Kubota Mini Excavator U-10ALPHA Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U-10ALPHA Mini Excavator
Number of Pages: 219 Pages
Crank Case
Oil Pan
Gear Case
Head Cover
Engine Bracket
Main Bearing Case
Camshaft And Idle Gear Shaft
Piston And Crankshaft
Flywheel
Fuel Camshaft And Governor Shaft
Stop Solenoid
Governor
Gear Case
Speed Control Plate
Nozzle Holder And Glow Plug
Nozzle Holder (Component Parts)
Fan And Dynamo
Dynamo (Component Parts)
Starter
Starter (Component Parts)
Water Flange And Thermostat
Water Pipe
Valve And Rocker Arm
Inlet Manifold
Exhaust Manifold
Air Cleaner
Muffler
Accel Lever
Fuel Piping
Fuel Filter (Component Parts)
Battery
Timer And Horn
Switch And Meter
Electrical Wiring
Pump Housing
Gear Pump (Component Parts)
Drive Motor
Drive Motor (Component Parts)
Swivel Motor And Component Parts
Rotary Joint
Oil Tank
Control Valve
Timer And Horn
Control Valve (Component Parts)
Spool Section (Swivel)
Spool Section (Arm)
Spool Section (Travel Lh)
Spool Section (Blade)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Travel Rh)
Spool Section (Swing)
Spool Section (Bucket)
Spool Section (Boom)
Change Valve
Control Lever (Frame)
Control Lever (Lever Lh)
Control Lever (Lever Rh)
Control Lever (Travel)
Control Lever (Swivel)
Control Lever (Boom/Bucket) / Control Lever (Boom/Bucket)
Control Lever (Arm)
Control Lever (Safety Lock Lever)
Control Lever (Swing Pedal)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Oil Piping (Suction)
Oil Piping (Return)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Track)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Track Cylinder And Component Parts
Swing Bracket
Boom
Arm
Bucket Link
Blade
Track Frame
Idler
Track Roller
Swivel Frame
Swivel Gear Case
Swivel Bearing
Step
Cover (Front)
Bonnet
Sponge
Weight
Label
Crank Case
Oil Pan
Gear Case
Head Cover
Engine Bracket
Main Bearing Case
Flywheel
Stop Solenoid
Governor
Gear Case
Speed Control Plate
Fan And Dynamo
Starter
Water Pipe
Inlet Manifold
Exhaust Manifold
Air Cleaner
Muffler
Accel Lever
Fuel Piping
Battery
Timer And Horn
Switch And Meter
Electrical Wiring
Pump Housing
Drive Motor
Rotary Joint
Oil Tank
Control Valve
Timer And Horn
Spool Section (Arm)
Change Valve
Control Lever (Arm)
Oil Piping (Return)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Track)
Swing Bracket
Boom
Arm
Bucket Link
Blade
Track Frame
Idler
Track Roller
Swivel Frame
Swivel Gear Case
Swivel Bearing
Step
Cover (Front)
Bonnet
Sponge
Weight
Label
