Kubota Lawn Mower G1900-S Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Lawn Mower
Model: Kubota G1900-S Lawn Mower
Number of Pages: 245 Pages
Bloque Motor / Crankcase
Aceite Cacerola / Oil Pan
Piston/Ciguenal / Piston/Crankshaft
Volante / Flywheel
Valvula/Balancin Brazo / Valve/Rocker Arm
Tobera Soporte/Bujia De Calentamiento Tapon / Nozzle Holder/Glow Plug
Portainyector [Componentes] / Nozzle Holder [Component Parts]
Culata Cubierta / Head Cover
Aire Limpiador / Air Cleaner
Exhaust Manifold
Silenciador / Muffler
Arbol De Levas / Camshaft
Agua Bomba / Water Pump
Water Flange/Thermostat / Water Flange/Thermostat
Bomba Inyección / Injection Pump
Placa De Control De Velocidad / Speed Control Plate
Upper Gasket Kit [Option]
Lower Gasket Kit [Option]
Ventilador / Fan
Dinamo / Dynamo
Dynamo [Fr][Component Parts]
Alternator [Uk][Sw][Component Parts]
Combustible Tubo / Fuel Pipe
Motor De Arranque [Componentes] / Starter [Component Parts]
Light
Dashboard
Dashboard [Component Parts]
Wire Harness [Fr]
Wire Harness [Uk][Sw]
Hst
Hst [Component Parts]
Universal Joint/Hst Fan [Old Type] / Universal Joint/Hst Fan [Old Type]
Universal Joint/Hst Fan [New Type] / Universal Joint/Hst Fan [New Type]
Pto Shaft
Tension Pulley
Belt Retainer
Rear Pto [Option]
Rear Pto [Component Parts]
Cruise Control Plate
Cruise Control Lever
Speed Control Pedal
Rear Axle Case
Rear Axle [4ws]
Rear Axle Joint [4ws]
Knuckle Arm [4ws]
Tie Rod [4ws]
Drag Link [4ws]
Rear Wheel (23*8.50-12) [4ws]
Pto Brake
Brake Shaft
Freno / Brake
Brake Rod
Freno Pedal / Brake Pedal
Front Axle/Knuckle Arm / Front Axle/Knuckle Arm
Tie Rod/Drag Link / Tie Rod/Drag Link
Front Wheel (16*6.50-8)
Frame
Steering Gear Case
Steering Wheel
Control Valve [Component Parts]
Rear Axle Case
Hydraulic Pipe 1
Hydraulic Pipe 2
Lift Cylinder
Hydraulic Outlet [Old Type][Option]
Hydraulic Outlet [New Type][Option]
3-Point Linkage [Option]
Mower Assist Spring [Option]
Mower Swing Stopper [Option]
Hood (Bonnet)
Panel
Fender
Hoja / Seat
Label
