Kubota Lawn Tractor T1600H-EUROPE Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Tractor
Model: Kubota T1600H-EUROPE Lawn Tractor
Number of Pages: 102 Pages
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Pistons/Vilebrequin / Piston/Crankshaft
Volant Moteur / Flywheel
Culasse / Cylinder Head
Soupapes/Culbuteurs / Valve/Rocker Arm
Injecteurs Et Tuyauteries / Nozzle Holder
[Component Parts]
[Component Parts]
Couvercle De Culasse / Head Cover
Collecteur / Inlet Manifold
Filtre A Air / Air Cleaner
Silencieux / Muffler
Arbre A Cames / Camshaft
Pompe A Eau / Water Pump
Bride / Water Flange
Plaque De Limiteur De Vitesse / Speed Contro L Plate
Regulateur De Pression / Governor
Trousse De Joint / Upper Gasket Kit
Trousse De Joint / Lower Gasket Kit
Tuyau Carburant / Fuel Pipe
Tuyau D'eau / Water Pipe
Radiateur / Radiator
Ventilateur / Fan
Ventilateur / Fan
Alternateur/Demarreu R / Dynamo/Starter
[Component Parts]
[Component Parts]
Batterie / Battery
Batterie / Battery
Batterie / Battery
Lampe / Light
Lampe / Light
Tableau Bord / Dashb Oard
Faisceau Electrique / Wire Harness
Hst Trans-Essieu / Hst Transaxle
[Component Parts]
[Component Parts]
Joint De Cardan/Hst Ventilateur / Universal Joint/Hst Fan
Arbre De Prise De Force / Pto Shaft
Poulie De Tension / Tension Pulley
Courroie Retenue / Belt Retainer
Bielle De Changement De Vitesse / Speed Change Rod
Pedale De Changement De Vitesse / Speed Change Pedal
(15 X 6.00-6)
(15 X 6.00-6)
Tige De Frein / Brake Rod
Pedale De Frein / Brake Pedal
Pont Avant / Front Axle
Chassis / Frame
Direction / Steering
Levier De Relevage / Lift Lever
Biellette De Relevage / Lift Link
Biellette / Link
Biellette / Link
Capot / Hood
Capot / Hood
Planche / Panel
Planche / Panel
Planche / Panel
Aile / Fender
Aile / Fender
Siege / Seat
[C A Fr Uk Sw G]
[C A Fr Uk Sw G]
[Component Parts]
[Component Parts]
Ventilateur / Fan
Ventilateur / Fan
[Component Parts]
[Component Parts]
Batterie / Battery
Batterie / Battery
Batterie / Battery
Lampe / Light
Lampe / Light
[Component Parts]
[Component Parts]
(15 X 6.00-6)
(15 X 6.00-6)
Chassis / Frame
Biellette / Link
Biellette / Link
Capot / Hood
Capot / Hood
Planche / Panel
Planche / Panel
Planche / Panel
Aile / Fender
Aile / Fender
Siege / Seat
[C A Fr Uk Sw G]
[C A Fr Uk Sw G]
