holder [Component Parts]
Engine _ Water Pump
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner ## S.No._=10987
Engine _ Air Cleaner ## S.No.10988 To 11192
Engine _ Air Cleaner ## S.No._=11193
Engine _ Muffler
Engine _ Hydraulic Pump
Engine _ Hydraulic Pump [Component Parts]
Fuel System _ Accelerator Lever
Fuel System _ Fuel Tank
Fuel System _ Fuel Filter
Cooling Water System _ Fan
Cooling Water System _ Radiator
Cooling Water System _ Dust Proof Plate
Cooling Water System _ Oil Switch And Thermo Sensor
Electrical System _ Stop Solenoid
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Battery
Electrical System _ Switch
Electrical System _ Tachometer Kit [Option]
Electrical System _ Light Kit [Option]
Clutch _ Clutch
Transmission _ Transmission Case
Transmission _ Differental Gear Case
Transmission _ HST [Component Parts] ## S.No._=19999
Transmission _ HST [Component Parts] ## S.No._=20001
Transmission _ Universal Joint_Fan
Transmission _ PTO Shaft
Transmission _ Front Differential
Transmission _ Rear Wheel Propeller Shaft
Transmission _ One-Way Clutch [Component Parts]
Front Axle_Front Wheel _ Front Axle Case
Front Axle_Front Wheel _ Front Wheel (230.5-12)
Brake _ Brake
Brake _ Brake Pedal
Brake _ Turn Assist Brake Pedals [Option]
Control Lever _ Cruise Control Lever ## S.No._=19999
Control Lever _ Cruise Control Lever ## S.No._=20001
Control Lever _ Cruise Control Lever [Option]
Control Lever _ Range Gear Shift Lever
Control Lever _ PTO Gear Shift Lever
Control Lever _ Hydraulic Lift Lever
Control Lever _ Speed Control Pedal
Control Lever _ Cruise Control [Option]
Control Lever _ Clutch Lock Lever
Control Lever _ Differential Lock Pedal
Rear Axle_Rear Wheel _ Rear Differential Case
Rear Axle_Rear Wheel _ Bevel Gear Shaft
Rear Axle_Rear Wheel _ Bevel Gear Case
Rear Axle_Rear Wheel _ Rear Axle Case
Rear Axle_Rear Wheel _ Rear Drive Shaft
Rear Axle_Rear Wheel _ Rear Wheel (18_7.0-8)
Steering _ Tie Rod
Steering _ Steering Wheel
Steering _ Hydraulic Pump (Ps)
Steering _ Hydraulic Pump (Ps) [Component Parts]
Steering _ Steering Cylinder [Component Parts]
Hydraulic System _ Hydraulic Oil Line (Inlet)
Hydraulic System _ Hydraulic Oil Line (Oil Cooler)
Hydraulic System _ Hydraulic Cylinder
Hydraulic System _ Control Valve
Hydraulic System _ Control Valve [Component Parts]
Hydraulic System _ Control Valve Kit (1valve) [Option]
Hydraulic System _ Control Valve Kit (2valve) [Option]
Lift Rod_Lower Link _ Mower Link
Lift Rod_Lower Link _ Joint Cover [Option]
Lift Rod_Lower Link _ Weight
Bonnet (Rear) _ Main Frame
Bonnet (Rear) _ H00d (Bonnet)
Bonnet (Rear) _ Steering Post
Bonnet (Rear) _ Fender
Bonnet (Rear) _ Seat ## S.No._=32549
Bonnet (Rear) _ Rops [Option]
Labels _ Label
Accessories And Service Parts _ Accessories
