Kubota Mini Excavator U35-3ALPHA3 -85001 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U35-3ALPHA3 Mini Excavator
Serial Number: -85001
Number of Pages: 345 Pages
Control Lever (Lever Lh)
Pilot Valve (Component Parts) Lh
Control Lever (Rh)
Pilot Valve (Component Parts) Rh
Control Lever (Travel Lh) 1
Control Lever (Travel Lh) 2
Control Lever (Travel Rh) 1
Control Lever (Travel Rh) 2
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/ Swing Change) / Control Pedal (Swivel/ Swing Change)
Control Pedal (Swivel/ Swing Change 3) / Control Pedal (Swivel/ Swing Change 3)
Control Lever (Blade)
Control Valve (Component Parts)
Spool Section (Inlet)
Spool Section (Swivel)
Spool Section (Swing)
Spool Section (Blade)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Arm)
Spool Section (Travel Lh)
Spool Section (Travel Rh)
Spool Section (Boom)
Spool Section (Bucket)
Spool Section (Outlet)
Unload Valve
Unload Valve (Component Parts)
Change Valve
Valve (Sp)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Timer And Horn
Switch And Meter
Light
Wire Harness
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Head Cover
Engine Bracket
Camshaft And Idle Gear Shaft
Volante / Flywheel
Fuel Camshaft And Governor Shaft
Motor Parar Palanca / Engine Stop Lever
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Alternador / Alternator
Alternator (Component Parts)
Motor De Arranque / Starter
Starter (Component Parts)
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Exhaust Manifold
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Gasket Kit, Upper
Gasket Kit, Lower
Cover (Lh)
Cover (Rh)
Bonnet (Lh)
Bonnet (Rh)
Bonnet (Back)
Sponge (1)
Sponge (2)
Weight
Hoja / Seat
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Auto Idle Motor
Fuel Piping
Moist Separator (Component Parts)
Label
Maintenance Parts
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return 1)
Oil Piping (Return 2)
Oil Piping (Oil Cooler)
Oil Piping (Operation Lh)
Fuel Piping
Oil Piping (Operation Rh)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (Arm)
Oil Piping (S/P 1) / Oil Piping (S/P 1)
Oil Piping (S/P 2) / Oil Piping (S/P 2)
Canopy
Cabin (Sponge)
Cabin (Window 1)
Cabin (Window 2)
Cabin (Door)
Cabin (Wiper Motor)
Cabin (Accessories)
Cabin (Heater)
Pipe-Break Valve/Boom / Pipe-Break Valve/Boom
Pipe-Break Valve/Arm / Pipe-Break Valve/Arm
Pipe-Break Valve/Dozer / Pipe-Break Valve/Dozer
Warning System
Clamp Kit (Without Quick-Coupler)
Kit Flat-Face Coupler
Kit Plug-In Coupler
Kit Screw-Type Coupler
Bucket, Quick-Coupler
Gap-Kit 2
Kit Cover Bottom
Sp2 Kit Base
Sp2 Kit Boom
Retromatic Qc-Series13
Kit Hydraulic Breaker
Kit De Caja Negra / Kit Black Box
Soporte - Km200 / Mounting Brackets - Km200
Soporte - Km205 / Mounting Brackets - Km205
Juego Cambio Rápido Hidráulico(Cabina) / Kit Quick Coupler Hydraulic(Cabin)
Cambio Rápido Hidráulico / Quick Coupler Hydraulic
Pump Housing
Piston Pump (Component Parts)
Drive Moter And Component Parts (1)
Drive Moter And Component Parts (2)
Swivel Motor And Component Parts (1)
Swivel Motor And Component Parts (2)
Rotary Joint
Oil Tank
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Truck Frame
Idler
Track Roller
Crawler
Control Lever (Rh)
Spool Section (Arm)
Unload Valve
Change Valve
Valve (Sp)
Timer And Horn
Switch And Meter
Light
Wire Harness
Head Cover
Engine Bracket
Volante / Flywheel
Exhaust Manifold
Gasket Kit, Upper
Gasket Kit, Lower
Cover (Lh)
Cover (Rh)
Bonnet (Lh)
Bonnet (Rh)
Bonnet (Back)
Sponge (1)
Sponge (2)
Weight
Hoja / Seat
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Blade
Auto Idle Motor
Fuel Piping
Label
Maintenance Parts
Fuel Piping
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (Arm)
Canopy
Cabin (Sponge)
Cabin (Window 1)
Cabin (Window 2)
Cabin (Door)
Cabin (Wiper Motor)
Cabin (Accessories)
Cabin (Heater)
Warning System
Kit Plug-In Coupler
Gap-Kit 2
Kit Cover Bottom
Sp2 Kit Base
Sp2 Kit Boom
Pump Housing
Rotary Joint
Oil Tank
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Truck Frame
Idler
Track Roller
Crawler
