652
1,893,758
Kubota Mini Excavator U50-5S Only For Asian Market Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U50-5S Mini Excavator
Number of Pages: 409 Pages
Crankcase
Oil Pan
Gear Case
Head Cover
Engine Bracket
Main Bearing Case
Camshaft And Idle Gear Shaft
Piston And Crankshaft
Flywheel
Fuel Camshaft And Governor Shaft
Engine Stop Lever
Governor
Speed Control Plate
Nozzle Holder And Glow Plug
Alternator (Component Parts)
Starter
Starter (Component Parts)
Water Flange And Thermostat
Water Pipe And Reserve Tank
Valve And Rocker Arm
Inlet Manifold
Exhaust Manifold
Air Cleaner
Muffler
Upper Gasket Kit
Lower Gasket Kit
Auto Idle Motor
Fuel Pump And Piping
Fuel Filter (Component Parts)
Separator (Component Parts)
Battery
Horn
Switch And Meter
Light
Electrical Wiring
Pump Housing
Piston Pump (Component Parts)
Drive Moter (Component Parts)
Swivel Motor (Component Parts)
Rotary Joint
Tank,Oil
Tank,Oil
Control Valve 1
Light
Control Valve 1
Control Valve 2
Control Valve 2
Control Valve 3
Control Valve 3
Control Valve 4
Control Valve 4
Control Valve (Component Parts)
Spool Section (Inlet)
Spool Section (Swivel)
Spool Section (Travel Lh)
Spool Section (Travel Rh)
Spool Section (Blade)
Spool Section (Arm)
Spool Section (Arm)
Spool Section (Boom)
Spool Section (Bucket)
Spool Section (Swing)
Spool Section (S/P) / Spool Section (S/P)
Section (Outlet)
Change Valve
Change Valve (Component Parts)
Super Change Valve
Super Change Valve (Component Parts)
Control Lever (Lever Lh)
Pilot Valve Lh (Component Parts)
Control Lever (Lever Rh)
Pilot Valve Rh (Component Parts)
Control Lever (Travel Lh 1)
Control Lever (Travel Lh 2)
Control Lever (Travel Rh 1)
Control Lever (Travel Rh 2)
Control Valve 4
Control Lever (Travel Lock)
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/Swing Change 1) / Control Pedal (Swivel/Swing Change 1)
Control Pedal (Swivel/Swing Change 2) / Control Pedal (Swivel/Swing Change 2)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Control Lh)
Oil Piping (Control Rh)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (S/P) / Oil Piping (S/P)
Oil Piping (Third Line Hydraulic Return)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Track Frame
Idler
Track Roller
Crawler
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Seat Support
Step
Step
Cover (Lh)
Cover (Rh)
Cover (Rh)
Bonnet (Lh)
Bonnet (Lh)
Bonnet (Rh)
Bonnet (Rear)
Sponge
Weight
Canopy
Cabin (Body)
Cabin (Door)
Cabin (Door Lock)
Cabin (Window)
Cabin (Window Front)
Cabin (Sponge)
Cabin (Seal Rubber)
Cabin (Wiper Motor)
Cabin (Electrical Wiring)
Cabin (Heater)
Cabin (A/C 1) / Cabin (A/C 1)
Cabin (A/C 2) / Cabin (A/C 2)
Cabin (A/C 3) / Cabin (A/C 3)
Cabin (A/C 4) / Cabin (A/C 4)
Label
