Kubota Mini Excavator U-10 Spare Parts Catalog EN ES
Language: English, Spanish
Model: Kubota U-10 Mini Excavator
Number of Pages: 237 Pages
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Head Cover
Engine Bracket
Camshaft And Idle Gear Shaft
Volante / Flywheel
Fuel Camshaft And Governor Shaft
Stop Solenoid
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Nozzle Holder (Component Parts)
Accel Lever
Fuel Piping
Fuel Filter (Component Parts)
Fan And Dynamo
Dynamo (Component Parts)
Motor De Arranque / Starter
Starter (Component Parts)
Timer And Horn
Switch And Meter
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Aire Limpiador / Air Cleaner
Exhaust Manifold
Silenciador / Muffler
Pump Housing
Piston Pump (Component Parts)
Drive Motor
Drive Motor (Component Parts)
Swivel Motor And Component Parts
Rotary Joint
Oil Tank
Control Valve (Component Parts)
Spool Section (Swivel)
Spool Section (Arm)
Spool Section (Travel Lh)
Spool Section (Blade)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Travel Rh)
Spool Section (Bucket)
Spool Section (Boom)
Spool Section (Swing)
Change Valve
Control Lever (Frame)
Control Lever (Lever Lh)
Control Lever (Lever Rh)
Control Lever (Travel)
Control Lever (Safety Lock Lever)
Control Lever (Swivel)
Control Lever (Swing)
Control Lever (Boom/Bucket) / Control Lever (Boom/Bucket)
Control Lever (Arm)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Oil Piping (Suction)
Oil Piping (Return)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Track)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Track Cylinder And Component Parts
Swing Bracket
Boom
Arm
Bucket Link
Blade
Track Frame
Idler
Track Roller
Swivel Frame
Swivel Gear Case
Swivel Bearing
Step
Cover (Front)
Capo / Bonnet
Sponge
Weight
Hoja / Seat
Label
Head Cover
Engine Bracket
Volante / Flywheel
Stop Solenoid
Accel Lever
Fuel Piping
Fan And Dynamo
Timer And Horn
Switch And Meter
Exhaust Manifold
Pump Housing
Drive Motor
Rotary Joint
Oil Tank
Spool Section (Arm)
Change Valve
Control Lever (Arm)
Oil Piping (Return)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Track)
Swing Bracket
Boom
Arm
Bucket Link
Blade
Track Frame
Idler
Track Roller
Swivel Frame
Swivel Gear Case
Swivel Bearing
Step
Cover (Front)
Capo / Bonnet
Sponge
Weight
Hoja / Seat
Label
