Kubota Mini Excavator U10-5 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U10-5 Mini Excavator
Number of Pages: 263 Pages
Bloque Motor / Crankcase
Engrase La Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Volante / Flywheel
Inyeccion Bomba / Injection Pump
Portainyector (Componente Piezas) / Nozzle Holder (Component Parts)
Ventilador Y Dinamo / Fan And Dynamo
Dinamo (Componente Piezas) / Dynamo (Component Parts)
Motor De Arranque / Starter
Motor De Arranque (Componente Piezas) / Starter (Component Parts)
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Metal Y Rodamiento Kit / Upper Gasket Kit
Combustible Tubos / Fuel Piping
Combustible Filtro (Componente Piezas) / Fuel Filter (Component Parts)
Relé Y Cuerno / Relay And Horn
Conmutador Y Metro / Switch And Meter
Luz / Light
Electrico Cableado / Wire Harness
Antirrobo Alarma Sistema / Anti-Theft Alarm System
Bomba Carcasa / Pump Housing
Bomba De Engranaje (Componente Piezas) / Gear Pump (Component Parts)
Bomba Hidraulica (Componente Piezas) / Hydraulic Pump (Component Parts)
Accionar Motor Y Componente Piezas / Drive Motor And Component Parts
Girar Motor Y Componente Piezas / Swivel Motor And Component Parts
Rotativo Junta / Rotary Joint
Aceite Deposito / Oil Tank
Control Valvula (Componente Piezas) / Control Valve (Component Parts)
Corredera Seccion (Entrada 1) / Spool Section (Inlet 1)
Corredera Seccion (Recorrido 2) / Spool Section (Travel 2)
Corredera Seccion (Bastidor) / Spool Section (Swivel)
Corredera Seccion (Brazo) / Spool Section (Arm)
Corredera Seccion (Trasl.,Izda) / Spool Section (Travel Lh)
Corredera Seccion (Cuch. Empuje) / Spool Section (Blade)
Corredera Seccion (Servicio) / Spool Section (S/P)
Corredera Seccion (Trasl.,Dcha) / Spool Section (Travel Rh)
Corredera Seccion (Oscilacion) / Spool Section (Swing)
Corredera Seccion (Cazo) / Spool Section (Bucket)
Corredera Seccion (Brazo Princ.) / Spool Section (Boom)
Corredera Seccion (Entrada 2) / Spool Section (Inlet 2)
Cambio Valvula / Change Valve
Magnetico Valvula / Magnetic Valve
Valvula Del Solenoide / Solenoid Valve
Valvula Del Solenoide (Componente Piezas) / Solenoid Valve (Component Parts)
Funcionamiento Caballete / Control Lever (Frame)
Control Palanca(Palanca Izquierdo) / Control Lever (Lever Lh)
Piloto Valvula (Componente Piezas) / Pilot Valve (Component Parts)
Control Palanca (Palanca Derecho) / Control Lever (Lever Rh)
Control Palanca (Recorrido Izquierdo) / Control Lever (Travel Lh)
Control Palanca (Recorrido Derecho) / Control Lever (Travel Rh)
Control Recorrido Pedal / Control Travel Pedal
Cierre Con Llave La Palanca / Control Lever (Safety Lock Lever)
Control Pedal (Girar) / Control Pedal (Swing)
Control Palanca(Lamina) / Control Lever (Blade)
Control Palanca (Servicio Piezas) / Control Lever (S/P)
Aceite Tubos (Asupiracion) / Oil Piping (Suction)
Aceite Tubos (Acumulador) / Oil Piping (Accumulator)
Aceite Tubos (Devolver) / Oil Piping (Return)
Aceite Tubos (Control Izquierdo) / Oil Piping (Control Lh)
Aceite Tubos (Control Derecho) / Oil Piping (Control Rh)
Ducto De Aceite (Piloto P) / Oil Piping (Pilot P)
Ducto De Aceite (Piloto T) / Oil Piping (Pilot T)
Aceite Tubos (Recorrido Izquierdo) / Oil Piping (Travel Lh)
Aceite Tubos (Recorrido Derecho) / Oil Piping (Travel Rh)
Aceite Tubos (Girar) / Oil Piping (Swivel)
Aceite Tubos (Oscilacion) / Oil Piping (Swing)
Aceite Tubos (Aguilon) / Oil Piping (Boom)
Aceite Tubos (Brazo) / Oil Piping (Arm)
Aceite Tubos (Cubo) / Oil Piping (Bucket)
Aceite Tubos (Lamina) / Oil Piping (Blade)
Aceite Tubos (Tren De Orugas) / Oil Piping (Track)
Aceite Tubos (Servicio Piezas) / Oil Piping (S/P)
Aguilon Cilindro Y Componente Piezas / Boom Cylinder And Component Parts
Brazo Cilindro Y Componente Piezas / Arm Cylinder And Component Parts
Cubo Cilindro Y Componente Piezas / Bucket Cylinder And Component Parts
Lamina Cilindro Y Componente Piezas / Blade Cylinder And Component Parts
Oscilacion Cilindro Y Componente Piezas / Swing Cylinder And Component Parts
Tren De Orugas Cilindro Y Componente Piezas / Track Cylinder And Component Parts
Oscilacion Soporte / Swing Bracket
Aguilon / Boom
Brazo / Arm
Cubo Vinculo / Bucket Link
Cubo / Bucket
Lamina / Blade
Tren De Orugas Bastidor / Track Frame
Rueda Loca / Idler
Camion Rodillo / Track Roller
Girar Bastidor / Swivel Frame
Girar Engranaje Caja / Swivel Gear Case
Girar Rodamiento / Swivel Bearing
Peldano / Step
Cubierta(Izquierdo) / Cover (Lh)
Cubierta(Derecho) / Cover (Rh)
Cubierta(Adelante) / Cover (Front)
Capo / Bonnet
Esponja / Sponge
Peso / Weight
Hoja / Seat
Techo De Lona / Canopy
Etiqueta / Label
Accesorios / Accessories
Kit De Registro Chaveta De Ath [Opción] / Ath Key Register Kit [Option]
Kit Faro Rotativo Naranja [Opción] / Orange Beacon Kit [Option]
Recorrido Alarma Kit [Opción] / Travel Alarm Kit [Option]
Kit Arco Seguridad Delantero [Opción] / Front Rops Kit [Option]
