Kubota Lawn Mower G26-LD Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota G26-LD Lawn Mower
Number of Pages: 381 Pages
Frequently Used Items
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Volante / Flywheel
Speed Control Plate
Combustible Bomba Cubierta / Fuel Pump Cover
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Superior Junta Kit [Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit [Opcion] / Lower Gasket Kit [Option]
Combustible Tubo / Fuel Pipe
Combustible Bomba / Fuel Pump
Ventilador / Fan
Cubierta Del Ventilador / Fan Shroud
Agua Tubo / Water Pipe
Alternador Y Polea / Alternator And Pulley
Motor De Arranque / Starter
Electrico Piezas / Electric Parts
Conmutador / Switch
Rele / Relay
Tablero Panel / Panel Board
Culata Luz / Head Light
Electrical Wiring
Transmision Caja (Bomba) / Transmission Case (Pump)
Transmision Caja (Válvula) / Transmission Case (Valve)
Freno Engranaje Eje/Engranaje Loco Eje / Brake Gear-Shaft/Idler Shaft
Entrada Eje / Input Shaft
Hst 1 (Bomba) / Hst 1 (Pump)
Hst 2 (Brazo) / Hst 2 (Arm)
Hst 3 (Puerto Bloque Cubierta ) / Hst 3 (Port Block Cover)
Hst 4 (Rotura Cubierta) / Hst 4 (Brake Cover)
Helice Eje / Propeller Shaft
Adelante Pto / Front Pto
Adelante Pto 1 (Embrague) [Componente Piezas] / Front Pto 1 (Clutch) [Compornent Parts]
Adelante Pto 2 (Eje) [Componente Piezas] / Front Pto 2 (Shaft) [Compornent Parts]
Adelante Pto 3 (Polea) [Componente Piezas] / Front Pto 3 (Pulley) [Compornent Parts]
Pto Tension Polea / Pto Tension Pulley
Trasero Diferencial Eje / Rear Differential Shaft
Trasero Axle Caja Izquierdo / Rear Axle Case Lh
Trasero Axle Caja Derecho / Rear Axle Case Rh
Trasero Rueda / Rear Wheel
Freno Pedal / Brake Pedal
Estcnmnt Frn Pedal / Parking Brake Pedal
Estacionamiento Freno Pedal / Parking Brake Lever
Velocidad Control / Cruise Control
Freno Varilla / Brake Rod
Trasero Freno (Izquierdo) / Rear Brake (Left)
Trasero Freno (Izquierdo) [Componente Piezas] / Rear Brake (Left) [Component Parts]
Trasero Freno (Derecho) / Rear Brake (Right)
Trasero Freno (Derecho) [Componente Piezas] / Rear Brake (Right) [Component Parts]
Freno Aceite Linea / Brake Oil Line
Hidraulico Control Palanca / Hydraulic Control Lever
Pto Palanca / Pto Lever
Adelante Eje / Front Axle
Adelante Pto Cubierta / Front Pto Cover
Universal Junta Cubierta [Fr] / Universal Joint Cover [Fr]
Hst Ventilador Cubierta / Hst Fan Cover
Adelante Rueda / Front Wheel
Ptnc Direccion/Direccion Maneta / Power Steering/Steering Handle
Direccion Varillaje / Steering Linkage
Pto Valvula / Pto Valve
Pto Valvula [Componente Piezas] / Pto Valve [Component Parts]
Hidraulico Aceite Linea (Adelante Pto) / Hydraulic Oil Line (Front Pto)
Hidraulico Aceite Linea (Aceite Filtro) / Hydraulic Oil Line (Oil Filter)
Hidraulico Aceite Linea (Devolver) / Hydraulic Oil Line (Return Pipe)
Hidraulico Ascenso Cilindro / Hydraulic Lift Cylinder
Ascenso Vinculo Derecho / Lift Link Rh
Ascenso Vinculo Izquierdo / Lift Link Lh
Cortacespedes Control Esfera / Mower Control Dial
Capo / Bonnet
Capo Lado / Bonnet Side
Capo Poste / Bonnet Post
Panel Tablero / Panel
Centro Montante / Center Pillar
Palanca Guia / Lever Guide
Guardabarros / Fender
Peldano / Step
Hoja / Seat
Grasa Recogedor Etiqueta / Grass Catcher Label
Base (Bajar) / Base (Lower)
Cerradura Brazo / Lock Arm
Hidraulico Cilindro (Vertedero) / Hydraulic Cylinder (Dump)
Hidraulico Cilindro (Vertedero) [Componente Piezas] / Hydraulic Cylinder (Dump) [Component Parts]
Cilindro Manguito (Vertedero) / Cylinder Hose (Dump)
Conmutador / Switch
Conducto / Duct
Conducto / Duct
Conducto Palanca / Duct Lever
Conducto Placa / Duct Plate
Conducto Tubo / Duct Pipe
Accesorios / Accessories
Velocidad De Crucero Control Valilla Kit [Opcion] / Cruise Control Rod Kit [Option]
Descargar Kit (Cubierta) [Opcion] / Discharge Kit (Cover) [Option]
Descargar Kit (Soporte,Dentro) [Opcion] / Discharge Kit (Inside Stay) [Option]
Descargar Kit (Brazo,Conmutador) [Opcion] / Discharge Kit (Switch Arm) [Option]
Descargar Kit (Soporte) [Opcion] / Discharge Kit (Stay) [Option]
Adaptador Racimo [Opcion] / Cluster Adapter Kit [Option]
Peso Soporte Kit [Opcion] / Weight Bracket Kit [Option]
Kit De La Circulacion Del Camino [Opcion] / Road Circulation Kit [Option]
Kit Del Espejo [Opcion] / Mirror Kit [Option]
Kit Del Asiento De Lujo [Opcion] / Deluxe Seat Kit [Option]
Tapon Placa Kit [Opcion] / Stopper Plate Kit [Option]
Freno Kit (Pedal) [Opcion] / Brake Kit (Pedal) [Option]
Freno Kit (Palanca) [Opcion] / Brake Kit (Lever) [Option]
Freno Kit (Varilla) [Opcion] / Brake Kit (Rod) [Option]
Freno Kit (Freno Izqd) [Opcion] / Brake Kit (Brake Lh) [Option]
Freno Kit (Freno Izqd) [Componente Piezas] [Opcion] / Brake Kit (Brake Lh) [Component Parts] [Option]
Freno Kit (Freno Dcha) [Opcion] / Brake Kit (Brake Rh) [Option]
Freno Kit (Freno Dcha) [Componente Piezas] [Opcion] / Brake Kit (Brake Rh) [Component Parts] [Option]
Freno Kit (Aceite Linea) [Opcion] / Brake Kit (Oil Line) [Option]
Freno Kit (Conmutador) [Opcion] / Brake Kit (Switch) [Option]
Freno Kit (Etiqueta) [Opcion] / Brake Kit (Label) [Option]
