Kubota Lawn Mower ZD326-EU_Merged Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota ZD326-EU_Merged Lawn Mower
Number of Pages: 285 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivel / Dipstick And Guide
Piston Y Ciguenal / Piston And Crank Shaft
Volante / Flywheel
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Tobera Soporte (Componente Piezas) / Nozzle Holder (Component Parts)
Cubierta / Cover
Dinamo Y Polea / Dynamo And Pulley
Dinamo (Componente Piezas) / Dynamo (Component Parts)
Motor De Arranque / Starter
Motor De Arranque (Componente Piezas) / Starter (Component Parts)
Aceite Conmutador Y Sensor / Oil Switch And Thermometer
Agua Bomba / Water Pump
Ventilador / Fan
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Colector Kit [Opcion] / Manifold Kit [Option]
Kit Junta Superior [Opcion] / Upper Gasket Kit [Option]
Kit Junta Inferior [Opcion] / Lower Gasket Kit [Option]
Tubo De Combustible (Adelante) / Fuel Hose (Front)
Tubo De Combustible (Trasero) / Fuel Hose (Rear)
Agua Manguito / Water Hose
Red Radiador / Radiator Net
Interruptor Arranque/Metro/Sensor / Starter Switch/Meter/Sensor
Interruptor/Controlador/Rele / Switch/Controller/Relay
Mazo Cables / Wire Harness
Kit Luz Para Trabajo [Opcion] / Work Light Kit [Option]
Embrague / Clutch
Caja Centro / Center Case
Cubierta Centro (Adelante) / Center Cover (Front)
Cubierta Centro (Trasero) / Center Cover (Rear)
Carga Bomba (Componente Piezas) / Charge Pump (Component Parts)
Hst
Hst Dr 1 (Componente Piezas) / Hst Rh 1 (Component Parts)
Hst Dr 2 (Componente Piezas) / Hst Rh 2 (Component Parts)
Hst Dr 3 (Componente Piezas) / Hst Rh 3 (Component Parts)
Hst Iz 1 (Componente Piezas) / Hst Lh 1 (Component Parts)
Hst Iz 2 (Componente Piezas) / Hst Lh 2 (Component Parts)
Hst Iz 3 (Componente Piezas) / Hst Lh 3 (Component Parts)
Eje De Embrague / Clutch Shaft
Eje De Entrada / Input Shaft
Junta Universal/Ventilador / Universal Joint/Fan
Eje De Junta / Joint Shaft
Eje / Axle
Varilla De Freno / Brake Rod
Estacionamiento Freno Pedal / Parking Brake Pedal
Palanca De Control Dr / Motion Control Lever Rh
Palanca De Control Iz / Motion Control Lever Lh
Brazo De Control / Motion Control Arm
Adelante Eje / Front Axle
Tubo Hidraulico (Hst) / Hydraulic Pipe (Hst)
Tubo Hidraulico/Radiador De Aceite / Hydraulic Pipe/Oil Cooler
Pedal Ascenso / Lift Pedal
Control Valvula (Componente Piezas) / Control Valve (Component Parts)
Cilindro De Elevacion De Cortacespedes / Mower Lift Cylinder
Brazo De Elevacion De Cortacespedes / Mower Lift Arm
Bastidor Principal / Main Frame
Bastidor Superior / Upper Frame
Bastidor Superior [Opcion] / Upper Frame [Option]
Volante Cubierta / Flywheel Cover
Ajustador Maneta / Adjuster Handle
Ascenso Arriba Ajustador / Lift Up Adjuster
Mascara Adelante / Front Mask
Capo (Adelante) / Bonnet (Front)
Capo (Trasero) / Bonnet (Rear)
Guardabarros Dr / Fender Rh
Guardabarros Iz / Fender Lh
Asiento / Seat
Base Asiento / Seat Base
Peldano / Step
Peldano / Step
Arco De Seguridad / Rops
Rueda Adelante (15*6-6) / Front Wheel (15*6-6)
Rueda Trasero (26*12-12) / Rear Wheel (26*12-12)
Etiquetas / Labels
Accesorios / Accessories
