Kubota Mini Excavator U20-3 -60001 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U20-3 Mini Excavator
Serial Number: -60001
Number of Pages: 323 Pages
Accesorios / Accessories
Aceite Tubos(Asupiracion) / Oil Piping (Suction)
Aceite Tubos (Entrega) / Oil Piping (Delivery)
Oil Piping (Accumulator)
Aceite Tubos (Devolver) / Oil Piping (Return)
Aceite Tubos (Aceite Refrigerador) / Oil Piping (Oil Cooler)
Aceite Tubos (Control Izquierdo) / Oil Piping (Control Lh)
Aceite Tubos (Control Derecho) / Oil Piping (Control Rh)
Aceite Tubos (Recorrido Izquierdo) / Oil Piping (Travel Lh) [Standard Track Type]
Aceite Tubos (Recorrido Izquierdo) / Oil Piping (Travel Lh) [Variable Track Gauge]
Aceite Tubos (Recorrido Derecho) / Oil Piping (Travel Rh) [Standard Track Type]
Aceite Tubos (Recorrido Derecho) / Oil Piping (Travel Rh) [Variable Track Gauge]
Aceite Tubos (Girar) / Oil Piping (Swivel)
Aceite Tubos (Oscilacion) / Oil Piping (Swing)
Aceite Tubos (Aguilon) / Oil Piping (Boom)
Aceite Tubos (Brazo) / Oil Piping (Arm)
Aceite Tubos (Cubo) / Oil Piping (Bucket)
Aceite Tubos (Lamina) / Oil Piping (Blade) [Standard Track Type]
Aceite Tubos (Lamina) / Oil Piping (Blade) [Variable Track Gauge]
Aceite Tubos(Tren De Orugas)[Galga Variable] / Oil Piping (Track) [Variable Track Gauge]
Aceite Tubos (Abrazadera) / Oil Piping (Clamp)
Aceite Tubos(Servicio Piezas 1) / Oil Piping (S/P)
Oil Piping (Third Line Hydraulic Return)
Oscilacion Soporte / Swing Bracket
Aguilon / Boom
Cilindro Cubierta (Aguilon) / Cylinder Cover (Boom)
Brazo / Arm
Cubo Vinculo / Bucket Link
Cubo / Bucket
Lamina / Blade [Standard Track Type]
Lamina / Blade [Variable Track Gauge]
Bomba Carcasa / Pump Housing
Piston Bomba Componente Piezas / Piston Pump Component Parts
Accionar Motor Y Componente Piezas / Drive Motor And Component Parts
Accionar Motor / Drive Motor And Component Parts
Girar Motor / Swivel Motor And Component Parts
Rotativo Junta / Rotary Joint [Standard Track Type]
Rotativo Junta / Rotary Joint [Variable Track Gauge]
Aceite Deposito(Placa) / Oil Tank
Palanca Del Acelerador / Accel Lever
Combustible Tubos / Fuel Piping
Combustible Filtro (Componente Piezas) / Fuel Filter (Component Parts)
Aguilon Cilindro / Boom Cylinder And Component Parts
Tren De Orugas Cilindro Y Componente Pie[Galga Variable] / Track Cylinder And Component Parts [Variable Track Gauge]
Brazo Cilindro / Arm Cylinder And Component Parts
Cubo Cilindro / Bucket Cylinder And Component Parts
Lamina Cilindro / Blade Cylinder And Component Parts
Oscilacion Cilindro / Swing Cylinder And Component Parts
Funcionamiento Caballete / Control Lever (Frame)
Control Palanca(Palanca Izquierdo) / Control Lever (Lever Lh)
Piloto Valvula (Componente Piezas) / Pilot Valve (Component Parts)
Control Palanca(Palanca Derecho)[Tipo Estandar] / Control Lever (Lever Rh)
Control Palanca(Recorrido Izquierdo) / Control Lever (Travel Lh)
Control Palanca(Recorrido Derecho) / Control Lever (Travel Rh)
Control Palanca(Cerradura Del Recorrido) / Control Lever (Travel Lock)
Control Recorrido Pedal / Control Travel Pedal
Cierre Con Llave La Palanca / Control Lever (Safety Lock Lever)
Control Pedal(Girar/Oscilacion Cambio) / Control Pedal (Swivel/Swing Change)
Control Palanca(Lamina) / Control Lever (Blade)
Control Palanca(Tren De Orugas)[Galga Variable] / Control Lever (Track) [Variable Track Gauge]
Control Palanca(Servicio Piezas) / Control Lever (S/P)
Techo De Lona / Canopy
Cabina(Carroceria) / Cabin (Body)
Cabina(Puerta) / Cabin (Door)
Cabina(Cerradura De La Puerta) / Cabin (Door Lock)
Cabina(Ventana) / Cabin (Window)
Cabina (Frente De La Ventana Superior) / Cabin (Window Front)
Cabina (Revestimiento) / Cabin (Sponge)
Cabina (Reten Caucho) / Cabin (Seal Rubber)
Cabina(Limpiaparabrisas Motor) / Cabin (Wiper Motor)
Cabina(Electrico Cableado) / Cabin (Electrical Wiring)
Cabina(Calentador) / Cabin (Heater)
Cabina (Desescarchador) / Cabin (Defroster)
Control Valvula [Componentes] / Control Valve (Component Parts)
Corredera Seccion(Recorrido) / Spool Section (Bucket)
Corredera Seccion(Recorrido) / Spool Section (Boom)
Corredera Seccion(Recorrido) / Spool Section (Travel Rh)
Corredera Seccion(Recorrido) / Spool Section (Delivery)
Corredera Seccion(Recorrido) / Spool Section (Travel Lh)
Corredera Seccion(Recorrido) / Spool Section (Arm)
Corredera Seccion(Recorrido) / Spool Section (S/P)
Corredera Seccion(Recorrido) / Spool Section (Swivel)
Corredera Seccion(Recorrido) / Spool Section (Swing)
Corredera Seccion(Recorrido) / Spool Section (Blade)
Corredera Seccion(Recorrido) / Spool Section (Track) [Variable Track Gauge]
Corredera Seccion(Recorrido) / Spool Section (Pressure Regulating)
Cambio Valvula / Change Valve
Cambio Valvula(Componente Piezas) / Change Valve (Component Parts)
Temporizador Y Claxon / Timer And Horn
Conmutador Y Metro / Switch And Meter
Luz / Light
Etiqueta / Label
Girar Bastidor / Swivel Frame
Arco Bastidor / Arch Frame
Girar Rodamiento / Swivel Bearing
Peldano / Step
Cubierta(Izquierdo) / Cover (Lh)
Cubierta(Derecho) / Cover (Rh)
Cubierta(Deposito) / Cover (Tank)
Capo(Izquierdo) / Bonnet Lh
Capo(Derecho) / Bonnet Rh
Capo Trasero / Bonnet Rear
Esponja 1 / Sponge 1
Esponja 2 / Sponge 2
Esponja 3 / Sponge 3 [Cabin]
Peso / Weight
Hoja / Seat
Asiento(Componente Piezas) / Seat (Component Parts)
Piezas De Mantenimiento / Maintenance Parts
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Volante / Flywheel
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Portainyector [Componentes] / Nozzle Holder (Component Parts)
Alternador / Alternator
Alternador [Componentes] / Alternator (Component Parts)
Motor De Arranque / Starter
Motor De Arranque [Componentes] / Starter (Component Parts)
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Tren De Orugas Bastidor / Track Frame [Standard Track Type]
Tren De Orugas Bastidor / Track Frame [Variable Track Gauge]
Rueda Loca / Idler
Camion Rodillo / Track Roller
Oruga / Crawler
Aguilon / Boom
Brazo / Arm
Cubo / Bucket
Luz / Light
Etiqueta / Label
Peldano / Step
Peso / Weight
Hoja / Seat
Volante / Flywheel
Rueda Loca / Idler
Oruga / Crawler
