652
1,893,758
Kubota Mini Excavator U-45 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U-45 Mini Excavator
Number of Pages: 279 Pages
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Head Cover
Engine Bracket
Camshaft And Idle Gear Shaft
Volante / Flywheel
Fuel Camshaft And Governor Shaft
Motor Parar Palanca / Engine Stop Lever
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Alternador / Alternator
Alternator (Component Parts)
Motor De Arranque / Starter
Starter (Component Parts)
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Exhaust Manifold
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Accel Lever
Fuel Piping
Fuel Filter (Component Parts)
Timer And Horn
Conmutador Y Metro / Switch And Meter
Bomba Carcasa / Pump Housing
Piston Pump (Component Parts)
Drive Motor And Component Parts
Swivel Motor And Component Parts
Rotary Joint
Oil Tank
Control Valve (Component Parts)
Spool Section (Bucket)
Spool Section (Boom)
Spool Section (Travel Rh/Spacer) / Spool Section (Travel Rh/Spacer)
Spool Section (Travel Lh)
Spool Section (Arm)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Travel Straight)
Spool Section (Blade/Swing) / Spool Section (Blade/Swing)
Spool Section (Swivel)
Unload Valve
Unload Valve (Component Parts)
Control Lever (Frame)
Control Lever (Lever Lh)
Pilot Valve (Component Parts)
Control Lever (Lever Rh)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/Swing Change) / Control Pedal (Swivel/Swing Change)
Control Lever (Blade)
Fuel Piping
Control Lever (S/P 1) / Control Lever (S/P 1)
Control Lever (S/P 2) / Control Lever (S/P 2)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Control Lh)
Oil Piping (Control Rh)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (S/P) / Oil Piping (S/P)
Aguilon Cilindro Y Componente Piezas / Boom Cylinder And Component Parts
Brazo Cilindro Y Componente Piezas / Arm Cylinder And Component Parts
Cubo Cilindro Y Componente Piezas / Bucket Cylinder And Component Parts
Lamina Cilindro Y Componente Piezas / Blade Cylinder And Component Parts
Oscilacion Cilindro Y Componente Piezas / Swing Cylinder And Component Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket Pin
Blade
Track Frame
Idler
Track Roller
Crawler
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Cover (Lh)
Cover (Rh)
Cover (Tank)
Capo / Bonnet
Sponge
Weight
Hoja / Seat
Cabin (Body)
Cabina(Puerta) / Cabin (Door)
Cabin (Door Lock 1)
Cabin (Door Lock 2)
Cabina(Ventana 1) / Cabin (Window 1)
Cabina(Ventana 2) / Cabin (Window 2)
Cabin (Sponge)
Cabin (Seal Rubber)
Cabin (Wiper Motor)
Cabin (Electrical Wiring)
Cabin (Heater)
Label
