702,169
Kubota Mower F2400-BI Australia Parts Catalog
Type of Machine: Mower
Model: Kubota F2400-BI Mower
Region: Australia
Number of Pages: 274 Pages
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Piston_Crankshaft
Engine _ Main Bearing Case
Engine _ Flywheel
Engine _ Cylinder Head
Engine _ Valve And Rocker Arm
Engine _ Nozzle Holder
Engine _ Nozzle Holder [Component Parts] ## S.No.;_=489915
Engine _ Nozzle Holder [Component Parts] ## S.No.;_=489916
Engine _ Head Cover
Engine _ Inlet Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Camshaft
Engine _ Gear Case
Engine _ Water Pump
Engine _ Water Flange
Engine _ Fuel Camshaft
Engine _ Injection Pump ## S.No._=489915
Engine _ Injection Pump ## S.No._=489916
Engine _ Engine Stop Solenoid
Engine _ Speed Control Plate ## S.No.;_=468068
Engine _ Speed Control Plate ## S.No.;_=468069
Engine _ Governor
Engine _ Upper Gasket Kit
Engine _ Lower Gasket Kit
Engine _ Accelerator Lever
Fuel System _ Fuel Tank
Fuel System _ Fuel Pipe
Fuel System _ Fuel Filter [Component Parts]
Cooling Water System _ Fan
Cooling Water System _ Radiator
Cooling Water System _ Dust Proof Plate
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Electrical System 1
Electrical System _ Electrical System 2
Electrical System _ Light Kit ## {UK}{Fr(Option)}{Ca(Option)}
Clutch _ Clutch
Clutch _ Propeller Shaft
Clutch _ Diff.Lock_Clutch Rod
Clutch _ Clutch Rod
Clutch _ Clutch Housing Frame
Transmission _ Transmission Case
Transmission _ Case Cover
Transmission _ HST
Transmission _ HST [Component Parts]
Transmission _ Second Shaft
Transmission _ Third_Fifth Shaft
Transmission _ 4th Shaft
Main Sp-Change Lever _ Speed Change Fork And PTO Lever
Main Sp-Change Lever _ Range Gear Shift Lever
Main Sp-Change Lever _ Rear Wheel Drive Lever ## S.No.;_=16590
Main Sp-Change Lever _ Neutral Holder
Main Sp-Change Lever _ Speed Change Rod
Main Sp-Change Lever _ Speed Lock Lever ## S.No.;_=14993
Main Sp-Change Lever _ Speed Lock Lever ## S.No.;_=14994
Front Axle_Front Wheel _ Differential
Front Axle_Front Wheel _ Axle Case
Front Axle_Front Wheel _ Front Axle
Front Axle_Front Wheel _ Front Wheel (25x8.50-14) ## Except F2400-BI-ELL
Brake _ Brake
Brake _ Pedal
Brake _ Brake Rod
Rear Axle_Rear Wheel _ Wheel Hub
Rear Axle_Rear Wheel _ Rear Axle Case
Rear Axle_Rear Wheel _ Bevel Gear Case
Rear Axle_Rear Wheel _ Bi-Speed Turn Case
Rear Axle_Rear Wheel _ Differential
Rear Axle_Rear Wheel _ Clutch Disk
Rear Axle_Rear Wheel _ Universal Joint ## S.No.;_=16193
Rear Axle_Rear Wheel _ Universal Joint ## S.No.;_=16194
Rear Axle_Rear Wheel _ Bi-Speed Turn Lever ## S.No.;_=16589
Rear Axle_Rear Wheel _ Bi-Speed Turn Lever ## S.No.;_=16590
Rear Axle_Rear Wheel _ Shift Fork
Rear Axle_Rear Wheel _ Shift Lever
Rear Axle_Rear Wheel _ Rear Wheel (20x8.00-10) ## Except B2400-BI-ELL_CDW
Rear Axle_Rear Wheel _ Rear Axle Frame
Steering _ Knuckle Arm
Steering _ Steering
Steering _ Handle Post
Hydraulic System _ Power Steering
Hydraulic System _ Power Steering [Component Parts]
Hydraulic System _ Power Cylinder [Component Parts]
Hydraulic System _ Hydraulic Pump
Hydraulic System _ Hydraulic Pump [Component Parts]
Hydraulic System _ Hydraulic Pipe
Hydraulic System _ Oil Cooler_Hydraulic Pipe
Hydraulic System _ Control Valve
Hydraulic System _ Control Valve [Component Parts]
Hydraulic System _ Lift Cylinder [Component Parts]
Hydraulic System _ Control Valve Kit [Option]
Hydraulic System _ Control Valve 2 [Component Parts]
Hydraulic System _ Link
Hydraulic System _ Lift Arm
Hood_Bonnet _ Hood(Bonnet)
Hood_Bonnet _ Fender
Hood_Bonnet _ Front Frame
Hood_Bonnet _ Seat
Hood_Bonnet _ Seat [Component Parts] ## Except F2400-Bi-Elw_Ell{Fr}
Hood_Bonnet _ Rops ## {Ca}
Labels _ Label
Accessories And Service Parts _ Accessories And Service Parts
