Kubota Lawn Mower G2160-F-2 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota G2160-F-2 Lawn Mower
Number of Pages: 253 Pages
Bloque Motor / Crankcase
Carter / Oil Pan
Cilindro Ppal / Cylinder Head
Caja De Cambio / Gear Case
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Medidor,Aceite / Gauge,Oil
Aceite Bomba / Oil Pump
Caja De Cambios Ppal / Main Bearing Case
Piston Y Ciguenal / Piston And Crankshaft
Volante / Flywheel
Arbol De Levas Sist De Combustible / Fuel Camshaft
Portainyector [Componentes] / Nozzle Holder [Component Parts]
Combustible Bomba Cubierta / Fuel Pump Cover
Termostatoy Tapa / Water Flange And Thermostat
Bomba Agua / Water Pump
Agua Tubo (Motor) / Water Pipe (Engine)
Valvulas Y Balancines / Valve And Rocker Arm
Filtro De Aire / Air Cleaner
Entrada Tubo / Inlet Pipe (Air Cleaner)
Silenciador / Muffler
Filtro Combustible / Fuel Filter
Combustible Bomba / Fuel Pump
Ventilador / Cooling Fan
Agua Tubo (Carroceria) / Water Pipe (Body)
Alternador / Alternator
Alternador [Componentes] / Alternator [Component Parts]
Motor De Arranque / Starter
Motor De Arranque [Componentes] / Starter [Component Parts]
Conmutador / Switch
Rele / Relay
Culata Luz / Head Lamp
Electrico Cableado / Wire Harness
Freno Engranaje-Eje/Rueda Loca Eje / Brake Gear-Shaft/Idler Shaft
Hst
Hst 1 (Cubierta) [Componente Piezas] / Hst 1 (Housing) [Component Parts]
Hst 2 (Tapon) [Componente Piezas] / Hst 2 (Plug) [Component Parts]
Hst 3 (Cilindro Bloque,Motor) [Componente Piezas] / Hst 3 (Cylinder Block,Motor) [Component Parts]
Hst 4 (Cilindro Bloque,Bomba) [Componente Piezas] / Hst 4 (Cylinder Block,Pump) [Component Parts]
Universal Junta/Hst Ventilador / Universal Joint/Hst Fan
Pto Eje / Pto Shaft
Pto Tension Polea / Pto Tension Pulley
Diferencial Trasero / Rear Wheel Differential
Trasero Diferencial Eje / Rear Differential Shaft
Rueda Trasera (23*10.50-12) / Rear Wheel (23*10.50-12)
Pto Freno / Pto Brake
Freno / Brake
Freno Pedal / Brake Pedal
Freno Varilla / Brake Rod
Velocidad Control Brazo / Speed Control Arm
Hidraulico Control Palanca / Hydraulic Control Lever
Pto Embrague Control Palanca/Cable / Pto Clutch Control Lever/Wire
Pto Cable Soporte / Pto Wire Bracket
Eje Delantero / Front Axle
Adelante Eje Varilla,Atar / Front Axle Tie Rod
Cubierta Comun Universal / Universal Joint Cover
Direccion Soporte / Steering Support
Rueda Delantera (16*6.5-8) / Front Wheel (16*6.5-8)
Maneta Direccion / Steering Handle
Direccion Varillaje / Steering Linkage
Distribuidor / Control Valve
Hidraulico Aceite Linea(Aspiracion) / Hydraulic Oil Line (Suction)
Hidraulico Aceite Linea(Respiradero) / Hydraulic Oil Line (Breather)
Hidraulico Aceite Linea(Vaciar) / Hydraulic Oil Line (Drain)
Hidraulico Ascenso Cilindro / Hydraulic Lift Cylinder
Ascenso Vinculo Soporte / Lift Link Support
Ascenso Vinculo Derecho / Lift Link Rh
Ascenso Vinculo Izquierdo / Lift Link Lh
Cortacespedes Control Esfera / Mower Control Dial
Enganche / Hitch
Capo / Bonnet
Panel
Palanca Guia / Lever Guide
Guardabarros / Fender
Guardabarros Soporte / Fender Support
Asiento / Seat
Asiento Suspension / Seat Suspension
Etiquetas / Labels
Universal Junta / Universal Joint
Entrada Eje/Centro Polea / Input Shaft/Center Pulley
Polea Soporte/Lamina(Centro) / Pulley Holder/Blade (Center)
Polea Soporte/Lamina(Izquierdo) / Pulley Holder/Blade (Left)
Panel
Polea Soporte/Lamina(Derecho) / Pulley Holder/Blade (Right)
Tension Polea/Cortacespedes Correa / Tension Pulley/Mower Belt
Cobierta Y Cubierta Del Cortacespedes / Mower Deck And Cover
Descargar Cubierta / Discharge Cover
Medidor Rueda / Gauge Wheel
Adelante Vinculo Palanca / Front Link Lever
Cortacespedes Etiqueta / Mower Label
Accesorios Y Servicio Piezas / Accessories
Carter / Oil Pan
Volante / Flywheel
Conmutador / Switch
Rele / Relay
Hst
Pto Eje / Pto Shaft
Freno / Brake
Enganche / Hitch
Capo / Bonnet
Panel
Asiento / Seat
Etiquetas / Labels
Panel
