Kubota Lawn Tractor T1400H-UK EUROPE Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Tractor
Model: Kubota T1400H-UK EUROPE Lawn Tractor
Number of Pages: 91 Pages
Bloc Moteur / Crankcase
Piston/Vilebrequin / Piston/Crankshaft
Arbre A Cames / Camshaft
Culbuteur / Rocker Arm
Reniflard / Breather
Silencieux / Muffler
Carburateur / Carburettor
[Component Parts]
[Component Parts]
Aimant / Magneto
Aimant / Magneto
Arbre De Compensateur / Balancer Shaft
Filtre A L'huile / Oil Filter
Carter De Lanceur / Fan Cover
Plaque De Limiteur De Vitesse / Speed Con Trol Plate
[Component Parts]
Reservoir Carb. / Fuel Tank
Filter A Air / Air Cleaner
Batterie / Battery
Batterie / Battery
Phare / Light
Phare / Light
Tableau Bord / Dash Board
Faisceau Electrique / Wire Harness
Hst/Arbre D'engrenage Conique / Hst/Bevel Gear Shaft
Hst / Hst
[Component Parts]
[Component Parts]
[Component Parts]
[Component Parts]
[Component Parts]
[Component Parts]
[Component Parts]
Carter De Differentiel / Diff Erential Case
Poulie De Tension / Tension P Ulley
Pedale De Changement De Vites Se / Speed Change Pedal
Bras De Changement De Vitesse / Speed Change Arm
Axe Arriere / Rear Axle
Bride D'essie U Arriere / Rear Axle Flange
Hst / Hst
Pont Avant / Front Axle
Roue Arriere( 18x8,50-8)/Roue Avant(14x5,00-6) / Rear Wheel(18x8. 50-8)/Front Wheel(14x5.00-6)
Pedale De Frien / Brake Pedal
Tige De Frein / Brake Rod
Frein / Blake
Direction / Steering
Levier De Relevage / Lift Lever
Biellette De Relevage / Lift Link
Biellette De Tondeuse / Mower Lin K
Capot / Hood
Panneau / Panel
Panneau / Panel
Aile / Fender
Aile / Fender
Chassis / Frame
Chassis / Frame
Marche De Siege / Step Seat
Etiquette / Label
Etiquette / Label
Accessoires / Accessories
