Kubota Lawn Mower G26-II-HD Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota G26-II-HD Lawn Mower
Number of Pages: 283 Pages
Frequently Used Items
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Volante / Flywheel
Inyeccion Bomba / Injection Pump
Velocidad Control Placa / Speed Control Plate
Combustible Bomba Cubierta / Fuel Pump Cover
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Combustible Tubo/Combustible Filtro / Fuel Pipe/Fuel Filter
Ventilador / Fan
Cubierta Del Ventilador / Fan Shroud
Agua Tubo / Water Pipe
Alternador Y Polea / Alternator And Pulley
Motor De Arranque / Starter
Solenoide De Parada / Stop Solenoid
Claxon/Sensor / Horn/Sensor
Conmutador / Switch
Conmutador (Capo) / Switch (Bonnet)
Rele / Relay
Tablero Panel / Panel Board
Culata Luz / Head Light
Electrico Cableado / Electrical Wiring
Transmision Caja (Bomba) / Transmission Case (Pump)
Freno Engranaje Eje/Engranaje Loco Eje / Brake Gear-Shaft/Idler Shaft
Entrada Eje / Input Shaft
Hst 1 (Bomba) / Hst 1 (Pump)
Hst 2 (Brazo) / Hst 2 (Arm)
Hst 3 (Puerto Bloque Cubierta ) / Hst 3 (Port Block Cover)
Hst 4 (Cubierta Del Freno) / Hst 4 (Brake Cover)
Helice Eje / Propeller Shaft
Adelante Tdf / Front Pto
Adelante Pto 1 (Embrague) [Componente Piezas] / Front Pto 1 (Clutch) [Compornent Parts]
Adelante Pto 2 (Eje) [Componente Piezas] / Front Pto 2 (Shaft) [Compornent Parts]
Adelante Pto 3 (Polea) [Componente Piezas] / Front Pto 3 (Pulley) [Compornent Parts]
Pto Tension Polea / Pto Tension Pulley
Trasero Diferencial Eje / Rear Differential Shaft
Trasero Axle Caja Izquierdo / Rear Axle Case Lh
Trasero Axle Caja Derecho / Rear Axle Case Rh
Trasero Eje Izquierdo / Rear Axle Rh
Rueda Trasera / Rear Wheel
Freno Pedal / Brake Pedal
Freno Vinculo (Iz) / Brake Link (Left)
Freno Vinculo (Dr) / Brake Link (Right)
Estcnmnt Frn Pedal / Parking Brake Pedal
Freno Varilla / Brake Rod
Trasero Freno (Izquierdo) / Rear Brake (Left)
Trasero Freno (Derecho) / Rear Brake (Right)
Velocidad Control / Cruise Control
Velocidad Cambio Pedal / Speed Control Pedal
Hidraulico Control Palanca / Hydraulic Control Lever
Tdf Palanca / Pto Lever
Adelante Eje / Front Axle
Adelante Pto Cubierta / Front Pto Cover
Universal Junta Cubierta [Fr] / Universal Joint Cover [Fr]
Hst Ventilador Cubierta / Hst Fan Cover
Grasa Recogedor Soporte / Grass Catcher Support
Rueda Delantera / Front Wheel
Ptnc Direccion/Direccion Maneta / Power Steering/Steering Handle
Direccion Varillaje / Steering Linkage
Tdf Valvula / Pto Valve
Tdf Valvula [Componente Piezas] / Pto Valve [Component Parts]
Hidraulico Aceite Linea (Adelante Pto) / Hydraulic Oil Line (Front Pto)
Hidraulico Aceite Linea (Aceite Filtro) / Hydraulic Oil Line (Oil Filter)
Hidraulico Aceite Linea (Devolver) / Hydraulic Oil Line (Return Pipe)
Hidraulico Ascenso Cilindro / Hydraulic Lift Cylinder
Ascenso Vinculo Derecho / Lift Link Rh
Ascenso Vinculo Izquierdo / Lift Link Lh
Cortacespedes Control Esfera / Mower Control Dial
Capo / Bonnet
Capo Lado / Bonnet Side
Capo Poste / Bonnet Post
Panel Tablero / Panel
Centro Montante / Center Pillar
Palanca Guia / Lever Guide
Guardabarros / Fender
Peldano / Step
Hoja / Seat
Cilindro Tubo (Ascensor) / Cylinder Pipe (Lift)
Conducto / Duct
Conducto Palanca / Duct Lever
Descargar Kit (Cubierta) [Opcion] / Discharge Kit (Cover) [Option]
Descargar Kit (Soporte,Dentro) [Opcion] / Discharge Kit (Inside Stay) [Option]
Descargar Kit (Brazo,Conmutador) [Opcion] / Discharge Kit (Switch Arm) [Option]
Descargar Kit (Soporte) [Opcion] / Discharge Kit (Stay) [Option]
Tapon Placa Kit [Opcion] / Stopper Plate Kit [Option]
