Kubota Lawn Mower ZD1211R-EU Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota ZD1211R-EU Lawn Mower
Number of Pages: 203 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Engranaje Caja / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Dipstick And Guide
Volante / Flywheel
Couvercle / Cover
Dinamo Y Polea / Dynamo And Pulley
Dinamo [Componente Piezas] / Dynamo [Component Parts]
Motor De Arranque / Starter
Aceite Conmutador Y Tapon / Oil Switch And Plug
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Ventilador / Fan
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Kit Junta Superior [Opcion] / Upper Gasket Kit [Option]
Kit Junta Inferior [Opcion] / Lower Gasket Kit [Option]
Palanca Del Acelerador / Accelerator Lever
Tubo De Combustible 1 / Fuel Pipe 1
Tubo De Combustible 2 / Fuel Pipe 2
A Prueba De Polvo Placa / Dustproof Plate
Interruptor Arranque/Metro/Sensor / Starter Switch/Meter/Sensor
Interruptor/Controlador/Rele / Switch/Controller/Relay
Instalacion Electrica / Electrical Wiring
Embrague / Clutch
Centro Cubierta(Delantero) / Center Cover (Front)
Centro Cubierta(Trasero) / Center Cover (Rear)
Carga Bomba / Charge Pump
Hst
Hst Izquierdo 1 [Componente Piezas] / Hst Lh 1 [Component Parts]
Hst Izquierdo 2 [Componente Piezas] / Hst Lh 2 [Component Parts]
Hst Izquierdo 3 [Componente Piezas] / Hst Lh 3 [Component Parts]
Hst Derecho 1 [Componente Piezas] / Hst Rh 1 [Component Parts]
Hst Derecho 2 [Componente Piezas] / Hst Rh 2 [Component Parts]
Hst Derecho 3 [Componente Piezas] / Hst Rh 3 [Component Parts]
Embrague Eje / Clutch Shaft
Eje De Entrada / Input Shaft
Universal Junta/Ventilador / Universal Joint/Fan
Eje De Junta / Joint Shaft
Freno Eje / Brake Shaft
Freno Varilla / Brake Rod
Estcnmnt Frn Pedal / Parking Brake Pedal
Palanca De Control Derecha / Motion Control Lever Rh
Palanca De Control Izquierda / Motion Control Lever Lh
Brazo De Control / Motion Control Arm
Eje Delantero / Front Axle
Tubo Hidraulico (Hst) / Hydraulic Pipe (Hst)
Tubo Hidraulico/Radiador De Aceite / Hydraulic Pipe/Oil Cooler
Ascenso Palanca / Lift Lever
Distribuidor / Control Valve
Cortacespedes Ascenso Brazo / Mower Lift Arm
Volante Cubierta / Flywheel Cover
Ajustador Maneta / Adjuster Handle
Ascenso Arriba Ajustador / Lift Up Adjuster
Adelante Mascara / Front Mask
Capo / Hood (Bonnet) Upper
Capo (Trasero) / Bonnet (Rear)
Guardabarros Izqd / Fender Lh
Hoja / Seat
Asiento Base / Seat Base
Peldano / Step
A Prueba De Polvo Placa / Dust Plate
Arco De Seguridad / Rops
Rueda Delantera (15*6,5-8ff) / Front Wheel (15*6,5-8ff)
Rueda Trasera (26*12,0-16) / Rear Wheel (26*12,0-16)
Etiquetas / Labels
Accesorios / Accessories
Volante / Flywheel
Couvercle / Cover
Ventilador / Fan
Embrague / Clutch
Hst
Hoja / Seat
Peldano / Step
Etiquetas / Labels
