652
1,893,758
Kubota Mini Excavator U36-4 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U36-4 Mini Excavator
Number of Pages: 521 Pages
Piezas De Mantenimiento / Maintenance Parts
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Aceite Tapaporos Brida / Oil Filler Flange
Volante / Flywheel
Motor Parar Palanca / Engine Stop Lever
Alternador / Alternator
Alternador (Componente Piezas) / Alternator (Component Parts)
Motor De Arranque / Starter
Motor De Arranque (Componente Piezas) / Starter (Component Parts)
Agua Bomba / Water Pump
Tension Polea / Pulley,Tension
Agua Tubo / Water Pipe And Reserve Tank
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Junta Kit [Opcion] / Upper Gasket Kit [Option]
Junta Kit / Lower Gasket Kit [Option]
Combustible Tubos / Fuel Pump And Piping
Combustible Filtro (Componente Piezas) / Fuel Filter (Component Parts)
Separador (Componente Piezas) / Water Separator (Component Parts)
Temporizador Y Claxon / Timer And Horn
Conmutador Y Metro / Switch And Meter
Lámpara / Light
Instalacion Electrica / Electrical Wiring
Antirrobo Alarma Sistema / Anti-Theft Alarm System
Bomba Carcasa / Pump Housing
Piston Bomba Componente Piezas / Piston Pump
Piston Bomba (Componente Piezas) / Piston Pump (Component Parts)
Accionar Motor / Drive Moter
Accionar Motor (Componente Piezas) / Drive Motor (Component Parts 1)
Accionar Motor (Componente Piezas) / Drive Motor (Component Parts 2)
Accionar Motor (Componente Piezas) / Drive Motor (Component Parts 3)
Girar Motor / Swivel Motor
Girar Motor (Componente Piezas) / Swivel Motor (Component Parts 1)
Girar Motor (Componente Piezas) / Swivel Motor (Component Parts 2)
Rotativo Junta / Rotary Joint
Rotativo Junta (Componente Piezas) / Rotary Joint (Component Parts)
Aceite Deposito (Placa) / Oil Tank (1)
Tanque De Aceite (2) / Oil Tank (2)
Filtro De Aceite / Oil Filter
Distribuidor (1) / Control Valve (1)
Distribuidor (2) / Control Valve (2)
Distribuidor / Control Valve
Control Valvula (Componente Piezas / Control Valve (Component Parts)
Corredera Seccion (Cubo) / Spool Section (Bucket)
Corredera Seccion (Aguilon) / Spool Section (Boom)
Corredera Seccion (Recorrido Derecho) / Spool Section (Travel Rh)
Corredera Seccion (Espaciador) / Spool Section (Spacer)
Corredera Seccion (Recorrido Izquierdo) / Spool Section (Travel Lh)
Corredera Seccion (Brazo) / Spool Section (Arm)
Corredera Seccion (Ax1) / Spool Section (Ax1)
Corredera Seccion (Delantera) / Spool Section (Lead)
Corredera Seccion (Lamina) / Spool Section (Blade)
Corredera Seccion (Oscilacion) / Spool Section (Swing)
Corredera Seccion (Girar) / Spool Section (Swivel)
Corredera Seccion (Aguilon2) / Spool Section (Boom2)
Corredera Seccion (Ax2) / Spool Section (Ax2)
Corredera Seccion (Salide) / Spool Section (Outlet)
Descargar Valvula / Unload Valve
Descargar Valvula (Componente Piezas) / Unload Valve (Component Parts)
Magnetico Valvula / Magnetic Valve
Magnetico Valvula (Componente Piezas) / Magnetic Valve (Component Parts)
Valvula Del Solenoide / Solenoid Valve
Valvula Del Solenoide (Componente Piezas) / Solenoid Valve (Component Parts)
Control Palanca (Palanca Izquierdo) / Control Lever (Lever Lh)
Piloto Valvula (Componente Piezas) / Pilot Valve Lh (Component Parts)
Control Palanca (Palanca Derecho) [Tipo Estandar] / Control Lever (Lever Rh)
Piloto Valvula (Componente Piezas) / Pilot Valve (Rh) (Component Parts)
Control Palanca (Recorrido) / Control Lever (Travel)
Piloto Valvula (Recorrido) / Pilot Valve (Travel)
Piloto Valvula (Recorrido) (Componente Piezas) / Pilot Valve (Travel) (Component Parts)
Aguilon Oscilacion Pedal / Swing Pedal
Cierre Con Llave La Palanca / Control Lever (Safety Lock Lever)
Control Palanca (Lamina) / Control Lever (Blade)
Aceite Tubos (Asupiracion) / Oil Piping (Suction)
Aceite Tubos (Entrega) / Oil Piping (Delivery)
Aceite Tubos (Devolver) / Oil Piping (Return)
Aceite Tubos (Aceite Refrigerador) / Oil Piping (Oil Cooler)
Aceite Tubos (Control Izquierdo) / Oil Piping (Control Lh)
Aceite Tubos (Control Derecho) / Oil Piping (Control Rh)
Ducto De Aceite (Piloto P) / Oil Piping (Pilot P)
Ducto De Aceite (Piloto T) / Oil Piping (Pilot T)
Aceite Tubos (Recorrido Izquierdo) / Oil Piping (Travel Lh)
Aceite Tubos (Recorrido Derecho) / Oil Piping (Travel Rh)
Aceite Tubos (Girar) / Oil Piping (Swivel)
Aceite Tubos (Oscilacion) / Oil Piping (Swing)
Aceite Tubos (Aguilon) / Oil Piping (Boom)
Aceite Tubos (Brazo) / Oil Piping (Arm)
Aceite Tubos (Cubo) / Oil Piping (Bucket)
Aceite Tubos (Lamina) / Oil Piping (Blade)
Aceite Tubos (Abrazadera) / Oil Piping (Clamp 1)
Aceite Tubos (Abrazadera) / Oil Piping (Clamp 2)
Aceite Tubos (Servicio Piezas 1) / Oil Piping (S/P)
Aceite Tubos (Tercera Linea Hidraulico Devolver) / Oil Piping (Third Line Hydraulic Return)
Aguilon Cilindro / Boom Cylinder
Brazo Cilindro / Arm Cylinder
Cubo Cilindro / Bucket Cylinder
Lamina Cilindro / Blade Cylinder
Oscilacion Cilindro / Swing Cylinder
Oscilacion Soporte / Swing Bracket
Aguilon / Boom
Cilindro Cubierta (Aguilon) / Cylinder Cover (Boom)
Brazo / Arm
Vinculo Cubo / Bucket Link
Lamina / Blade
Tren De Orugas Bastidor / Track Frame
Rueda,Rueda Loca / Idler
Camion Rodillo / Track Roller
Oruga / Crawler
Girar Bastidor / Swivel Frame
Arco Bastidor / Arch Frame
Girar Rodamiento / Swivel Bearing
Peldano / Step
Peldano / Step
Cubierta (Izquierdo) / Cover (Lh)
Cubierta (Derecho) / Cover (Rh)
Capo (Izquierdo) / Bonnet (Lh)
Capo (Derecho) / Bonnet (Rh)
Capo Trasero / Bonnet (Rear)
Capo (Centre) / Bonnet (Center)
Esponja 1 / Sponge 1
Esponja 2 / Sponge 2
Esponja 3 / Sponge 3
Peso / Weight
Hoja / Seat
Hoja / Seat
Techo De Lona / Canopy
Cabina (Carroceria) / Cabin (Body)
Cabina (Puerta) / Cabin (Door)
Cabina (Ventana 1) / Cabin (Window 1)
Cabina (Frente De La Ventana) / Cabin (Window 2)
Cabina (Esponja) / Cabin (Cover And Trim))
Cabina (Forro) / Cabin (Lining)
Cabina (Reten Caucho) / Cabin (Seal Rubber)
Cabina (Espejo Retrovisor) / Cabin (Rearview Mirror)
Cabina (Limpiaparabrisas Motor) / Cabin (Wiper Motor)
Cabina (Electrico Cableado) / Cabin (Electrical Wiring)
Cabina (Calentador) / Cabin (Heater)
Cabina (A/C 1) / Cabin (Air Conditioner 1)
Cabina (A/C 2) / Cabin (Air Conditioner 2)
Cabina (Acondicionador, Aire 3) / Cabin (Air Conditioner 3)
Techo De Lona (Luz) / Canopy (Light)
Etiqueta / Label
Accesorios / Accessories
Juego Protección Contra Caída Y Proyección De Piedras 1 [Option] / Kit Gravel Guard 1 [Option]
Juego Protección Contra Caída Y Proyección De Piedras 2 [Option] / Kit Gravel Guard 2 [Option]
Juego Protección Contra Caída Y Proyección De Piedras 3 [Option] / Kit Gravel Guard 3 [Option]
Juego Protección Contra Caída Y Proyección De Piedras 4 [Option] / Kit Gravel Guard 4 [Option]
Vál.Antirot.Tubo/Pesc. / Pipe-Break Valve/Boom
Vál.Antirot.Tubo/Brazo / Pipe-Break Valve/Arm
Vál.Antirot.Tubo/Cuchil / Pipe-Break Valve/Dozer
Juego De Acoplamientos Rápidos / Kit Plug-In Coupler
Juego De Acoplamientos Planos / Kit Flat-Face Coupler
Juego De Acoplamientos Filetados / Kit Screw-Type Coupler
Kit Luz Central / Kit Rotating Beacon
Kit Luz Central (Capot) / Kit Rotating Beacon (Canopy)
Kit Llave / Kit Key
Kit De Mordazas / Kit Clamshell
Soporte - Km205 / Mounting Brackets - Km205
Accesorio Martillo Hidráulico / Accessory Hydraulic Breaker
Kit Zumbador,Trasero / Kit Buzzer,Travel
Cambio Rápido Hidráulico / Quick Coupler Hydraulic
Juego Cambio Rápido Hidráulico / Kit Quick Coupler Hydraulic
Powertilt (Cambio Rápido Hidr.) / Powertilt (Quick Coupler Hydr.)
Juego Powertilt (Cambio Rápido Hidr.) / Kit Powertilt (Quick Coupler Hydr.)
Powertilt (Cambio Rápido Mec.) / (Quick Coupler Mech.)
Juego Powertilt (Cambio Rápido Mec.) / Kit Powertilt (Quick Coupler Mech.)
Kit De Sistemas De Enganche Rápido De Acción Dual / Kit Dual Action Quick Hitch Systems
