Kubota Mini Excavator U35-3ALPHA 70001-79999 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U35-3ALPHA Mini Excavator
Serial Number: 70001-79999
Number of Pages: 298 Pages
Cabin (Sponge)
Cabin (Window 1)
Cabin (Window 2)
Cabin (Door)
Cabin (Wiper Motor)
Cabin (Accessories)
Cabin (Heater)
Change Valve
Valve (Sp)
Control Lever (Lever Lh)
Pilot Valve (Component Parts) Lh
Control Lever (Lever Rh)
Pilot Valve (Component Parts) Rh
Control Lever (Travel Lh) 1
Control Lever (Travel Lh) 2
Control Lever (Travel Rh) 1
Control Lever (Travel Rh) 2
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/ Swing Change 1) / Control Pedal (Swivel/ Swing Change 1)
Control Pedal (Swivel/ Swing Change 2) / Control Pedal (Swivel/ Swing Change 2)
Control Lever (Blade)
Spool Section (Swivel)
Spool Section (Swing)
Spool Section (Blade)
Spool Section (Straight Travel)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Arm)
Spool Section (Travel Lh)
Spool Section (Travel Rh)
Spool Section (Boom) 2
Spool Section (Boom) 3
Spool Section (Bucket)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Timer Horn Relay Ai
Switch And Meter
Light
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Head Cover
Engine Bracket
Camshaft And Idle Gear Shaft
Volante / Flywheel
Motor Parar Palanca / Engine Stop Lever
Injection Pump (Component Parts)
Speed Control Plate
Motor De Arranque / Starter
Starter (Component Parts)
Alternator And Pulley
Alternator (Component Parts)
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Inlet Manifold Exhaust Manifold
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Gasket Kit Upper
Gasket Kit Lower
Maintenance Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Fuel Piping
Cover (Lh)
Cover (Rh)
Bonnet (Lh)
Bonnet (Rh)
Bonnet (Back)
Sponge (1) (S.No. <=75067)
Sponge (1) (S.No. >=75068)
Sponge (2) (S.No. <=75067)
Sponge (2) (S.No. >=75068)
Weight
Hoja / Seat
Label
Oil Piping (S/P 1) / Oil Piping (S/P 1)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return 1)
Oil Piping (Return 2)
Oil Piping (Oil Cooler)
Oil Piping (Operation Lh)
Oil Piping (Operation Rh)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel 1)
Oil Piping (Swing)
Oil Piping (Boom 1)
Oil Piping (Arm 1)
Oil Piping (Bucket 1)
Oil Piping (Blade)
Clamp (Oil Piping)
Oil Piping (S/P 2) / Oil Piping (S/P 2)
Canopy
Retromatic Cambio Rápido Serie13 / Retromatic Qc-Series13
Soporte - Km200 / Mounting Brackets - Km200
Pipe-Break Valve/Boom / Pipe-Break Valve/Boom
Pipe-Break Valve/Arm / Pipe-Break Valve/Arm
Pipe-Break Valve/Dozer / Pipe-Break Valve/Dozer
Warning System
Clamp Kit (Without Quick-Coupler)
Kit Flat-Face Coupler
Kit Plug-In Coupler
Juego De Acoplamientos Filetados / Kit Screw-Type Coupler
Pump Housing
Hydraulic Pump And Component Parts
Drive Moter And Component Parts (1)
Drive Moter And Component Parts (2)
Swivel Motor And Component Parts (1)
Swivel Motor And Component Parts (2)
Rotary Joint
Oil Tank
Control Valve (Component Parts)
Supply Unit
Supply Unit(Component Parts)
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Truck Frame
Idler
Track Roller
Crawler
Cabin (Sponge)
Cabin (Window 1)
Cabin (Window 2)
Cabin (Door)
Cabin (Wiper Motor)
Cabin (Accessories)
Cabin (Heater)
Change Valve
Valve (Sp)
Spool Section (Arm)
Timer Horn Relay Ai
Switch And Meter
Light
Head Cover
Engine Bracket
Volante / Flywheel
Speed Control Plate
Gasket Kit Upper
Gasket Kit Lower
Maintenance Parts
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Blade
Fuel Piping
Cover (Lh)
Cover (Rh)
Bonnet (Lh)
Bonnet (Rh)
Bonnet (Back)
Weight
Hoja / Seat
Label
Oil Piping (Swing)
Oil Piping (Boom 1)
Oil Piping (Arm 1)
Oil Piping (Blade)
Clamp (Oil Piping)
Canopy
Warning System
Kit Plug-In Coupler
Pump Housing
Rotary Joint
Oil Tank
Supply Unit
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Truck Frame
Idler
Track Roller
Crawler
