Kubota Mini Excavator U50-3ALPHA Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U50-3ALPHA Mini Excavator
Number of Pages: 360 Pages
Maintenance Parts
Vál.Antirot.Tubo/Pesc. / Pipe-Break Valve/Boom
Vál.Antirot.Tubo/Brazo / Pipe-Break Valve/Arm
Vál.Antirot.Tubo/Cuchil (S.No. ~76913) / Pipe-Break Valve/Dozer (S.No. ~76913)
Vál.Antirot.Tubo/Cuchil (S.No. 76914~) / Pipe-Break Valve/Dozer (S.No. 76914~)
Kit Pinza (Sin Acoplador) / Clamp Kit (Without Quick-Coupler)
Kit Pinza (Con Acoplador) / Clamp Kit (With Quick-Coupler)
Juego De Acoplamientos Planos / Kit Flat-Face Coupler
Juego De Acoplamientos Rápidos / Kit Plug-In Coupler
Juego De Acoplamientos Filetados / Kit Screw-Type Coupler
Sp2 Conjunto De Base / Sp2 Kit Base
Sp2 Juego De Brazo / Sp2 Kit Boom
Gap-Kit 3
Kit Black Box
Soporte - Km200 / Km300 / Mounting Brackets - Km200 / Km300
Pipe-Break Valve/Boom / Pipe-Break Valve/Boom
Pipe-Break Valve/Arm / Pipe-Break Valve/Arm
Pipe-Break Valve/Dozer / Pipe-Break Valve/Dozer
Kit Plug-Face Coupler
Sp2 Kit Base
Sp2 Kit Boom
Gap-Kit 3
Kit Knob Lh
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Head Cover
Engine Bracket
Camshaft And Idle Gear Shaft
Gap-Kit 3
Volante / Flywheel
Fuel Camshaft Governor Shaft
Motor Parar Palanca / Engine Stop Lever
Injection Pump (Component Parts)
Speed Control Plate
Motor De Arranque / Starter
Starter (Component Parts)
Alternator And Pulley
Alternator (Component Parts)
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Exhaust Manifold
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Gasket Kit Upper
Gasket Kit Lower
Auto Idle Motor
Fuel Piping
Fuel Filter (Component Parts)
Timer Horn Relay Ai
Switch And Meter
Light
Pump Housing
Hydraulic Pump (Component Parts)
Drive Moter (Component Parts) (1)
Drive Moter (Component Parts) (2)
Swivel Motor (Component Parts) (1)
Swivel Motor (Component Parts) (2)
Rotary Joint
Oil Tank
Control Valve (1)
Control Valve (2)
Control Valve (3)
Control Valve (4)
Control Valve (Component Parts)
Spool Section (Swivel)
Spool Section (Travel Lh)
Spool Section (Travel Rh)
Spool Section (Blade)
Spool Section (Arm)
Spool Section (Boom)
Spool Section (Bucket)
Spool Section (Swing)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Inlet)
Change Valve
Change Valve (Component Parts)
Control Lever (Lever Lh)
Pilot Valve (Component Parts) Lh
Control Lever (Lever Rh)
Pilot Valve (Component Parts) Rh
Control Lever (Travel Lh) 1
Control Lever (Travel Lh) 2
Control Lever (Travel Rh) 1
Control Lever (Travel Rh) 2
Stop Lever Travel
Valve (Sp) (S.No. <=76627)
Valve (Sp) (S.No. >=76628)
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/ Swing Change 1) / Control Pedal (Swivel/ Swing Change 1)
Control Pedal (Swivel/ Swing Change 2) / Control Pedal (Swivel/ Swing Change 2)
Control Lever (Blade)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Accumulator)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Operation Lh)
Oil Piping (Operation Rh)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Clamp (Oil Piping)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder (Comp. Parts)
Arm Cylinder (Comp. Parts)
Bucket Cylinder (Component Parts)
Blade Cylinder (Component Parts) (S.No. <=76858)
Blade Cylinder (Component Parts) (S.No. >=76859)
Swing Cylinder (Component Parts)
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Bucket (No Quick-Coupler)
Blade
Truck Frame
Idler
Track Roller
Crawler
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Seat Support (Air Condition)
Step
Step (Air Condition)
Cover (Lh)
Cover (Rh)
Bonnet (Lh)
Bonnet (Lh)(Air Condition)
Bonnet (Rh)
Bonnet (Back)
Sponge
Weight
Hoja / Seat
Cabin (Sponge)
Cabin (Window 1)
Cabin (Window 1) (Air Conditioning)
Cabin (Window 2)
Cabin (Door)
Cabin (Wiper Motor)
Cabin (Accessories)
Cabin (Heater)
Cabin (Heater)(Air Condition)
Cabin (Air Condition 1)
Cabin (Air Condition 2)
Cabin (Air Condition 3)
Cabin (Air Condition 4)
Label
Accessories (S.No. <=76627)
Accessories (S.No. >=76628)
Maintenance Parts
Gap-Kit 3
Kit Black Box
Sp2 Kit Base
Sp2 Kit Boom
Gap-Kit 3
Kit Knob Lh
Head Cover
Engine Bracket
Gap-Kit 3
Volante / Flywheel
Speed Control Plate
Exhaust Manifold
Gasket Kit Upper
Gasket Kit Lower
Auto Idle Motor
Fuel Piping
Timer Horn Relay Ai
Switch And Meter
Light
Pump Housing
Rotary Joint
Oil Tank
Control Valve (1)
Control Valve (2)
Control Valve (3)
Control Valve (4)
Spool Section (Arm)
Change Valve
Stop Lever Travel
Oil Piping (Return)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Clamp (Oil Piping)
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Blade
Truck Frame
Idler
Track Roller
Crawler
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Cover (Lh)
Cover (Rh)
Bonnet (Lh)
Bonnet (Rh)
Bonnet (Back)
Sponge
Weight
Hoja / Seat
Cabin (Sponge)
Cabin (Window 1)
Cabin (Window 2)
Cabin (Door)
Cabin (Wiper Motor)
Cabin (Accessories)
Cabin (Heater)
Label
