652
1,893,758
Kubota Mini Excavator U-35 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U-35 Mini Excavator
Number of Pages: 315 Pages
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Head Cover
Engine Bracket
Camshaft And Idle Gear Shaft
Volante / Flywheel
Fuel Camshaft And Governor Shaft
Stop Solenoid
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Nozzle Holder (Component Parts)
Alternador / Alternator
Alternator (Component Parts)
Motor De Arranque / Starter
Starter (Component Parts)
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Exhaust Manifold
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Accel Lever
Fuel Piping
Fuel Filter (Component Parts)
Timer And Horn
Conmutador Y Metro / Switch And Meter
Light
Bomba Carcasa / Pump Housing
Piston Bomba Componente Piezas / Piston Pump Component Parts
Drive Motor And Component Parts
Swivel Motor And Component Parts
Rotary Joint
Oil Tank
Control Valve (Component Parts)
Spool Section (Bucket)
Spool Section (Boom)
Spool Section (Travel Rh/Spacer) / Spool Section (Travel Rh/Spacer)
Timer And Horn
Spool Section (Travel Lh)
Spool Section (Arm)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Travel Straight)
Spool Section (Blade/Swing) / Spool Section (Blade/Swing)
Spool Section (Swivel)
Change Valve
Change Valve (Component Parts)
Control Lever (Frame)
Control Lever (Lever Lh)
Pilot Valve (Component Parts)
Control Lever (Lever Rh)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/Swing Change) / Control Pedal (Swivel/Swing Change)
Control Lever (Blade)
Control Lever (S/P 1) / Control Lever (S/P 1)
Control Lever (S/P 2) / Control Lever (S/P 2)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Control Lh)
Oil Piping (Control Rh)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Track Frame
Idler
Track Roller
Crawler
Swivel Frame
Arch Frame
Swivel Bearing
Seat Support
Step
Cover (Lh)
Crawler
Cover (Rh)
Cover (Tank)
Capo / Bonnet
Sponge (1) [Canopy]
Sponge (1) [Cabin]
Sponge (2)
Weight
Hoja / Seat
Canopy
Cabin (Body)
Cabina(Puerta) / Cabin (Door)
Cabin (Door Lock 1)
Cabin (Door Lock 2)
Cabina(Ventana 1) / Cabin (Window 1)
Cabina(Ventana 2) / Cabin (Window 2)
Cabin (Sponge)
Cabin (Seal Rubber)
Cabin (Wiper Motor)
Cabin (Electrical Wiring)
Cabin (Heater)
Label
