Kubota Lawn Tractor T1400 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Lawn Tractor
Model: Kubota T1400 Lawn Tractor
Number of Pages: 73 Pages
B Loc Moteur / Crankcase
P Iston/Vilebrequin / Piston/Crankshaft
A Rbre A Cames / Camshaft
C Ulbuteur / Rocker Arm
R Eniflard / Breather
S Ilencieux / Muffler
C Arburateur / Carburettor
[Component Parts]
[Component Parts]
[Component Parts]
A Imant / Magneto
A Rbre De Compensateur / Balancer Shaft
F Iltre A L'huile / Oil Filter
C Arter De Lanceur / Fan Cover
P Laque De Limiteur De Vitesse / Speed Control Plate
[Compo Nent Parts]
R Egulateur De Vitesses / Governor
Reservoir Carb. / Fuel Tank
Filter A Air / Air Cleaner
Batterie / Battery
Batterie / Battery
Phare / Light
Tableau Bord / Dashboard
Faisceau Electrique / Wire Har Ness
Carter De Transmission / Transmission Ca Se
Arbre D'engrenage Conique / Bevel Gear S Haft
Carter De Differentiel / Differential Ca Se
Poulie De Tension / Tension Pulley
Courroie De Changement De Vitesse / Spee D Change Belt
Levier De Changement De Vitesse / Speed Change Pedal
Bras De Changement De Vitesse / Speed Ch Ange Arm
Pont Avant / Front Axle
Roue Arriere(18x8,50-8)/ Roue Avant(14x5,00-6) / Rear Wheel(18x8.50-8)/Front Wheel(14x5.00-6)
Ped Ale De Frien / Brake Pedal
Tig E De Frein / Brake Rod
Fre In / Blake
Fre In / Blake
Direction / Steering
Levier De Relevage / Lift Lever
Biellette De Relevage / Lift Link
Biellette De Tondeuse / Mower Link
Capot / Hood
Capot / Hood
Capot / Hood
Panneau / Panel
Panneau / Panel
Aile / Fender
Aile / Fender
Chassis / Frame
Chassis / Frame
Chassis / Frame
Marche De Siege / Step Sea T
Siege / Seat
E Tiquette / Label
E Tiquette / Label
Accessoires / Accessories
