Kubota Lawn Mower G231-HD Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota G231-HD Lawn Mower
Number of Pages: 341 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Oil Gauge
Aceite Bomba / Oil Pump
Volante / Flywheel
Pipa Excesiva Del Flujo / Over Flow Pipe
Combustible Bomba Cubierta / Fuel Pump Cover
Agua Bomba / Water Pump
Aire Limpiador / Air Cleaner
Entrada Tubo / Inlet Pipe
Silenciador / Muffler
Motor Parar Varilla / Engine Stop Rod
Combustible Bomba / Fuel Pump
Ventilador / Cooler Fan
Cubierta Del Ventilador / Fan Shroud
Agua Tubo / Water Pipe
Alternador / Alternator
Motor De Arranque / Starter
Bateria Cable / Battery Cable
Sensor/Claxon/Zumbador / Sensor/Horn/Buzzer
Conmutador (Freno/Capo/Hoja) / Switch (Brake/Bonnet/Seat)
Conmutador (Hst) / Switch (Hst)
Rele / Relay
Panel
Faro Delantero / Head Light
Cable Mazo De Cables (Principal) / Wire Harness (Body)
Cable Mazo De Cables (Fusible) / Wire Harness (Fuse)
Soporte De Alambre Arnes / Wire Harness Stay
Punto Muerto Eje / Idle Shaft
Eje De Entrada / Input Shaft
Hst
Hst (Caso) [Componente Piezas] / Hst (Case) [Component Parts]
Hst (Bomba) [Componente Piezas] / Hst (Pump) [Component Parts]
Hst (Brazo) [Componente Piezas] / Hst (Arm) [Component Parts]
Hst (Motor) [Componente Piezas] / Hst (Motor) [Component Parts]
Hst (Bloque De Puerto) [Componente Piezas] / Hst (Port Block) [Component Parts]
Hst (Poseedor) [Componente Piezas] / Hst (Holder) [Component Parts]
Tdf Eje / Pto Shaft
Tdf Embrague / Pto Clutch
Pto Tension Polea / Pto Tension Pulley
Trasero Diferencial Eje / Rear Differential Shaft
Trasero Eje Caja Izquierdo / Rear Axle Case Left
Trasero Eje Caja Derecho / Rear Axle Case Right
Eje De La Tracción Trasera (Izquierda) / Rear Wheel Drive Shaft (Left)
Eje De La Tracción Trasera (Derecha) / Rear Wheel Drive Shaft (Right)
Trasero Eje Izquierdo / Rear Axle Left
Trasero Eje Derecho / Rear Axle Right
Rueda Trasera (24*12-12) / Rear Wheel (24*12-12)
Freno Pedal / Brake Pedal
Freno Vinculo Izquierdo / Brake Link Left
Freno Vinculo Derecho / Brake Link Right
Estcnmnt Frn Pedal / Parking Brake Pedal
Freno Varilla / Brake Rod
Trasero Freno Izquierdo / Rear Brake Left
Trasero Freno Derecho / Rear Brake Right
Velocidad Control / Cruise Control
Hidraulico Control Palanca / Hydraulic Control Lever
Cierre Con Llave La Palanca / Safety Lock Lever
Eje Delantero Izquierda / Front Axle Left
Eje Delantero Derecha / Front Axle Right
Rueda Delantera (16*7.5-8) / Front Wheel (16*7.5-8)
Adelante Pto Cubierta / Front Pto Cover
Cubierta Comun Universal / Universal Joint Cover
Hst Ventilador Cubierta / Hst Fan Cover
Direccion / Steering
Dirección Soporte / Steering Bracket
Potencia Direccion Cilindro / Power Steering Cylinder
Distribuidor / Control Valve
Hidraulico Aceite Linea (Aceite Filtro) / Hydraulic Oil Line (Oil Filter)
Tubería De Aceite Hidráulico (Potencia Direccion 1) / Hydraulic Oil Line (Power Steering 1)
Tubería De Aceite Hidráulico (Potencia Direccion 2) / Hydraulic Oil Line (Power Steering 2)
Hidraulico Aceite Linea (Devolver) / Hydraulic Oil Line (Return Pipe)
Hidraulico Aceite Linea (T/M) / Hydraulic Oil Line (T/M)
Tubería De Aceite Hidráulico (Ascenso Cilindro) / Hydraulic Oil Line (Lift Cylinder)
Hidraulico Ascenso Cilindro / Hydraulic Lift Cylinder
Ascenso Vinculo Derecho / Lift Link Right
Ascenso Vinculo Izquierdo / Lift Link Left
Ascenso Vinculo Centro / Lift Link Center
Cortacespedes Control Esfera / Mower Control Dial
Capo Delantero / Bonnet Front
Capo / Bonnet
Capo Lado / Bonnet Side
Capó Inferior / Bonnet Lower
Capó Abierto / Bonnet Open
Panel
Centro Montante / Center Pillar
Palanca Guia / Lever Guide
Guardabarros / Fender
Guardabarros Soporte / Fender Support
Peldano / Step
Hoja / Seat
Cinturón Del Asiento / Seat Belt
Bloqueo De Asiento / Seat Lock
Soporte De Arco Seguridad / Rops Bracket
Arco De Seguridad / Rops
Valvula Manguito / Valve Hose
Interruptor De Bolsa / Bag Switch
Conducto / Duct
Conducto Palanca / Duct Lever
Acoplamiento De Conducto Palanca / Duct Lever Linkage
Accesorios / Accessories
Descargar Kit (Estructura) [Opcion] / Discharge Kit (Frame) [Option]
Descargar Kit (Cubierta) [Opcion] / Discharge Kit (Cover) [Option]
Descargar Kit (Placa) [Opcion] / Discharge Kit (Plate) [Option]
Descargar Kit (Interruptor De La Brazo) [Opcion] / Discharge Kit (Arm Switch) [Option]
Kit De La Circulacion Del Camino (Conmutador/Rele) [Opcion] / Road Circulation Kit (Switch/Relay) [Option]
Kit De La Circulacion Del Camino (Espejo) [Opcion] / Road Circulation Kit (Mirror) [Option]
Trasero Enganche Kit [Opcion] / Rear Hitch Kit [Option]
Kit Reposabrazos (Soporte De Asiento) [Opcion] / Deluxe Seat Bracket Kit (Seat Stay) [Option]
Kit Reposabrazos (Bloqueo De Asiento) [Opcion] / Deluxe Seat Bracket Kit (Seat Lock) [Option]
Kit Elevador (Soporte) [Opcion] / Maintenance Lift Kit (Bracket) [Option]
Kit Elevador (Ajustador) [Opcion] / Maintenance Lift Kit (Adjuster) [Option]
Kit Elevador (Mango) [Opcion] / Maintenance Lift Kit (Handle) [Option]
Almacenamiento Kit (Estructura) [Opcion] / Storage Kit (Frame) [Option]
Almacenamiento Kit (Varilla) [Opcion] / Storage Kit (Rod) [Option]
Volante / Flywheel
Rele / Relay
Panel
Hst
Tdf Eje / Pto Shaft
Capo / Bonnet
Panel
Peldano / Step
Hoja / Seat
Conducto / Duct
