Kubota Mini Excavator U30-6 Only For Asian Market Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U30-6 Mini Excavator
Number of Pages: 311 Pages
Frequently Used Items
Crankcase
Oil Pan
Gear Case
Head Cover
Oil Filter
Oil Filler Flange
Engine Bracket
Main Bearing Case
Camshaft And Idle Gear Shaft
Piston And Crankshaft
Flywheel
Fuel Camshaft And Governor Shaft
Stop Solenoid
Governor
Speed Control Plate
Nozzle Holder And Glow Plug
Alternator (Component Parts)
Starter
Starter (Component Parts)
Water Flange And Thermostat
Tension Pulley
Water Pipe And Reserve Tank
Valve And Rocker Arm
Inlet Manifold
Exhaust Manifold
Air Cleaner
Muffler
Upper Gasket Kit
Lower Gasket Kit
Fuel Pump And Piping
Fuel Filter (Component Parts)
Separator (Component Parts)
Battery
Horn
Switch And Meter
Lamp
Electrical Wiring (1)
Electrical Wiring (2)
Pump Housing
Piston Pump
Piston Pump (Component Parts)
Drive Motor
Drive Motor (Component Parts)
Swivel Motor
Swivel Motor (Component Parts)
Rotary Joint
Rotary Joint (Component Parts)
Oil Tank (1)
Oil Tank (2)
Oil Filter
Control Valve (1)
Control Valve (2)
Control Valve (Component Parts)
Spool Section (Swivel)
Spool Section (Swing)
Spool Section (Blade)
Spool Section (P3 Inlet)
Spool Section (Ax1 )
Spool Section (Arm)
Spool Section (Travel Lh)
Spool Section (Inlet)
Spool Section (Travel Rh)
Spool Section (Boom)
Spool Section (Bucket)
Unload Valve
Unload Valve (Component Parts)
Super Change Valve
Super Change Valve (Component Parts)
Control Lever (Lh)
Pilot Valve Lh (Component Parts)
Control Lever (Rh)
Pilot Valve Rh (Component Parts)
Control Lever (Travel)
Pilot Valve (Travel)
Pilot Valve (Travel) (Component Parts)
Swing Pedal
Control Lever (Safety Lock Lever)
Control Lever (Blade)
Pedal (S/P) / Pedal (S/P)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Control Lh)
Oil Piping (Control Rh)
Oil Piping (Pilot P)
Oil Piping (Pilot T)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (S/P) / Oil Piping (S/P)
Stop Valve (Component Parts)
Oil Piping (Third Line Hydraulic Return)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Gear Case
Swing Bracket
Boom
Cylinder Cover
Arm
Bucket Link
Bucket
Blade
Track Frame
Idler In Assy
Track Roller
Crawler
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Cover (Lh)
Cover (Rh)
Bonnet (Lh)
Bonnet (Rh)
Bonnet (Rear)
Step
Bonnet (Center)
Sponge (1)
Sponge (2)
Weight
Canopy
Label
Crankcase
Oil Pan
Gear Case
Head Cover
Oil Filter
Oil Filler Flange
Engine Bracket
Main Bearing Case
Flywheel
Stop Solenoid
Governor
Speed Control Plate
Starter
Tension Pulley
Inlet Manifold
Exhaust Manifold
Air Cleaner
Muffler
Upper Gasket Kit
Lower Gasket Kit
Battery
Horn
Switch And Meter
Lamp
Pump Housing
Piston Pump
Drive Motor
Swivel Motor
Rotary Joint
Oil Tank (1)
Oil Tank (2)
Oil Filter
Control Valve (1)
Control Valve (2)
Spool Section (Arm)
Unload Valve
Super Change Valve
Control Lever (Lh)
Control Lever (Rh)
Swing Pedal
Oil Piping (Return)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Clamp)
Gear Case
Swing Bracket
Boom
Cylinder Cover
Arm
Bucket Link
Bucket
Blade
Track Frame
Idler In Assy
Track Roller
Crawler
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Cover (Lh)
Cover (Rh)
Bonnet (Lh)
Bonnet (Rh)
Bonnet (Rear)
Step
Bonnet (Center)
Sponge (1)
Sponge (2)
Weight
Canopy
Label
