652
1,893,758
Kubota Mini Excavator U45-3 55001-69999 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U45-3 Mini Excavator
Serial Number: 55001-69999
Number of Pages: 291 Pages
Label
Air Cleaner
Crankcase
Oil Pan
Gear Case
Head Cover
Engine Bracket
Main Bearing Case
Camshaft And Idle Gear Shaft
Piston And Crankshaft
Flywheel
Fuel Camshaft Governor Shaft
Engine Stop Lever
Injection Pump (Component Parts)
Governor
Speed Control Plate
Nozzle Holder And Glow Plug
Starter
Starter (Component Parts)
Alternator And Pulley
Alternator (Component Parts)
Valve And Rocker Arm
Inlet Manifold
Exhaust Manifold
Gasket Kit Upper
Gasket Kit Lower
Water Flange And Thermostat
Water Pipe
Battery (S.No. <=50157)
Battery (S.No. >=50158)
Timer Horn
Switch And Meter
Light
Electrical Wiring
Electrical Wiring (Air Condition)
Muffler
Maintenance Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Bucket Link
Blade
Fuel Piping
Fuel Filter (Component Parts)
Pump Housing
Hydraulic Pump (Component Parts)
Drive Moter (Component Parts) (1)
Drive Moter (Component Parts) (2)
Swivel Motor (Component Parts) (1)
Swivel Motor (Component Parts) (2)
Rotary Joint
Oil Tank
Control Valve (1)
Control Valve (2)
Control Valve (3)
Control Valve (4)
Control Valve (Component Parts)
Spool Section (Swivel)
Spool Section (Travel)
Spool Section (Blade)
Spool Section (Arm)
Spool Section (Boom)
Spool Section (Bucket)
Spool Section (Swing)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Inlet)
Change Valve
Change Valve (Component Parts)
Control Lever (Lever Lh)
Pilot Valve (Component Parts) Lh
Control Lever (Lever Rh)
Pilot Valve (Component Parts) Rh
Control Lever (Travel Lh) 1
Control Lever (Travel Lh) 2
Control Lever (Travel Rh) 1
Control Lever (Travel Rh) 2
Stop Lever Travel
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/ Swing Change 1) / Control Pedal (Swivel/ Swing Change 1)
Control Pedal (Swivel/ Swing Change 2) / Control Pedal (Swivel/ Swing Change 2)
Control Lever (Blade)
Pedal (S/P) / Pedal (S/P)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Operation Lh)
Oil Piping (Operation Rh)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Clamp (Oil Piping)
Oil Piping (S/ P) / Oil Piping (S/ P)
Boom Cylinder (Component Parts)
Arm Cylinder (Component Parts)
Bucket Cylinder (Component Parts)
Blade Cylinder (Comp. Parts)(S.No. <=00197)
Blade Cylinder (Comp. Parts)(S.No. >=00198)
Swing Cylinder (Component Parts)
Cabin (Sponge)
Cabin (Window 1)
Cabin (Window 2)
Cabin (Door)
Cabin (Wiper Motor)
Cabin (Accessories)
Cabin (Heater)
Cabin (Heater)(Air Condition)
Cabin (Air Condition 1)
Cabin (Air Condition 2)
Cabin (Air Condition 3)
Cabin (Air Condition 4)
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Seat Support (Air Condition)
Step
Cover (Lh)
Cover (Rh)
Bonnet (Lh)
Bonnet (Lh)(Air Condition)
Bonnet (Rh)
Bonnet (Back)
Sponge
Weight
Truck Frame
Idler
Track Roller
Crawler
