Kubota Lawn Mower G21HD Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota G21HD Lawn Mower
Number of Pages: 247 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Aceite Bomba / Oil Pump
Volante / Flywheel
Speed Control Plate
Combustible Bomba Cubierta / Fuel Pump Cover
Manocontacto De Aceite/Termometro / Oil Switch/Thermometer
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Silenciador [Fr] / Muffler [Fr]
Superior Junta Kit [Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit [Opcion] / Lower Gasket Kit [Option]
Combustible Tubo/Combustible Filtro / Fuel Pipe/Fuel Filter
Ventilador / Fan
Alternador / Alternator
Motor De Arranque / Starter
Electrico Piezas / Electrical Parts
Culata Luz / Head Light
Freno Engranaje-Eje/Rueda Loca Eje / Brake Gear-Shaft/Idler Shaft
Hst
Hst 1 (Cubierta) / Hst 1 (Housing)
Hst 2 (Tapon) / Hst 2 (Plug)
Hst 3 (Cilindro Bloque,Motor) / Hst 3 (Cylinder Block,Motor)
Hst 4 (Cilindro Bloque,Bomba) / Hst 4 (Cylinder Block,Pump)
Universal Junta/Hst Ventilador / Universal Joint/Hst Fan
Pto Eje / Pto Shaft
Pto Tension Polea / Pto Tension Pulley
Trasero Diferencial Eje / Rear Differential Shaft
Trasero Eje Caja / Rear Axle Case
Eje Trasero / Rear Axle
Rueda Trasera(23*10,50-12) / Rear Wheel (23*10.50-12)
Pto Freno / Pto Brake
Freno / Brake
Freno Pedal / Brake Pedal
Freno Varilla / Brake Rod
Velocidad Control Brazo / Speed Control Arm
Hidraulico Control Palanca / Hydraulic Control Lever
Pto Embrague Control Palanca/Cable / Pto Clutch Control Lever/Wire
Pto Cable Soporte / Pto Wire Bracket
Adelante Eje / Front Axle
Principal Bastidor/Direccion Soporte / Main Frame/Steering Support
Principal Bastidor/Direccion Soporte [Fr] / Main Frame/Steering Support [Fr]
Motor Soporte [Fr] / Engine Support [Fr]
Rueda Delantera(16*6,5-8) / Front Wheel (16*6.5-8)
Potencia Direccion/Direccion Maneta / Power Steering/Steering Handle
Hidraulico Aceite Linea(Aspiracion) / Hydraulic Oil Line (Suction)
Hidraulico Aceite Linea(Respiradero) / Hydraulic Oil Line (Breather)
Hidraulico Aceite Linea(Vaciar) / Hydraulic Oil Line (Drain)
Hidraulico Ascenso Cilindro / Hydraulic Lift Cylinder
Ascenso Vinculo / Lift Link
Capo (Capo) / Hood (Bonnet)
Capo (Capo) [Fr] / Hood(Bonnet) [Fr]
Panel
Guardabarros / Fender
Hoja / Seat
Hoja / Seat
Asiento Suspension / Seat Suspension
Etiqueta / Label
Etiqueta [Fr] / Label [Fr]
Cubierta (Cuerpo Adelante) [Fr] [Opcion] / Safety Cover Kit (Body Front) [Fr] [Option]
Cubierta (Cuerpo Trasero) [Fr] [Opcion] / Safety Cover Kit (Body Rear) [Fr] [Option]
