Kubota Lawn Mower ZD21-EC Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota ZD21-EC Lawn Mower
Number of Pages: 291 Pages
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Aceite Bomba / Oil Pump
Volante / Flywheel
Bomba InyecciN / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Cubierta / Cover
Dinamo Y Polea / Dynamo And Pulley
Dinamo[Componente Piezas] / Dynamo [Component Parts]
Motor De Arranque / Starter
Aceite Conmutador Y Termometro / Oil Switch And Thermometer
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Ventilador / Fan
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Superior Junta Kit [Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit [Opcion] / Lower Gasket Kit [Option]
Combustible Tubo / Fuel Pipe
A Prueba De Polvo Placa / Dustproof Plate
Conmutador/Controlador / Switch/Controller
Cableado ElCtrico / Electrical Wiring
Embrague / Clutch
Embrague / Clutch
Carga Bomba Caja / Charge Pump Case
Carga Bomba Caja [Opcion] / Charge Pump Case [Option]
Hst
Hst Derecho 1 [Componente Piezas] / Hst Rh 1 [Component Parts]
Hst Derecho 2 [Componente Piezas] / Hst Rh 2 [Component Parts]
Hst Izquierdo 1 [Componente Piezas] / Hst Lh 1 [Component Parts]
Hst Izquierdo 2 [Componente Piezas] / Hst Lh 2 [Component Parts]
Embrague Eje / Clutch Shaft
Entrada Eje / Input Shaft
Universal Junta/Ventilador / Universal Joint/Fan
Junta Eje / Joint Shaft
Eje Trasero / Rear Axle
Freno Eje / Brake Shaft
Freno Derecho / Brake Rh
Freno Izquierdo / Brake Lh
Freno Varilla / Brake Rod
Mano Freno / Hand Brake
Velocidad Control Palanca Derecho / Speed Control Lever Rh
Velocidad Control Palanca Izquierdo / Speed Control Lever Lh
Velocidad Control Varilla 1 / Speed Control Rod 1
Velocidad Control Varilla 2 / Speed Control Rod 2
Estacionamiento Freno Pedal / Parking Brake Pedal
Adelante Eje / Front Axle
Linea De Aceite Hidraulico (Impulsion) / Hydraulic Oil Line (Delivery)
Hydraulico Aceite Linea (Tdf) / Hydraulic Oil Line (Pto)
Hidraulico Tubo (Tdf) / Hydraulic Pipe (Hst)
Ascenso Palanca / Lift Lever
Cortacespedes Ascenso Brazo / Mower Lift Arm
Superior Bastidor / Upper Frame
Ajustador Maneta / Adjuster Handle
Ascenso Arriba Ajustador / Lift Up Adjuster
Adelante Mascara / Front Mask
Capo / Hood (Bonnet)
Guardabarros / Fender
Hoja / Seat
Asiento Suspension 1 [Componente Piezas] / Seat Suspension 1 [Component Parts]
Asiento Suspension 2 [Componente Piezas] / Seat Suspension 2 [Component Parts]
Peldano / Step
Rueda Delantera (15*6.00-6) / Front Wheel (15*6.00-6)
Rueda Posterior (24*12.00-12) / Rear Wheel (24*12.00-12)
Etiqueta(Adelante) / Label(Front)
Etiqueta(Trasero) / Label(Rear)
Accesorios / Accessories
Claxon Kit [Opcion] / Horn Kit [Option]
Kit Eja [Opcion] / Axle Kit [Option]
Deposito De Reserva [Opcion] / Oil Reserve Tank [Option]
