Kubota Mini Excavator U25-3ALPHA 20001-59999 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U25-3ALPHA Mini Excavator
Serial Number: 20001-59999
Number of Pages: 451 Pages
Separador De Agua (Componente Piezas) / Water Separator (Component Parts)
Accesorios / Accessories
Aceite Tubos (Asupiracion) / Oil Piping (Suction)
Aceite Tubos (Entrega) / Oil Piping (Delivery)
Aceite Tubos (Acumulador) / Oil Piping (Accumulator)
Aceite Tubos (Devolver) / Oil Piping (Return)
Aceite Tubos (Aceite Refrigerador) / Oil Piping (Oil Cooler)
Aceite Tubos (Control Izquierdo) / Oil Piping (Control Lh)
Aceite Tubos (Control Derecho) / Oil Piping (Control Rh)
Aceite Tubos (Recorrido Izquierdo) / Oil Piping (Travel Lh)
Aceite Tubos (Recorrido Derecho) / Oil Piping (Travel Rh)
Aceite Tubos (Girar) / Oil Piping (Swivel)
Aceite Tubos (Oscilacion) / Oil Piping (Swing)
Aceite Tubos (Aguilon) / Oil Piping (Boom)
Aceite Tubos (Brazo) / Oil Piping (Arm)
Aceite Tubos (Cubo) / Oil Piping (Bucket)
Aceite Tubos (Lamina) / Oil Piping (Blade)
Aceite Tubos (Abrazadera) / Oil Piping (Clamp)
Aceite Tubos(Servicio Piezas) / Oil Piping (S/P)
Aceite Tubos (Tercera Linea Hidraulico Devolver) / Oil Piping (Third Line Hydraulic Return)
Juego Valvula (Aguilon) [Opcion] / Pipe-Break Valve (Boom) [Option]
Juego Valvula (Brazo) [Opcion] / Pipe-Break Valve (Arm) [Option]
Juego Valvula (Dormilon) [Opcion] / Pipe-Break Valve (Dozer) [Option]
Sistema De Aviso [Opcion] / Warning System [Option]
Kit Pinza (Sin Acoplamiento Rapido) [Opcion] / Clamp Kit (Without Quick-Coupler) [Option]
Kit Pinza (Con Acoplamiento Rapido) [Opcion] / Clamp Kit (With Quick-Coupler) [Option]
Acoplador,Juego [Opcion] / Kit Flat-Face Coupler [Option]
Kit D'acc.Rapidi [Opcion] / Kit Plug-In Couplerkit Plug-In Coupler [Option]
Juego Aco.Filetados [Opcion] / Kit Screw-Type Coupler [Option]
Oscilacion Soporte / Swing Bracket
Aguilon / Boom
Cilindro Cubierta (Aguilon) / Cylinder Cover (Boom)
Brazo / Arm
Brazo / Arm
Cubo Vinculo / Bucket Link
Cubo / Bucket
Lamina / Blade
Piezas De Mantenimiento / Maintenance Parts
Bomba Carcasa / Pump Housing
Accionar Motor Y Componente Piezas / Drive Motor And Component Parts
Girar Motor Y Componente Piezas / Swivel Motor And Component Parts
Tanque De Aceite / Oil Tank
Piston Bomba Componente Piezas / Piston Pump And Component Parts
Rotativo Junta / Rotary Joint
Aguilon Cilindro Y Componente Piezas / Boom Cylinder And Component Parts
Brazo Cilindro Y Componente Piezas / Arm Cylinder And Component Parts
Cubo Cilindro Y Componente Piezas / Bucket Cylinder And Component Parts
Lamina Cilindro Y Componente Piezas / Blade Cylinder And Component Parts
Oscilacion Cilindro Y Componente Piezas / Swing Cylinder And Component Parts
Acelerador Palanca / Accel Lever
Combustible Tubos / Fuel Piping
Combustible Filtro (Componente Piezas) / Fuel Filter (Component Parts)
Funcionamiento Caballete (Cuadro) / Control Lever (Frame)
Control Palanca(Palanca Izquierdo) / Control Lever (Lever Lh)
Piloto Valvula(Componente Piezas) / Pilot Valve (Component Parts)
Piloto Valvula (Componente Piezas) / Pilot Valve (Component Parts)
Control Palanca (Palanca Derecho) / Control Lever (Lever Rh)
Control Palanca (Recorrido Izquierdo) / Control Lever (Travel Lh)
Control Palanca (Recorrido Derecho) / Control Lever (Travel Rh)
Control Palanca (Cerradura Del Recorrido) / Control Lever (Travel Lock)
Control Palanca (Lamina) / Control Lever (Safety Lock Lever)
Control Pedal (Girar/Oscilacion Cambio 1) / Control Pedal (Swivel/Swing Change)
Control Palanca (Lamina) / Control Lever (Blade)
Control Palanca (Servicio Piezas) / Control Lever (S/P)
Control Valvula (Componente Piezas) / Control Valve (Component Parts)
Corredera Seccion (Recorrido) / Spool Section (Bucket)
Corredera Seccion(Recorrido) / Spool Section (Boom)
Corredera Seccion (Recorrido Derecho) / Spool Section (Travel Rh)
Corredera Seccion (Entrega) / Spool Section (Delivery)
Corredera Seccion (Recorrido Izquierdo) / Spool Section (Travel Lh)
Corredera Seccion(Recorrido) / Spool Section (Arm)
Corredera Seccion (Servicio Piezas) / Spool Section (S/P)
Corredera Seccion(Recorrido) / Spool Section (Swivel)
Corredera Seccion (Oscilacion) / Spool Section (Swing)
Corredera Seccion (Lamina) / Spool Section (Blade)
Corredera Seccion (Recorrido) / Spool Section (Pressure Regulating)
Cambio Valvula / Change Valve
Cambio Valvula (Componente Piezas) / Change Valve (Component Parts)
Techo De Lona / Canopy
Cabina (Carroceria) / Cabin (Body)
Cabina (Puerta) / Cabin (Door)
Cabina (Cerradura De La Puerta) / Cabin (Door Lock)
Cabina (Ventana) / Cabin (Window)
Cabina (Frente De La Ventana) / Cabin (Window Front)
Cabina (Esponja) / Cabin (Sponge)
Cabina (Reten Caucho) / Cabin (Seal Rubber)
Cabina (Limpiaparabrisas Motor) / Cabin (Wiper Motor)
Cabina (Electrico Cableado) / Cabin (Electrical Wiring)
Cabina (Calentador) / Cabin (Heater)
Cabina (Descongelador) / Cabin (Defroster)
Temporizador Y Claxon / Timer And Horn
Conmutador Y Metro / Switch And Meter
Luz / Light
Electrico Cableado / Electrical Wiring
Etiqueta / Label
Cubierta (Derecho) / Cover (Rh)
Esponja 2 / Sponge 2
Peso / Weight
Girar Bastidor / Swivel Frame
Arco Bastidor / Arch Frame
Girar Rodamiento / Swivel Bearing
Peldano / Step
Cubierta (Izquierdo) / Cover (Lh)
Cubierta (Deposito) / Cover (Tank)
Capo (Izquierdo) / Bonnet (Lh)
Capo (Derecho) / Bonnet (Rh)
Capo (Trasero) / Bonnet (Rear)
Esponja 1 / Sponge 1
Esponja 3 [Cabina] / Sponge 3 [Cabin]
Asiento / Seat
Asiento (Componente Piezas) / Seat (Component Parts)
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Volante / Flywheel
Tobera Soporte (Componente Piezas) / Nozzle Holder (Component Parts)
Alternador / Alternator
Alternador (Componente Piezas) / Alternator (Component Parts)
Motor De Arranque / Starter
Motor De Arranque (Componente Piezas) / Starter (Component Parts)
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Gr.Leva (Izquierdo) / Kit Knob (Lh)
Conj.Boton Pulsador / Kit Double Action Switch
Vál.Antirot.Tubo/Pesc. / Pipe-Break Valve/Boom
Vál.Antirot.Tubo/Brazo / Pipe-Break Valve/Arm
Vál.Antirot.Tubo/Cuchil / Pipe-Break Valve/Dozer
Sistema De Aviso / Warning System
Kit Pinza (Sin Acoplador) / Clamp Kit (Without Quick-Coupler)
Kit Pinza (Con Acoplador) / Clamp Kit (With Quick-Coupler)
Juego De Acoplamientos Planos / Kit Flat-Face Coupler
Juego De Acoplamientos Rápidos / Kit Plug-In Coupler
Juego De Acoplamientos Filetados / Kit Screw-Type Coupler
Kit Luz Central / Kit Rotating Beacon
Gap-Kit 3
Retromatic Cambio Rápido Serie12 / Retromatic Qc-Series12
Soporte - Km155 / Mounting Brackets - Km155
Kit Martillo Hidráulico / Kit Hydraulic Breaker
Caja Montaje / Kit Black Box
Tren De Orugas Bastidor / Track Frame
Rueda Loca / Idler
Tren De Orugas Rodillo / Track Roller
Oruga / Crawler
