Kubota Lawn Mower G23-3-HD-S5 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota G23-3-HD-S5 Lawn Mower
Number of Pages: 265 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Caja De Cambio / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Oil Gauge And Guide
Aceite Bomba / Oil Pump
Volante / Flywheel
Combustible Arbol De Levas / Fuel Camshaft And Governor Shaft
Inyeccion Bomba / Injection Pump
Combustible Bomba Cubierta / Fuel Pump Cover
Agua Bomba / Water Pump
Valvulas Y Balancines / Valve And Rocker Arm
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Combustible Tubo/Combustible Filtro / Fuel Pipe/Fuel Filter
Ventilador / Fan
Cubierta Del Ventilador / Fan Shroud
Agua Tubo / Water Pipe
Alternador Y Polea / Alternator And Pulley
Motor De Arranque / Starter
Claxon/Sensor / Horn/Sensor
Conmutador / Switch
Conmutador (Capo) / Switch (Bonnet)
Rele / Relay
Tablero Panel / Panel Board
Faro Delantero / Head Light
Electrico Cableado / Wire Harness
Transmision Caja (Bomba) / Transmission Case (Pump)
Freno Engranaje-Eje/Rueda Loca Eje / Brake Gear-Shaft/Idler Shaft
Eje De Entrada / Input Shaft
Hst (Bomba) / Hst (Pump)
Hst (Brazo) / Hst (Arm)
Hst (Cubierta Del Bloque De Puerto) / Hst (Port Block Cover)
Hst (Cubierta Del Freno) / Hst (Brake Cover)
Rele / Relay
Pto Eje / Pto Shaft
Pto Tension Polea / Pto Tension Pulley
Trasero Diferencial Eje / Rear Differential Shaft
Rueda Trasera / Rear Wheel
Pto Freno / Pto Brake
Freno Pedal / Brake Pedal
Freno Vinculo Izquierdo / Brake Link Lh
Freno Vinculo Derecho / Brake Link Rh
Estcnmnt Frn Pedal / Parking Brake Pedal
Freno Varilla / Brake Rod
Trasero Freno Izquierdo / Rear Brake Lh
Trasero Freno Derecho / Rear Brake Rh
Velocidad Control / Cruise Control
Hidraulico Control Palanca / Hydraulic Control Lever
Pto Palanca / Pto Lever
Pto Cable Soporte / Pto Wire Bracket
Eje Delantero / Front Axle
Rueda Delantera / Front Wheel
Adelante Pto Cubierta / Front Pto Cover
Rele / Relay
Cubierta Comun Universal / Universal Joint Cover
Hst Ventilador Cubierta / Hst Fan Cover
Potencia Direccion/Direccion Maneta / Power Steering/Steering Handle
Direccion Varillaje / Steering Linkage
Distribuidor / Control Valve
Hidraulico Aceite Linea (Aceite Filtro) / Hydraulic Oil Line (Oil Filter)
Hidraulico Aceite Linea (Devolver) / Hydraulic Oil Line (Return Pipe)
Hidraulico Aceite Linea (T/M) / Hydraulic Oil Line (T/M)
Hidraulico Ascenso Cilindro / Hydraulic Lift Cylinder
Ascenso Vinculo Derecho / Lift Link Rh
Ascenso Vinculo Izquierdo / Lift Link Lh
Cortacespedes Control Esfera / Mower Control Dial
Capo / Hood (Bonnet)
Capo Lado / Bonnet Side
Capo Poste / Bonnet Post
Panel
Centro Montante / Center Pillar
Palanca Guia / Lever Guide
Guardabarros / Fender
Peldano / Step
Hoja / Seat
Cinturón Del Asiento / Seat Belt
Plataforma / Platform
Arco De Seguridad / Rops
Hidraulico Manguito Bajar / Cylinder Hose Lower
Conducto / Duct
Conducto Palanca / Duct Lever
Descargar Kit (Cubierta) [Opcion] / Discharge Kit (Cover) [Option]
Descargar Kit (Soporte,Dentro) [Opcion] / Discharge Kit (Inside Stay) [Option]
Descargar Kit (Brazo,Conmutador) [Opcion] / Discharge Kit (Switch Arm) [Option]
Descargar Kit (Soporte) [Opcion] / Discharge Kit (Stay) [Option]
Accesorios / Accessories
Tapon Placa Kit [Opcion] / Stopper Plate Kit [Option]
