Kubota Lawn Mower G3HST Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota G3HST Lawn Mower
Number of Pages: 137 Pages
Crankcase
Oil Pan
Gear Case
Main Bearing Case
Cylinder Head Cover
Manifold
Valve / Rocker Arm / Valve / Rocker Arm
Camshaft
Piston / Crankshaft / Piston / Crankshaft
Flywheel
Nozzle Holder
Nozzle Holder [Component Parts]
Flywheel
Injection Pump [Component Parts]
Idling Apparatus
Governor
Speed Control Plate
Dynamo
Water Flange
Governor
Dynamo [Component Parts]
Accessories And Service Parts
Air Cleaner
Muffler
Engine Stop Wire
Accel Lever
Fuel Pump
Idling Apparatus
Fuel Pipe
Fuel Filter [Component Parts]
Starter
Starter [Component Parts]
Battery
Transmission Case 1 [G2hst G3hst]
Propeller Shaft [G2hst G3hst]
4th Shaft [G2hst G3hst]
5th Shaft
H.S.T. [G2hst G3hst]
Speed Change Pedal [G2hst G3hst]
Rear Axle
Rear Wheel (23x10.50-12)
Brake (Old Type)
Brake (New Type)
Brake Pedal
Frame
Front Axle
Front Wheel (16x6.50-8)
Steering
Hydraulic Pipe [G2hst G3hst]
Pto Shaft
Tension Pulley
Pto Lever
Lift Shaft
Lift Linkage
Bonnet
Panel Cover
Dustproof Net
Fender
Seat (Old Type)
Seat (Old Type)
Seat (New Type)
Label
