Kubota Loader LA514 Assembly Instructions
Type of Machine: Loader
Type of Manual: Assembly Instructions
Model: Kubota LA514 Loader
Number of Pages: 30 Pages
ASSEMBLY INSTRUCTIONS
TO THE DEALER
SAFETY
UNPACKING AND CHECKING PARTS
B Unpacking Wooden Crate
1. Cutting metal bands (if two are banded together). Metal bands hold the two crates together as ...
2. Unpacking the crates
(1) Hook a hoist to the 4 corners of the crate and raise the hoist cable until taut. This serves ...
(2) Saw the crate as indicated in the figure 1.
A Sawing outside the indicated area may damage the loader or accessory parts.
A Be sure that the crate is free of other obstructions (e.g. nails, staples and etc.).
(3) Raise the upper part of the crate and remove from the immediate area.
(4) Remove the remaining slats from the crate. These are indicated by the oblique lines in Figure...
B Checking Parts
TRACTOR PREPARATION
ASSEMBLY
B Boom Assembly
To avoid personal injury:
A Do not operate or mount loader without quick attach or bucket installed to loader. Damage may o...
1. Attach the bucket to the boom and bucket links as shown.
2. Raise the boom until the stands can be rotated.
3. Remove the spring pins holding the stands to the boom.
4. Rotate the stands until the pin on the stand and hole in the boom are aligned. Then slide the ...
B Boom Assembly with Quick Hitch (Option)
1. Attach the quick hitch to the boom and bucket links as shown.
B Level Indicator (LA514)
1. Attach the level indicator.
B Main Frame
1. Remove plastic plugs and any excess paint from tractor body bolt locations.
2. Attach the main frame LH and RH to the flywheel housing and tractor frame as shown.
1. Remove the air conditioner hose clamp from the side of the clutch case.
2. Install the loader main frame, and using the cord band, secure the air conditioner hoses out o...
A When installing the main frame, be careful not to get the air conditioner hoses caught. With th...
3. Secure the controller cable out of contact with the sub frame, using the cord band.
B Sub Frame
1. Attach the sub frame to the main frame as shown.
A There are the three holes left at the sub frame. These three holes will be used when installing...
2. Attach the rear of sub frames to the rear brackets as shown.
B Front Guard
1. Remove the front bumper from the front axle frame, if equipped.
2. Attach the front guard to the front axle frame.
3RD FUNCTION (OPTION)
B Inlet Tube Disassembly
1. Remove the rear tire RH and fender RH. Remove also the front loader main frame and sub frame, ...
2. Drain the oil completely from the drain plug.
3. Remove the coupler stay mounting bolts.
4. Loosen the valve tubes.
5. Disconnect the valve tank tube.
A Be careful not to lose the copper packings when disconnecting the tractor hydraulic tubes.
6. Remove the brake rod RH.
7. Remove the bearing flange and joint cover.
8. Remove the bolt and draw out the universal joint from the joint shaft.
A Pull the universal joint out of the joint shaft. Temporarily reapply the bolt in its original p...
9. Disconnect the inlet tube.
A O-ring will be used again. Be sure to handle it with care and not to lose it.
B Inlet 3rd Tube Assembly
1. Connect the inlet 3rd tube and inlet hose. Temporarily connect the inlet hose. Do not tighten ...
(1) Be sure to put the O-ring to the inlet 3rd tube.
(2) Be sure to put the rubber in between the inlet 3rd tube and the metal fitting.
A Tighten the bolts to their respective specified torques.
2. Connect the tank tube and tank hose.
A Orient the tank hose toward the tractor front, as shown below. Make sure the hose is out of con...
3. Temporarily connect the power beyond tube and power beyond hose in their respective positions.
4. Attach the metal fitting and secure the tank tube and power beyond tube.
A With the power beyond tube and tank tube temporarily connected and secured with the metal fitti...
5. Tighten the power beyond tube and power beyond hose.
6. Attach the brake rod RH.
A Split the split pins on both sides as shown below.
7. Remove the temporarily applied bolt. Fit the universal joint into the joint shaft. Temporarily...
8. Attach the bearing flange and joint cover and tighten them with bolts.
A Before tightening the bolts, make sure the joint is out of contact with nearby parts.
9. Attach the front loader and main frame RH.
(1) Keep all the bolts temporarily tight.
(2) See "Main Frame" section for setting up.
10. Tighten the valve tubes.
11. Attach 3rd function assembly to the frond loader and sub frame RH.
12. Connect hoses to the 3rd function assembly.
13. Install the coupler stay and connect the hydraulic hose A and 3rd function assembly to the co...
B 3rd Function Lever Section (ROPS Model)
1. Remove the original lever.
2. Detach the grip and lever boot from the original lever.
3. Cut the detached lever boot as shown below.
4. Remove the bolt and nut, and then take out the lever assembly.
5. Remove the sleeve and rod from the lever assembly and fit them to the control lever 2.
(1) Make sure to put the sleeve to the control lever 2.
(2) Apply Loctite 271 or equivalent in fitting the rod into position.
6. Attach the lever boot to the control lever assembly.
A Make sure not to get the lever harness twisted.
7. Temporarily attach the control lever 2 to the control lever assembly.
(1) Screw in the control lever assembly as deep as possible.
(2) Do not yet get the nut locked. (3) Apply Loctite 271 or equivalent in fitting the rod into po...
8. Install the 3rd function lever assembly.
A Apply Loctite 271 or equivalent in fitting the rod into position.
C Wire Harness
A Connect the wire harness couplers of the 3rd function control lever to their respective same-co...
9. Connect the 3rd function harness with tractor harness.
10. Pass the 3rd function harness through the lever console. Connect the 3rd function control lev...
(1) Using the cord band, secure the 3rd function harness and the tractor harness onto the floor s...
(2) Move the control lever to make sure it does not catch or drag the harnesses.
11. Connect the harness to the solenoid valve harness and attach the cover.
12. Attach the tractor fender RH.
A With the fender in place, move the lever to make sure it is out of contact with the fender and ...
13. Attach the rear tire RH.
14. Apply rubber type bond to the boot and attach the boot to the lever guide.
B 3rd Function Lever Section (CAB Model)
2. Detach the lever boot from the original lever.
4. Detach the upper console.
5. Detach the lower console.
6. Remove the rubber cap from the hole under the seat. Make the 18 mm diameter hole.
A Just scrape the hole large enough to pass the harness, if desired.
7. Attach the detached lever boot to the control lever assembly (CAB) and install it to the tractor.
8. Slit the rubber cap crosswise and pass the harness through it.
9. Lay the harness (at the solenoid valve side) out of the cabin. Then make necessary connections...
A Make sure the harness is out of contact with other parts and not too tight.
C Wire Harness
10. Put the lower and upper consoles back into position in the reverse order of removal.
A Make sure the harness and other parts are not caught between the upper and lower consoles.
A Move the control lever and make sure the harness is not caught by the lever or other parts and ...
B 3rd Function Boom Section
1. Attach the coupler stay to the boom.
2. Fit the 3rd function tube 1 and 2 to the boom.
3. Connect the 3rd function tube 1 and 2 to the mid hydraulic hose.
4. Front hydraulic valve main switch Push the front hydraulic valve main switch (1) to engage the...
5. Activation switch
(1) When pressing the "A" button, hydraulic oil will come out of the port A and return through th...
(2) When pressing the "B" button hydraulic oil will come out of the port B and return through the...
6. Push the front hydraulic valve main switch again to disengage the front hydraulic valve, and t...
PRE-OPERATION CHECK
B Lubrication
B Transmission Fluid
A To check the tractor transmission fluid level, lower the bucket to the ground and lower the 3-p...
B Hydraulic Hose Route
ESTIMATED ASSEMBLY TIME
TIGHTENING TORQUE OF BOLTS AND NUTS
TO THE DEALER
SAFETY
B Checking Parts
TRACTOR PREPARATION
ASSEMBLY
B Boom Assembly
B Main Frame
B Sub Frame
B Front Guard
C Wire Harness
C Wire Harness
PRE-OPERATION CHECK
B Lubrication
