Kubota Lawn Mower G2160-F-4-S5 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota G2160-F-4-S5 Lawn Mower
Number of Pages: 233 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Caja De Cambio / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Oil Gauge
Aceite Bomba / Oil Pump
Caja De Cambios Ppal / Main Bearing Case
Volante / Flywheel
Combustible Arbol De Levas / Fuel Camshaft And Governor Shaft
Combustible Bomba Cubierta / Fuel Pump Cover
Agua Bomba / Water Pump
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Combustible Bomba / Fuel Pump
Ventilador / Fan
Cubierta Del Ventilador / Fan Shroud
Agua Tubo (Motor) / Water Pipe (Engine)
Agua Tubo (Cuerpo) / Water Pipe (Body)
Alternador / Alternator
Motor De Arranque / Starter
Conmutador / Switch
Rele / Relay
Faro Delantero / Head Light
Instalacion Electrica / Electrical Wiring
Caja Transmision / Transmission Case
Freno Engranaje-Eje/Rueda Loca Eje / Brake Gear-Shaft/Idler Shaft
Hst
Hst 1 (Cubierta) [Componente Piezas] / Hst 1 (Housing) [Component Parts]
Hst 2 (Tapon) [Componente Piezas] / Hst 2 (Plug) [Component Parts]
Hst 3 (Bloque De Cilindro,Motor) [Componente Piezas] / Hst 3 (Cylinder Block,Motor) [Component Parts]
Hst 4 (Bloque De Cilindro,Bomba) [Componente Piezas] / Hst 4 (Cylinder Block,Pump) [Component Parts]
Universal Junta/Hst Ventilador / Universal Joint/Hst Fan
Tdf Eje / Pto Shaft
Tdf Tension Polea / Pto Tension Pulley
Trasero Diferencial Eje / Rear Differential Shaft
Rueda Trasera (23*10,50-12) / Rear Wheel (23*10.50-12)
Pto Freno / Pto Brake
Freno / Brake
Freno Pedal / Brake Pedal
Freno Varilla / Brake Rod
Velocidad Control Brazo / Speed Control Arm
Hidraulico Control Palanca / Hydraulic Control Lever
Pto Embrague Control Palanca/Cable / Pto Clutch Control Lever/Wire
Pto Cable Soporte / Pto Wire Bracket
Eje Delantero / Front Axle
Adelante Eje Varilla,Atar / Front Axle Tie Rod
Rueda Delantera (16*6,5-8) / Front Wheel (16*6.5-8)
Cubierta Comun Universal / Universal Joint Cover
Direccion Soporte / Steering Support
Direccion Varillaje / Steering Linkage
Distribuidor / Control Valve
Hidraulico Aceite Linea (Respiradero) / Hydraulic Oil Line (Breather)
Hidraulico Aceite Linea (Vaciar) / Hydraulic Oil Line (Drain)
Hidraulico Ascenso Cilindro / Hydraulic Lift Cylinder
Ascenso Vinculo Soporte / Lift Link Support
Ascenso Vinculo Derecho / Lift Link Rh
Ascenso Vinculo Izquierdo / Lift Link Lh
Cortacespedes Control Esfera / Mower Control Dial
Enganche / Hitch
Capo / Hood (Bonnet)
Tablero De Instrumentos / Panel
Palanca Guia / Lever Guide
Guardabarros / Fender
Hoja / Seat
Cinturón Del Asiento / Seat Belt
Enlace De Apoyo De Asiento / Seat Support Link
Arco Deseguridad (Bajar) / Rops (Lower)
Arco Deseguridad (Braco) / Rops (Upper)
Etiquetas / Labels
Accesorios / Accessories
Volante / Flywheel
Ventilador / Fan
Conmutador / Switch
Rele / Relay
Hst
Tdf Eje / Pto Shaft
Freno / Brake
Enganche / Hitch
Hoja / Seat
Etiquetas / Labels
